| Code: |
#wxBlenderPlayer.py ################################################################################################## # Windows only! Sorry Linux! """wxBlenderPlayer by M.E.Farmer Jr. 2002 This is the begining of a Blender 3D Plug-in ActiveX Control module\widget for wxPython so it can easily be used in your own wxPython programs. Originally written in 2002 it has sat dormant on my hard drive forgotten for a year. When I annonced it on the old website someone asked me if I was trying to make Nan go bankcrupt. Although they said it jokingly I figured I would not release it ... But they did go bankcrupt and it wasn't even my fault! So here it is, hope you find it useful. I have stalled on it and never finished it, so much work left to do.... but I only program in my _spare time_ so bills come first ;) Released to the public 03/2003 M.E.Farmer """ ################################################################################################## # Can view local and internet based .Blend files # # Requirements: # Either: # ActivePython (http://www.activestate.com/Products/ActivePython/) # Or: # Python 2.0 or higher : (http://www.Python.org) # Mark Hammonds win32 extensions (http://starship.python.net/crew/mhammond/) # Also: # wxPython : a cross platform gui toolkit (http://www.wxPython.org) # BlenderPlugin : ActiveX version (http://www.blender.org) # Windows 95 or higher: (http://Microsoft.com) ################################################################################################## #This section is sensitive only change values if you know what your doing. #If you want to tweak things and change up stuff goto the GUI section below. ################################################################################################## # This section created by makepy.py version 0.4.0 # By python version 2.1.1 (#20, Jul 26 2001, 11:38:51) [MSC 32 bit (Intel)] # From type library 'BLENDER3DPLUGIN.OCX' # On Sat May 25 02:52:04 2002 makepy_version = '0.4.0' python_version = 0x20101f0 import win32com.client.CLSIDToClass, pythoncom # The following 3 lines may need tweaking for the particular server # Candidates are pythoncom.Missing and pythoncom.Empty defaultNamedOptArg=pythoncom.Missing defaultNamedNotOptArg=pythoncom.Missing defaultUnnamedArg=pythoncom.Missing CLSID = pythoncom.MakeIID('{B7A2076C-3DD8-4F9D-9D76-5FE71ECC0EF1}') MajorVersion = 1 MinorVersion = 0 LibraryFlags = 10 LCID = 0x0 from win32com.client import DispatchBaseClass class _DBlenderPlayer(DispatchBaseClass): """Dispatch interface for Blender 3D Plug-in Active X Control""" CLSID = pythoncom.MakeIID('{75BE7171-64C0-4125-99A8-1AE50EA49D6C}') def AboutBox(self): return self._oleobj_.InvokeTypes(0xfffffdd8, LCID, 1, (24, 0), (),) def Rewind(self): return self._oleobj_.InvokeTypes(0x8, LCID, 1, (24, 0), (),) def SendMessage(self, to=defaultNamedNotOptArg, From=defaultNamedNotOptArg, subject=defaultNamedNotOptArg, message=defaultNamedNotOptArg): return self._oleobj_.InvokeTypes(0x9, LCID, 1, (11, 0), ((8, 0), (8, 0), (8, 0), (8, 0)), to, From, subject, message) _prop_map_get_ = { "BackColor": (-501, 2, (19, 0), (), "BackColor", None), "ForeColor": (-513, 2, (19, 0), (), "ForeColor", None), "blenderURL": (3, 2, (8, 0), (), "blenderURL", None), "frameRate": (6, 2, (2, 0), (), "frameRate", None), "loadingURL": (5, 2, (8, 0), (), "loadingURL", None), "showFrameCount": (1, 2, (11, 0), (), "showFrameCount", None), "showProfileInfo": (2, 2, (11, 0), (), "showProfileInfo", None), "showProperties": (4, 2, (11, 0), (), "showProperties", None), "useFileBackColor": (7, 2, (11, 0), (), "useFileBackColor", None), } _prop_map_put_ = { "BackColor" : ((-501, LCID, 4, 0),()), "ForeColor" : ((-513, LCID, 4, 0),()), "blenderURL" : ((3, LCID, 4, 0),()), "frameRate" : ((6, LCID, 4, 0),()), "loadingURL" : ((5, LCID, 4, 0),()), "showFrameCount" : ((1, LCID, 4, 0),()), "showProfileInfo" : ((2, LCID, 4, 0),()), "showProperties" : ((4, LCID, 4, 0),()), "useFileBackColor" : ((7, LCID, 4, 0),()), } class _DBlenderPlayerEvents: "Event interface for Blender 3D Plug-in Active X Control" CLSID = CLSID_Sink = pythoncom.MakeIID('{7990FCE5-09A6-4E39-94B6-3E470ED5C22A}') _public_methods_ = [] # For COM Server support _dispid_to_func_ = { } def __init__(self, oobj = None): if oobj is None: self._olecp = None else: import win32com.server.util from win32com.server.policy import EventHandlerPolicy cpc=oobj._oleobj_.QueryInterface(pythoncom.IID_IConnectionPointContainer) cp=cpc.FindConnectionPoint(self.CLSID_Sink) cookie=cp.Advise(win32com.server.util.wrap(self, usePolicy=EventHandlerPolicy)) self._olecp,self._olecp_cookie = cp,cookie def __del__(self): try: self.close() except pythoncom.com_error: pass def close(self): if self._olecp is not None: cp,cookie,self._olecp,self._olecp_cookie = self._olecp,self._olecp_cookie,None,None cp.Unadvise(cookie) def _query_interface_(self, iid): import win32com.server.util if iid==self.CLSID_Sink: return win32com.server.util.wrap(self) # Handlers for the control # If you create handlers, they should have the following prototypes: class CoClassBaseClass: def __init__(self, oobj=None): if oobj is None: oobj = pythoncom.new(self.CLSID) self.__dict__["_dispobj_"] = self.default_interface(oobj) def __repr__(self): return "<win32com.gen_py.%s.%s>" % (__doc__, self.__class__.__name__) def __getattr__(self, attr): d=self.__dict__["_dispobj_"] if d is not None: return getattr(d, attr) raise AttributeError, attr def __setattr__(self, attr, value): if self.__dict__.has_key(attr): self.__dict__[attr] = value; return try: d=self.__dict__["_dispobj_"] if d is not None: d.__setattr__(attr, value) return except AttributeError: pass self.__dict__[attr] = value # This CoClass is known by the name 'BLENDERPLAYER.BlenderPlayerCtrl.1' class BlenderPlayer(CoClassBaseClass): # A CoClass # Blender 3D Plug-in Active X Control CLSID = pythoncom.MakeIID("{5DB05CB8-7751-469D-A1DD-45C8C201C013}") coclass_sources = [ _DBlenderPlayerEvents, ] default_source = _DBlenderPlayerEvents coclass_interfaces = [ _DBlenderPlayer, ] default_interface = _DBlenderPlayer RecordMap = { } CLSIDToClassMap = { '{7990FCE5-09A6-4E39-94B6-3E470ED5C22A}' : _DBlenderPlayerEvents, '{5DB05CB8-7751-469D-A1DD-45C8C201C013}' : BlenderPlayer, '{75BE7171-64C0-4125-99A8-1AE50EA49D6C}' : _DBlenderPlayer, } CLSIDToPackageMap = {} win32com.client.CLSIDToClass.RegisterCLSIDsFromDict( CLSIDToClassMap ) VTablesToPackageMap = {} VTablesToClassMap = { } VTablesNamesToCLSIDMap = { } ###################################################################################### #GUI code for the player.Change at will..... :) ###################################################################################### from wxPython.wx import * from wxPython.lib.activexwrapper import MakeActiveXClass class PlayerPanel(wxWindow): def __init__(self, parent, frame=None): wxWindow.