chat icon Guides for compiling Blender
kestion
Posted: Tue Aug 30, 2011 8:17 pm
The Vimeo actually had the best resolution for me. Thanks.
candre
Posted: Fri Nov 18, 2011 1:51 am
Hi all
im following this guide:
Building x64 targets with Visual C++ 2008 Express:
It's possible to build 64 bit versions of Blender using Visual C++ express from microsoft, and windows 7 x64 editions
http://wiki.blender.org/index.php/Dev:2.5/Doc/Building_Blender/Windows/Visual_C%2B%2B_2008_Express
And then this step:
http://wiki.blender.org/index.php/Dev:2.5/Doc/Building_Blender/Windows/msvc/Scons
This is how to build Blender from its SVN source using Microsoft compiler with Scons. Except if specifically noted you can use the free Microsoft Visual C++ Express instead of the full Microsoft Visual Studio.
I trying to compile using cycles with CUDA so i learn
Building Cycles:
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Building
And about CUDA:
Download the CUDA Toolkit and install, and make sure you have recent enough nvidia drivers (e.g. 270.X or newer)
Everything works fine... no errors... but
when i select cycles > render > display
only can see CPU option
no GPU option... no CUDA
What im doing wrong ?
any help is welcome
user-config.py
WITH_BF_FFMPEG = True
WITH_BF_GAMEENGINE = True
WITH_BF_BULLET = True
WITH_BF_PLAYER = True
WITH_BF_ODE = False
WITH_BF_OPENEXR = True
WITH_BF_FTGL = True
WITH_BF_FMOD = False
WITH_BF_FREETYPE = True
WITH_BF_COLLADA = True
WITH_BF_BOOST = True
WITH_BF_CYCLES = True
WITH_CYCLES_CUDA_BINARIES = True
WITH_BF_DDS = True
WITH_BF_OPENAL = True
WITH_BF_SDL = True
WITH_BF_ICONV = True
WITH_BF_FFTW3 = False
WITH_BUILDINFO = True
WITH_BF_RAYOPTIMIZATION = True
BF_DEBUG = False
BF_NUMJOBS = 5
WITH_BF_OPENMP = False
mcleary
Posted: Mon Jan 07, 2013 1:56 am
candre wrote:
Hi all
And then this step:
Building Cycles:
And about CUDA:
any help is welcome
user-config.py
WITH_BF_ODE = False
WITH_BF_FTGL = True
WITH_BF_DDS = True
WITH_BF_SDL = True
BF_DEBUG = False
BF_NUMJOBS = 5
Open the User Preferences (Ctrl Alt U), go to System and then choose a Device in the Compute Device section. Be sure to select your graphics card.
After this, GPU Compute option will be available in the Render Panel.
_________________
Anyday, anytime, anywhere
Goto page Previous  1, 2, 3, 4, 5, 6, 7
