Posted: Mon Mar 12, 2012 10:48 am
Hi there,
could anyone please tell me when I export my animation it is all blurry/pixelated? I have uploaded an example.
http://youtu.be/8gKGZpKdybw If you could please provide me with some feedback that would be great.
Thanks
Posted: Mon Mar 12, 2012 4:56 pm
That looks like a video that was encoded at a low bitrate.
Posted: Tue Mar 13, 2012 3:08 am
| stiv wrote: |
| That looks like a video that was encoded at a low bitrate. |
I have tried changing the bitrate to 60 frames / sec and it is still like that
Any ideas? or does anyone know of any tutorials I could follow?
Thanks
Posted: Tue Mar 13, 2012 5:06 am
| Quote: |
| I have tried changing the bitrate to 60 frames / sec and it is still like that |
I expect it would be. Frame rate refers to the number of times an image is drawn on the screen. Bit rate refers to how much information is in each frame. (yeah, I'm simplifying) Low bit rate yields fuzzy, blocky images.
Note that the same set of frames can be encoded at different bit rates; usually depending on the end application. DVD video is close to 10 Mbits/sec, while web video is much less.
Posted: Sun Mar 18, 2012 9:15 am
| stiv wrote: |
| Quote: | | I have tried changing the bitrate to 60 frames / sec and it is still like that |
Note that the same set of frames can be encoded at different bit rates; usually depending on the end application. DVD video is close to 10 Mbits/sec, while web video is much less. |
Thanks for clarifying that. I will look at changing the bit rate.
