Undo Command????
Hqpsy
Undo Command????
Postby Hqpsy » Tue May 27, 2003 2:40 pm
How to do an undo command? (like ctrl+z in regular windows apps)
I haven't found this thing.. Any ideas?
Little_Cube
Re: Undo Command????
Postby Little_Cube » Tue May 27, 2003 10:49 pm
Hqpsy wrote:How to do an undo command? (like ctrl+z in regular windows apps)
There's no real undo in Blender. The only thing similar to an undo, is the U hotkey which, while you're in Edit mode (TAB) reverts to the state the mesh, surface, etc. was when you entered Edit mode.
Goran
Hqpsy
Postby Hqpsy » Wed May 28, 2003 9:11 am
my worst nightmare has come true.. No Undo!!!!
Jamesk
Postby Jamesk » Wed May 28, 2003 11:14 am
Well, it's not that bad you know. Here's what everybody else does:
* CTRL+W - ENTER (save the current file, takes less than a second)
Then do the stuff you suspect might cause problems.
And, if you indeed got into trouble:
* CTRL+O - ENTER (reverts to last saved version of your file, takes less than a second)
This soon becomes a muscular memory reflex. You will do it without even thinking. In your sleep, your fingers will soon go through these motions all by themselves after a few weeks. This proves you have started to become a Blenderhead. And once the print on your 'W'-key starts to wear off, you will know that you have worked hard enough for the past year.
I've used blender for more than 3 years now, and I actually use this principle in other apps too, even those equipped with a standard undo feature. And it's really good - and more reliable.
Hqpsy
Postby Hqpsy » Wed May 28, 2003 12:20 pm
Hmm.. sounds quite alright..
Thx dude
Jamesk
Postby Jamesk » Wed May 28, 2003 4:41 pm
You're welcome! Indeed.
Homer_S
Postby Homer_S » Thu May 29, 2003 9:13 pm
Jamesk , from someone still learning blender and who makes more mistakes than anyone on the planet,:( THANK YOU. :D
Jamesk
Postby Jamesk » Thu May 29, 2003 11:58 pm
Homer_S: Making mistakes is a good thing. You learn a lot while doing them, and sometimes - not often though - you even come up with something really cool while accidently messing stuff up.
matt_e
Postby matt_e » Fri May 30, 2003 4:15 am
Also, if you go to the user preferences menuy, you can set Blender to save incremental temporary files ever X minutes, so you can revert t oone of those as well. These get saved in the temporary directory in 'File paths'. Also, whenever you quit Blender, a file named quit.blend is saved in the same temporary directory, allowing you to continue where you last left off, even if you forgot to save.
I think it'd be a good idea to write up a document with all of these 'undo workarounds' so they're all together somewhere, so we could just point to it whenever people ask about undo. There's a fair bit of information on elysiun about this topic if you do a search too. Anyone willing to put something together?
ideasman
Postby ideasman » Fri May 30, 2003 10:41 am
I find that duplicating mesh(s) (SHIFT+D) and then moving it to another layer for backup- a good way not to loose things.
Hqpsy
Postby Hqpsy » Fri May 30, 2003 5:20 pm
I hope that someone put in a real undo function into blender sometime..
ylai
Postby ylai » Sat May 31, 2003 12:13 am
Hqpsy wrote:I hope that someone put in a real undo function into blender sometime..
A multi-level undo function in Blender is really not a bad idea. At the moment, I can only help myself by saving into many different "versions" frequently.
Return to “Interface & Tools”
