Rounded cube modelling
modula
Postby modula » Fri Nov 16, 2012 8:05 am
I'm new to modelling so please bear with me! I need to create a model of a traditional sardine tin; a cubic shape with rounded corners. Is there an easy way to round the corners on a cube please?
Thanks
Sam
CoDEmanX
Postby CoDEmanX » Fri Nov 16, 2012 12:25 pm
You can probably do this in blender somehow, but for me it's easier to create the shape externally (InkScape):
http://www.pasteall.org/blend/17520
modula
Postby modula » Fri Nov 16, 2012 12:58 pm
Thank you so much, that's brilliant! Huge help; thank you
dom107
Postby dom107 » Fri Nov 16, 2012 1:06 pm
Hello,
2 methods :
1) Edit mode
Select all edges
Add modifier bevel
Select proper width = w
Set object to Smooth
For a less crude effect :
Add a second modifier bevel with width = w/2
2) Add modifier subdivision surface
Edit mode
Then use Loop Cut and slide several times moving the loop line down towards a face, leaving some space between the loop line and a face for the rounded effect (I saw this on a video).
modula
Postby modula » Fri Nov 16, 2012 5:59 pm
CoDEmanX - I have converted the curves in the file you gave me in to a mesh so that I can build it up to include lips at the top and bottom, but it creates a really complex top face - I need this to join in to one single face, but cannot get it to do this; any ideas please?
modula
Postby modula » Fri Nov 16, 2012 6:04 pm
Actually ignore me; I revisited the original file that you sent me and it's not a problem; I'd done something weird to it! Ta
apm-designs
Postby apm-designs » Thu Feb 21, 2013 5:53 pm
I have previously entered a link that is no longer in use.
Here you can find information on how to create a cube with rounded corners as a starting point.
Hope this helps
http://www.apm-designs.com/blender-tuto ... ed-corners
Return to “Interface & Tools”
