How to skip non mesh objects?
shagwana
Postby shagwana » Mon Oct 21, 2002 9:37 pm
:oops: Well, im kind of new to this python coding lark so be kind!
Im currently trying to access all selected objects from a pyhton script, like so;
from Blender import *
print "Running..."
#Pull in the selected object information...
Selected_Objects=Object.GetSelected()
Number_Of_Selected_Objects=len(Selected_Objects)
#If the user has selected some objects, get to work ....
if Number_Of_Selected_Objects>0:
   #The user has selected something!
   for Working_Object in Selected_Objects:
      #Scan through each of the objects available, grab the object in question
      #If its a usable type ...
      if Working_Object.data==None:
         print "Axis"+str(Working_Object)
         #<<< problem!?! >>>
else:
   #No work to do, exit!
   print "Nothing selected!."
Now my problem is, how can I tell a non mesh object (Mesh & empty) apart from a curve (and other blender object types)?
When trying to access .data of a curve/surface (for example), I get a python module missing error :(
All I want to be able to so is skip non mesh objects in the selection, any pointers or ideas would be ace :P
chromit
Postby chromit » Wed Oct 23, 2002 8:01 pm
hope this helps, in my version (2.20) it works. dont know why i had to import Blender210. with the Blender namespace it didnt work.
import Blender210
import string
print "Running..."
      if Blender210.isMesh(Working_Object.name):
         print "mesh"
      else:
         print "somethingelse"
else:
chromit
Postby chromit » Wed Oct 23, 2002 8:21 pm
installed 2.25. here you can get the Type with the getType() method.
      print "-- "+Working_Object.getType()
else:
shagwana
Postby shagwana » Thu Oct 24, 2002 3:46 pm
Thanks, the getObject() method helps tons. :)
Return to “Python”
Users browsing this forum: Google [Bot] and 0 guests
