Same speed with GPU than with CPU?
Fran
Postby Fran » Tue Jan 01, 2013 12:51 pm
Hi there,
I have an Ubuntu box where I have been able to install and enable CUDA for my nVidia GeForce GT610, so I can select its GPU on Blender for rendering instead the CPU.
The problem is that the render takes the same time with the GPU than with the CPU. I was no expecting this graphic card to be awesome, but the problem is that the rendering time is EXACTLY the same for the same scene, so I think it may not be using the GPU at all even when it lets me select it.
Any ideas for debugging this problem? How could I make sure of what device is blender using for rendering?
Thanks a lot in advance,
Fran
Postby Fran » Tue Jan 01, 2013 1:17 pm
I have even changed the GPU behaviour from "adaptative" to "perfomance" with nvidia-settings application and there were no changes at all, so it actually seems like Blender is NOT using the GPU, whatever settings I put.
Pi x Om
Postby Pi x Om » Tue Jan 01, 2013 5:33 pm
happy new year ;)
do you monitoring cpu/gpu usage?
u should, bcs u could be sure about whats used or not :)
for cuda usage u need to enable it in the user prefs
and then in the render tab/device: cpu to gpu.
at another thing, i am not sure if it can work in a (virtual) box.
br
Fran
Postby Fran » Tue Jan 01, 2013 6:51 pm
Happy new year to you too.
Of course I have selected my GeForce GPU on User preferences instead of the CPU, that's exactly the point...
I do not know how to monitory gpu usage, although top command shows that CPU usage by blender boosts when making a render, even when GPU has been selected as render device, so it seems like it were using the CPU anyway, no matter what I set on user preferences.
I am not using a virtual box, but actual hardware.
Bests,
Pi x Om
Postby Pi x Om » Tue Jan 01, 2013 11:29 pm
u didn´t said what system u have (cpu importand)
but on my system when I render with cpu it uses 4 cores, when i render with gpu,
it uses one cpu core.
here on windows we have task manager, where u can see cpu usage or another way desktop widgets.
I am not sure if there is something like these available on linux :D
Tehrasha
Postby Tehrasha » Wed Jan 02, 2013 12:34 am
Linux definitely has CPU usage measuring capability. GPU usage I am not as certain of. I typically judge that by how fast the graphics card fan runs. :)
Fran
Postby Fran » Wed Jan 02, 2013 1:38 am
As I told you 'top' Linux command shows similar CPU activity on both cases.
I honestly appreciate your interest, but I asked this question here with the hope that someone that has addressed similar problems -or at least with a similar configuration- could give me some straight forward advice, not for taking shots in the dark, an activity that I am able to do by myself.
Bests,
Pi x Om
Postby Pi x Om » Wed Jan 02, 2013 2:45 pm
Moderator's Note:
This post was deleted due to its lack of useful info and bad attitude. Let's all play nice!
MrJimbob
Similar issue
Postby MrJimbob » Mon Jan 28, 2013 2:25 pm
I'm having similar results, running:
Blender 2.65
i7 2720QM
Nvidea GTX 460M
Same render speed using GPU / CPU.
I'm not convinced it is actually using the GPU - anyone have any ideas on how to check this?
Return to “Rendering”
