Posted: Wed Feb 06, 2013 6:32 pm
My problem is, Blender uses Z for up and I use Y for up, so things get different when I export.
I created a custom exporter, this file format has a matrix for each mesh, the matrix contains all transformations and will just be multiplied with the modelview on OpenGL, so here the great problem comes, the matrix is a little different from how it should be on OpenGL because Blender uses Z for up.
So, there's any way to convert the Blender Matrix to OpenGL matrix? If yes, how?
Posted: Thu Feb 14, 2013 3:14 am
I dont know about opengl world coordinates but I think you just need to swap the y and z coordinates.
I know this sounds too easy but it works. However...
You should note that this converts the coordinate system from blender's right handed system to a left handed system with the z-axis positive direction toward the back camera. If you need to z axis positive coming toward the front-view camera then just negate the z-value (after swapping the axis).
Posted: Fri Mar 08, 2013 9:19 am
Say Blender coords are (X, Y, Z), OpenGL are (X', Y', Z'). Then the coordinate orientations are:
Blender: X to right, Y away from you, Z up.
OpenGL: X' to right, Y' up, Z' towards you.
Therefore:
X' = X
Y' = Z
Z' = -Y
