Blender 2.64a x86_64 not start in ubuntu 12.10 AMD64 Linux
YQ-YSY
Postby YQ-YSY » Fri Nov 02, 2012 2:02 pm
Blender 2.64a x86_64 not start in ubuntu 12.10 AMD64 Linux.
If run Blender in terminal, can got the following error :
error while loading shared libraries: libSDL-1.2.so.0: cannot open shared object file: No such file or directory
All is ok in ubuntu 12.04. Why error in 12.10 ?
Someone meet this problem too:
http://ubuntuforums.org/showthread.php?p=12308344
How can i fix that?
Postby stiv » Fri Nov 02, 2012 3:12 pm
You need to install the dev package for libSDL-1.2. That message means Blender could not find the shared library.
YQ-YSY
Postby YQ-YSY » Sat Nov 03, 2012 2:23 am
Thanks! It works!
(1) download SDL-1.2.15.tar.gz here: (3.7M)
http://www.libsdl.org/release/
(2) Run command in terminal:
tar -xzvf SDL-1.2.15.tar.gz
cd SDL-1.2.15
./configure
make
sudo make install
(3) So you can find libSDL-1.2.so.0 at /usr/lib/
And then Blender 2.64a can start in Ubuntu 12.10 now!
YOGYOG
Postby YOGYOG » Fri Nov 09, 2012 11:05 am
errr..... can I have a dumbed-down version of that for less techie people?
This is what I tried:
yogyog@yogyog-305V4A-305V5A:~$ tar -xzvf SDL-1.2.15.tar.gz
tar (child): SDL-1.2.15.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
yogyog@yogyog-305V4A-305V5A:~$ tar -xzvf yogyog/Home/Downloads/SDL-1.2.15.tar.gz
tar (child): yogyog/Home/Downloads/SDL-1.2.15.tar.gz: Cannot open: No such file or directory
yogyog@yogyog-305V4A-305V5A:~$ cd SDL-1.2.15.tar.gz
bash: cd: SDL-1.2.15.tar.gz: No such file or directory
yogyog@yogyog-305V4A-305V5A:~$ cd yogyog/Home/Downloads/SDL-1.2.15.tar.gzbash: cd: yogyog/Home/Downloads/SDL-1.2.15.tar.gz: No such file or directory
yogyog@yogyog-305V4A-305V5A:~$ ^C
yogyog
Postby stiv » Fri Nov 09, 2012 4:30 pm
Did you forget the "download the file" step?
YOGYOG
Postby YOGYOG » Tue Nov 13, 2012 3:50 pm
Yes... I did.
I was pointing the terminal at the wrong folder.
I sorted that - but to no avail - getting help from someone who knows far more about this sort of thing.
And it still didn't work!
I'm thinking of going back to the penultimate Ubuntu, or waiting and seeing if somebody solves this problem for me, meanwhile using Blender on the Windows half of my machine.
yogyog
YOGYOG
Postby YOGYOG » Thu Nov 15, 2012 1:00 pm
OK - I've just discovered a whole new level of weirdness... good weirdness! :D
If I click Blender in the dock, or type blender in the terminal, nothing happens*.... but if I click a .blend file it works fine!
well - I'm happy now anyway.
*the error message I get is
connect failed: No such file or directory
FRS_set_context: context 0x0x4f940d8 scene 0x0x5566e08
Segmentation fault (core dumped)
yogyog
Postby stiv » Fri Nov 16, 2012 2:22 am
The connect failed: No such file or directory message is just a warning that no Space Navigator was found. Not to worry!
This is more serious:
The fact you can click on .blend and it loads fine suggests your default .blend is trashed somehow. After starting Blender, you might try resetting the defaults:
File->Load Factory Settings
File->Save User Defaults
TxRxFx
Postby TxRxFx » Mon May 06, 2013 2:38 pm
YQ-YSY wrote:Thanks! It works!
cd SDL-1.2.15
./configure
make
sudo make install
Must confess when I was creating headless 12.04 vmimage I only had to just run
sudo apt-get install libsdl1.2-dev libXi6
to clear up any weird not wanting to play when rendering cmdline renders.
Return to “News & Chat”
