Posted: Wed Feb 13, 2013 1:43 am
I was wondering if there was any way to read sensor data from Arduino without using Pyserial.
Pyserial is a pain to setup.
Posted: Wed Feb 13, 2013 5:52 pm
The trick with pyserial is to install it for Python 3.3, which Blender uses. Then you need to add the path to pyserial to sys.path in Blender since Blender uses it's own copy of Python.
Other options, needing either some hardware on the Arduino side or some low-level coding, include bit-banging on the parallel port or sending data over TCP/IP.
Posted: Wed Feb 13, 2013 9:55 pm
I'll try to find Pyserial for Python 3.3 and follow that and get back to you.
What kind of hardware do you suggest on the arduino side? That seems practical to me if it is cheap and will bring it closer to a plug and play experience.
Advice much much appreciated Stiv.
| stiv wrote: |
Other options, needing either some hardware on the Arduino side or some low-level coding, include bit-banging on the parallel port or sending data over TCP/IP. |
Posted: Thu Feb 21, 2013 12:43 am
I'm not quite sure how to install it specifically for Python 3.3. Does this have to do with the version of pyserial? or what ?
| stiv wrote: |
Posted: Thu Feb 21, 2013 12:52 am
| Quote: |
| I'm not quite sure how to install it specifically for Python 3.3. Does this have to do with the version of pyserial? or what ? |
It has to do with the version of Python used to do the pyserial install. Like running easy_install-3.3, or python3 setup.py...
There are two issues here:
One is the modules must be built for the correct version of python since struct sizes change between versions.
The other is having the module end up where the appropriate version of python (or blender) can see it. This is less important and can be tweaked by setting the PYTHONPATH env var or appending to sys.path before importing.
Posted: Sat Feb 23, 2013 4:36 pm
Yesterday I added pyserial to Blender 2.66 on Ubuntu and Windows.
I could not get pyserial working with Python outside Blender, but I could make it works with the internal Python included in Blender.
I've taken the following steps:
Ubuntu (12.04-64bit):
- Open a terminal and setup python3.2 with “sudo apt-get install python3.2“
- Download the pyserial source - pyserial-2.6.tar.gz
- Decompress it, open a terminal and go to the folder where you have decompressed it.
- Execute “sudo python3.2 setup.py install” or “sudo python3 setup.py install”. I'm not sure which is the correct one, but if you want, you can run both commands.
- Open your blender and open a python console
- Write:
| Code: |
import sys
sys.path.append("/usr/local/lib/python3.2/site-packages/")
import serial |
After running ‘import serial’ you should not get any errors.
Windows (XP-32bit):
- Setup Python33 on C:\Python33
- Decompress it with 7zip on C:\Python33 - You need to have "setup.py" in that folder.
- Run “cmd”, go to C:\Python33 and Execute “python.exe setup.py install”
- Write:
| Code: |
import sys
sys.path.append("C:\Python33\Lib\site-packages")
import serial |
Now you should be able to run:
| Code: |
| arduino = serial.Serial('/dev/ttyACM0', 9600) |
or “COM*” on windows
If you need to write values (example ”a”):
| Code: |
| arduino.write(b'a') # I must add that b before the 'a' |
If you need to read values:
Good luck!
Posted: Thu Feb 28, 2013 5:52 pm
Hah woo! Worked all the way until
| Code: |
I am on windows, and I'm not sure what it is I should be changing to COM*
Also was wondering if I will need to run:
| Code: |
import sys
import serial |
at the beginning of every serial code in order to import serial?
Posted: Thu Feb 28, 2013 6:23 pm
arduino = serial.Serial('COM5', 9600)
Aha, had to close Arduino scripting too, thanks for the assistance mate. It seems to be working properly now !
