RPM available.
noselasd
RPM available.
Postby noselasd » Wed Oct 16, 2002 12:11 pm
Based on the very good work at http://www.linux.ucla.edu/~phaethon/ble ... oconf.html, and further tweaking,
I made an RPM: http://utelsystems.dyndns.org/apt/redha ... 1.i586.rpm , consists of the binary only. Compiled on and for RedHat 7.3, other may work.
NOS@Utel.no
angelo
Re: RPM available.
Postby angelo » Wed Oct 16, 2002 3:34 pm
noselasd wrote:Based on the very good work at http://www.linux.ucla.edu/~phaethon/ble ... oconf.html, and further tweaking,
NOS@Utel.no
Thanks a lot !! .
Silbert
Postby Silbert » Wed Oct 16, 2002 4:01 pm
Great! I will try your rpm on SuSe 7.3. THX!
JohnMSCLinux
Postby JohnMSCLinux » Wed Oct 16, 2002 7:50 pm
How about the source RPM?
Manuel
Re: RPM available.
Postby Manuel » Thu Oct 17, 2002 12:42 am
NOS@Utel.no
Hi!
I use RH7.3
When I try the boolean, with the W-Key,
Blender crash :
unknow file format
segmentation fault
However thanks, thanks, thanks
without rpm I can't see the 2.25 under Linux (the static
version seg fault and dyn requires python22, a problem
because in RH7.3 Tkinker is based on python1.5,
and remove or update it is difficult)
thanks again,
:D
Manuel
pannomatte
Good Build !
Postby pannomatte » Thu Oct 17, 2002 6:27 am
Worked like a charm, Red Hat 7.3. No game engine........ :cry:
Eric
Re: RPM available.
Postby Eric » Thu Oct 17, 2002 9:22 am
NOS@Utel.no
Hi!
I use RH7.3
Blender crash :
unknow file format
segmentation fault
thanks again,
:D
Manuel
As I understand it, booleans aren't available because of the collision detection thingy that couldn't get into GPL.
noselasd
Postby noselasd » Thu Oct 17, 2002 10:04 am
JohnMSCLinux wrote:How about the source RPM?
It will come when blender builds without tweaks and to much manual
fixups, for now I build the rpm after I have the binary, just so folks
easily can test blender.
Manuel
Re: RPM available.
Postby Manuel » Thu Oct 17, 2002 11:16 pm
NOS@Utel.no
Hi!
I use RH7.3
Blender crash :
unknow file format
segmentation fault
thanks again,
:D
Manuel
The booleans is indipendent from collision:
under binary for win it work fine...
Return to “News & Chat”
