chat icon Mesh creation in Python with 2.25
daddy
Posted: Tue Nov 19, 2002 2:31 am
I'm trying to get started creating meshes in Blender 2.25 using Python. I have been successful creating NMeshes - but that seems to be deprocated.
The example script for the Mesh module in the 2.25 python documentation dies trying to load the "tess" module as mandated by "../modules/utils/tesselation.py" as soon as i get to the m.update() method.
Any suggestions ?
jms
Posted: Tue Nov 19, 2002 11:53 am
Any suggestions ?
Are you using linux version?
There was a problem with this function under win32 systems.
_________________
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
daddy
Posted: Tue Nov 19, 2002 4:14 pm
I was using windows NT4. I will try it on Suse Linux 7.2 when I get home.
Many thanks
daddy
Posted: Wed Nov 20, 2002 3:28 am
No - still not working.
Here are its dying words...
File "mesh.py", line 32, in ?
m.update() # update and triangulate mesh
File "../modules/Blender/Mesh.py", line 203, in update
File "../modules/Blender/Mesh.py", line 69, in toTriangles
File "../modules/utils/tesselation.py", line 11, in ?
ImportError: No module named tess
If I need to set some kind of path, how would I do it ?
Schlops
Posted: Tue Nov 26, 2002 10:35 pm
I have the same problem Sad I don't think it has to do anything with paths, cause every other script runs fine. I can only create a mesh consisting of one triangle. I get this error, when I call update()
_________________
Stay Rude!
daddy
Posted: Tue Nov 26, 2002 10:52 pm
I did succeed in creating a series of vertexes (I haven't tried making faces yet, at least not that kind) I used the code in S68's post "Add material with 2.25API" posted at 6:08 on Tue November 19th in the Python part of the Elysiun forum.
Maybe he has some special magic - he (or she) does not see fit to call update() at all.
Schlops
Posted: Tue Nov 26, 2002 11:15 pm
Thanks, I take a look at it. Creating vertices is no problem for me, I created a lot of them. But adding faces...
_________________
Stay Rude!
theeth
Posted: Wed Nov 27, 2002 3:35 am
as far as I understood it, the update() method should only be called when creating ngons.
here's a little example that creates a plane, inspired by the docstring of the Mesh module (always read the docstrings, they are your best friends)
Code:
import Blender
vlist = []
mesh = Blender.Mesh.New()
vlist.append(mesh.addVert((1.0,1.0,1.0)))
vlist.append(mesh.addVert((-1.0,1.0,1.0)))
vlist.append(mesh.addVert((-1.0,-1.0,-1.0)))
vlist.append(mesh.addVert((1.0,-1.0,-1.0)))
mesh.addFace(vlist)
ob = Blender.Object.New("Mesh")
ob.link(mesh)
Blender.Scene.getCurrent().link(ob)
I hope that's more clear.
_________________
- John Lennon
Schlops
Posted: Wed Nov 27, 2002 5:40 pm
Well, works fine for one face, but try adding more faces. Confused
It seems as Object.link() calls Mesh.update() => Boing Evil or Very Mad
Must be a bug
_________________
Stay Rude!
theeth
Posted: Wed Nov 27, 2002 8:35 pm
you have to use a different list for each face (at list, that's how I understood it)
like this:
Code:
import Blender
face1 = []
face1.append(mesh.addVert((1.0,1.0,1.0)))
face1.append(mesh.addVert((-1.0,1.0,1.0)))
face1.append(mesh.addVert((-1.0,-1.0,-1.0)))
face1.append(mesh.addVert((1.0,-1.0,-1.0)))
mesh.addFace(face1)
face2 = []
face2.append(face1[0])
face2.append(face1[1])
face2.append(mesh.addVert((-1.0,2.0,1.0)))
face2.append(mesh.addVert((1.0,2.0,1.0)))
mesh.addFace(face2)
ob.link(mesh)
_________________
- John Lennon
Schlops
Posted: Fri Nov 29, 2002 1:03 pm
D'oh, I always used the first list (removed the unwanted vertices first) for each new face. But this seems a lot easier. I will give it a try, thanks theeth!
_________________
Stay Rude!
