Tuhopuu / Windows (2004/03/09)
nozzy
Postby nozzy » Tue Mar 09, 2004 1:03 pm
This is a old build, check newer posting
Tuhopuu with ODE
tuhopuu-2004-03-09-windows.zip
Some great stuff "Leon", on the particle IPO:
Featurelist:
feature with this build
Check the logs for updates:
logs-march
/nozzy
Gimble
Postby Gimble » Sat Mar 13, 2004 6:26 pm
Hi nozzy.
Thanks for all the compiles.
They've worked very well (up to now :wink: ).
Here's a render with this version:
http://www.telusplanet.net/public/kugye ... h_58_3.jpg
It seems to be the particles I believe that they are causing the problem.
The same file renders fine with the March 5 compile and it also renders fine if the 'Unified Render' button is activated.
Thanks again.
<EDIT>
Hmm, maybe it's not the particles. I deleted all of the particle effects and it is still doing it.
</EDIT>
nozzy
Postby nozzy » Mon Mar 15, 2004 7:43 am
Gimble wrote:It seems to be the particles I believe that they are causing the problem.
Hi Gimble,
I've rendered a few old scenes and I cannot re-create the problem, sorry I cannot help you :(
/nozzy
gabio
Postby gabio » Tue Mar 16, 2004 1:22 am
here is a weird problem, appenning with the render of particles: unified render option on and static particle On.
---------->Blend file
Just press F12.
or if you'r too lazy, here is a quick render for you:
rendered in 2.32, is that a know bug?
leon
Postby leon » Tue Mar 16, 2004 12:29 pm
hi gimble,
my fault I'm afraid! Looks like the "shadow texture map" feature I was playing with is causing the black lines problem. I've removed this until I have time to track down exactly why it's not working right.
I'll update the tuhopuu windows binary in my last post later tonight....
Cheers
Leon
Gimble
Postby Gimble » Wed Mar 17, 2004 5:12 am
Hi Leon (and nozzy):
Thanks for the help I appreciate it.
Really like the new features. Keep them coming :)
Return to “Testing Builds”
