Help needed - yet another newbie lost
diz
Postby diz » Tue Jan 07, 2003 2:02 am
Hy all! I'm really needing some help, I spent really a lot of time with some trivial-looking problems. So if you could please take some time to have a look at my problem, this would be very appreciated!
:arrow: I'm a complete python beginner, and in order to learn the basics of the blender scripting, I intended to make a simple two-particle system with the particle number 2 being attracted by number 1 (particle 2 tracks particle 1). So here's my code:
from Blender import *
# a simple increment printed in the console for debug purpose
try: test+=1
except: test=0
print test
# if the variables are set output some debug info, else set them
try:
   print bx
   print ax
   print link.loc.x
except:
   print "except"
   bx=ax=link.loc.x
   by=ay=link.loc.y
   bz=az=link.loc.z
# position=position+acceleration/16+speed*0.9
link.loc.x+=(link.track.loc.x-link.loc.x)/16+(link.loc.x-bx)*0.9
link.loc.y+=(link.track.loc.y-link.loc.y)/16+(link.loc.y-by)*0.9
link.loc.z+=(link.track.loc.z-link.loc.z)/16+(link.loc.z-bz)*0.9
# update variables for the next script call
bx=ax
by=ay
bz=az
ax=link.loc.x
ay=link.loc.y
az=link.loc.z
This works in Blender 2.23, and here's an output:
64 # test
-5.84074544907 # bx
-5.66258335114 # ax
-5.66258335114 # link.loc.x
The first very strange thing is that I have to create two variable triplets (a* and b*), because a* is always the same as link.loc.*. Do you have any explaination for this behavior :?:
Second problem, in Blender 2.25 this doesn't work, here's an output again:
0 # test never increments
except # never entering the "try:" code
So my try-except stuff doesn't work, because the global variables don't seem to be preseved from one script call to another... But why :?:
Thank you for having read my problem, and if any of you has any idea or suggestion, please help me. :wink:
Gabriel
theeth
Postby theeth » Tue Jan 07, 2003 5:10 am
diz wrote:So my try-except stuff doesn't work, because the global variables don't seem to be preseved from one script call to another... But why
As far as I understood, In 2.25, the Python interpreter is restarted everytime you run a script, so variables are not preserved.
- John Lennon
diz
Postby diz » Tue Jan 07, 2003 11:26 am
Ok, but that there *must* be a way to preseve a variable between two script calls. Otherwise this would be a *huge* restriction, because it wouldn't even be possible to transfer a variable between two scripts, two frames, ... Well in fact I hope there is a way of doing it... :(
Anyway thanks for the tip, actually the only solution I found was to go on working in Blender 2.23.
Gabriel
Return to “Python”
