Add Object actuator, generate with name
colinn
Postby colinn » Sat Jan 28, 2012 3:35 am
Hey, thought I would post my changes to KX_SCA_AddObjectActuator::PyInstantAddObject.
I needed this change to granularly send messages to my dynamically created objects.
KX_SCA_AddObjectActuator.h
KX_PYMETHOD_DOC_VARARGS(KX_SCA_AddObjectActuator,InstantAddObject);
KX_SCA_AddObjectActuator.cpp
PyMethodDef KX_SCA_AddObjectActuator::Methods[] = {
  {"instantAddObject", (PyCFunction) KX_SCA_AddObjectActuator::sPyInstantAddObject, METH_VARARGS,"instantAddObject(name) : immediately add object without delay\n"},
  {NULL,NULL} //Sentinel
PyObject* KX_SCA_AddObjectActuator::PyInstantAddObject(PyObject* args)
    PyObject* pystring;
   char* name = 0;
   if (!PyArg_ParseTuple(args, "s", &name))
      InstantAddObject();
   InstantAddObject(name);
   Py_RETURN_NONE;
void   KX_SCA_AddObjectActuator::InstantAddObject(const char* name)
   if (m_OriginalObject)
      // Add an identical object, with properties inherited from the original object
      // Now it needs to be added to the current scene.
      SCA_IObject* replica = m_scene->AddReplicaObject(m_OriginalObject,GetParent(),m_timeProp );
      KX_GameObject * game_obj = static_cast<KX_GameObject *>(replica);
      game_obj->setLinearVelocity(m_linear_velocity ,m_localLinvFlag);
      game_obj->setAngularVelocity(m_angular_velocity,m_localAngvFlag);
      game_obj->ResolveCombinedVelocities(m_linear_velocity, m_angular_velocity, m_localLinvFlag, m_localAngvFlag);
        // If we have a new name, assign it.
        if(name != 0)
            game_obj->SetName(name);
      // keep a copy of the last object, to allow python scripters to change it
      if (m_lastCreatedObject)
         //Let's not keep a reference to the object: it's bad, if the object is deleted
         //this will force to keep a "zombie" in the game for no good reason.
         //m_scene->DelayedReleaseObject(m_lastCreatedObject);
         //m_lastCreatedObject->Release();
         //Instead we use the registration mechanism
         m_lastCreatedObject->UnregisterActuator(this);
         m_lastCreatedObject = NULL;
      m_lastCreatedObject = replica;
      // no reference
      //m_lastCreatedObject->AddRef();
      // but registration
      m_lastCreatedObject->RegisterActuator(this);
      // finished using replica? then release it
      replica->Release();
Postby stiv » Sat Jan 28, 2012 9:53 pm
If this is generally useful, you might want to create a patch and add it to the patch tracker:
http://wiki.blender.org/index.php/Dev:D ... ss/Patches
colinn
Postby colinn » Tue Jan 31, 2012 7:39 pm
stiv wrote:If this is generally useful, you might want to create a patch and add it to the patch tracker:
Done, thanks for the tip.
Return to “Interactive 3d”