__init__(self, parent, -1, style=wxCLIP_CHILDREN) self.Plug = None self.frame = frame sizer = wxBoxSizer(wxVERTICAL) btnSizer = wxBoxSizer(wxHORIZONTAL) # old sample area No longer exist but left for historical purposes. #http://www.blender3d.com/3DInAction/gallery/plugins/XXXX.blend # new sample area #http://www.blender3d.org/_media/gallery/3dwebplugin/XXXX.blend # If you want to add more or change the list do it here. Location = ['http://www.blender3d.org/_media/gallery/3dwebplugin/Radiosity.blend', 'http://www.blender3d.org/_media/gallery/3dwebplugin/skategirl.blend', 'http://www.blender3d.org/_media/gallery/3dwebplugin/haloparty.blend', 'http://www.blender3d.org/_media/gallery/3dwebplugin/Nevaeh.blend', 'http://www.blender3d.org/_media/gallery/3dwebplugin/SkategirlMovie.blend', 'http://www.blender3d.org/_media/gallery/3dwebplugin/Colorcubes.blend'] # Make a new class that derives from the BlenderPlayer class in the # COM module imported above. This class also derives from wxWindow and # implements the machinery needed to integrate the two worlds. theXClass = MakeActiveXClass(BlenderPlayer, eventObj = self) # Create an instance of that class self.Plug = theXClass(self, -1, style=wxSUNKEN_BORDER) # Code for the buttons on the player btn = wxButton(self, wxNewId(), "About") EVT_BUTTON(self, btn.GetId(), self.OnAboutBox) btnSizer.Add(btn, 0, wxEXPAND|wxALL, 5) btn = wxButton(self, wxNewId(), "Restart") EVT_BUTTON(self, btn.GetId(), self.OnRewind) btnSizer.Add(btn, 0, wxEXPAND|wxALL, 5) btn = wxButton(self, wxNewId(), "Properties") EVT_BUTTON(self, btn.GetId(), self.OnProperties) btnSizer.Add(btn, 0, wxEXPAND|wxALL, 5) txt = wxStaticText(self, -1, "Location:") btnSizer.Add(txt, 0, wxCENTER|wxALL, 5) self.location = wxComboBox(self, wxNewId(), "Select an URL from the drop down list, or type in one here->", wxPoint(-1,-1), wxSize(-1,-1), Location, style=wxCB_DROPDOWN) EVT_COMBOBOX(self, self.location.GetId(), self.OnLocationSelect) EVT_KEY_UP(self.location, self.OnLocationKey) btnSizer.Add(self.location, 1, wxEXPAND|wxALL, 5) #Player layout code. used to position buttons on top #and the activex control in the bottom. sizer.Add(btnSizer, 0, wxEXPAND) sizer.Add(self.Plug, 1, wxEXPAND) self.SetSizer(sizer) self.SetAutoLayout(true) #Sets an event handler for resizing the window when needed EVT_SIZE(self, self.OnSize) def OnSize(self, event): self.Layout() def OnLocationSelect(self, evt): """Gets the location fron the address bar when a selection is made in drop down list, and sends it to the control for loading. """ url = self.location.GetStringSelection() self.Plug.blenderURL = url self.Plug.loadingURL = "" self.Plug.useFileBackColor = 1 def OnLocationKey(self, evt): """Gets the location when entered, appends it to the drop down list, and then sends the URL to the control for loading. Skips if no enter is pressed. """ if evt.KeyCode() == WXK_RETURN: URL = self.location.GetValue() self.location.Append(URL) self.Plug.blenderURL = URL self.Plug.useFileBackColor = 1 self.Plug.loadingURL = "" else: evt.Skip() def OnAboutBox(self,event): """It even says Nan ;)""" self.Plug.AboutBox() def OnRewind(self, event): """Restart.....Rewind""" self.Plug.Rewind() def OnProperties(self, event): """Really just an example of how to do it this function acts like a toggle on or off for the values below""" if self.Plug.showProperties: self.Plug.showProperties = 0 self.Plug.showFrameCount = 0 self.Plug.showProfileInfo = 0 else: self.Plug.showProperties = 1 self.Plug.showFrameCount = 1 #If you want to see it make it eqaul one not zero self.Plug.showProfileInfo = 0 if __name__ == '__main__': #All the top level code is here. class PlayerFrame(wxFrame): def __init__(self): wxFrame.__init__(self, None, -1, "wxBlenderPlayer--by M.E.Farmer Jr.", size=(800, 600), style=wxDEFAULT_FRAME_STYLE|wxNO_FULL_REPAINT_ON_RESIZE) #self.CreateStatusBar() self.tp = PlayerPanel(self) self.SetBackgroundColour(wxBLACK) EVT_CLOSE(self, self.OnCloseWindow) def OnCloseWindow(self, event): self.Destroy() app = wxPySimpleApp() frame = PlayerFrame() frame.Show(true) app.MainLoop() |
