chat icon MS3D Export problems
Shadoh
Posted: Mon Jan 21, 2013 12:58 am
Hi all.
I'm using the MS3D file format as a format to import in to my game.
When I export the model to MS3D the Bones seem to align to the Y-Axis-up system, like I want it to, but the vertices don't. And it completely screws the animations (The joints move in the wrong directions, and get warped).
This is what it looks like when I load it in Milkshape
beta-tester
Posted: Fri Feb 08, 2013 11:01 pm
Shadoh wrote:
Hi all.
hello, can you provide the blend file and the ms3d file, that i can take a look to it
Shadoh
Posted: Fri Feb 08, 2013 11:30 pm
Here's the MS3D file
https://dl.dropbox.com/u/27825152/Blender/TestHuman.ms3d
Here's the blend file
https://dl.dropbox.com/u/27825152/Blender/basemesh_male.blend
Thanks
beta-tester
Posted: Sat Feb 09, 2013 12:11 pm
thank you for providing the files...
i can confirm the issues.
as quick workaround, you can apply the location and rotation of the mesh and the armature to (0, 0, 0).
- [Shift]+[C] to bring the cursor to (0,0,0)
- for the mesh, hit [Ctrl]+[A],[L] than [Ctrl]+[A],[R]
- for the armature, hit [Ctrl]+[A],[L] than [Ctrl]+[A],[R]
that will fix the wrong orientation of the mesh and lines up mesh to armature.
BUT ! than i saw, that some vertices are not correctly transformed in the animation.
i will invest some time to figure out, what the problem is an how to fix it in the add-on, hopefully i will find a nice solution.
_________________
http://wiki.blender.org/index.php/User:Beta-tester
beta-tester
Posted: Sat Feb 09, 2013 12:32 pm
i saw, that some vertices in your model has weights for more than 3 different bones. milkshape does only allow 3 as maximum.
on export, when you watch the report info log (i don't know the correct name of that area in blender - if you don't see it, grab the lower border of the headline a bit down...). there are some messages like "skipped weight" and "skippes weight: limit exeeded".
because i take the weights as they ordered and not as they affected by the bones, it will be randomly skip strong weights, what will be very visible.
i will try to change the exporter to take first the strong weights and skip less stronger weights in case of skipping...
and maybe add an option to show problematic vertices with more than 3 weights in editmode.
_________________
beta-tester
Posted: Sat Feb 09, 2013 2:31 pm
[/quote]
version 0.94.0 is online.
http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Import-Export/MilkShape3D_MS3D
i made some changes in the add-on to fix only the wrong weights, for now, in case of more than 3 - now the ones with higher weights will keeped, and the less ones will skipped.
will work well with your model without strange visible issues.
but you still have to apply location and rotation for now - i will fix this late.
_________________
beta-tester
Posted: Sat Feb 09, 2013 9:43 pm
hmmm... Confused
i don't know, what i was testing today in the morning...
but the export option "Apply Transformation" is doing that what i was telling you before just at export time automatically.
so, for me the add-on is OK with version 0.94.0 - or i am now wrong?!?
please let me know. i am a little bit confused right now.
anyhow, it was good, otherwise i didn't found the issue with the weights. Razz
PS.: if you download the blender 2.65.10 r54409 or newer, you will get that updated add-on version.
_________________
Shadoh
Posted: Sat Feb 09, 2013 10:54 pm
Ok, I'll give it a try now Smile thanks
Shadoh
Posted: Sun Feb 10, 2013 12:35 am
That's awesome it's working perfectly! Thank you Very Happy
beta-tester
Posted: Sun Feb 10, 2013 12:51 am
version 0.95.0 is online.
or wait for a new blender 2.65.10 newer than r54416 on the builder page
http://builder.blender.org/download/
i changed the transformation in the exporter, because i saw, that when i import an exported model that was parented with an other object/armature, it may happen, that it appears on a slightly different position than it was on export time. it will also affect the position in your game - maybe you already noticed this distortion - it should be fixed now.
_________________
