Setting the bake destination image
trethaller
Postby trethaller » Wed Aug 08, 2012 9:34 pm
Hi there.
I'm trying to set the bake destination image pragmatically to enable batch bake rendering. There was some threads about this, but the working solution is very ugly and not robust:
bpy.data.screens['UV Editing'].areas[1].spaces[0].image = bpy.data.images[key]
So I decided to give it a new try. It turns out that the last image that was unwrapped in the UV/Image editor will always be the target.
Looking at the source, I found that the IMA_USED_FOR_RENDER flag is used to determine which image is used for rendering.
In imagetexture.c:
int imagewraposa(...)
    if (ima) {
        /* hack for icon render */
        if (ima->ibufs.first==NULL && (R.r.scemode & R_NO_IMAGE_LOAD))
            return retval;
        ibuf= BKE_image_get_ibuf(ima, &tex->iuser);
        ima->flag|= IMA_USED_FOR_RENDER;
And IMA_USED_FOR_RENDER is then tested in int RE_bake_shade_all_selected(...).
Do you have any idea how to change this (even incidentally) from Python ? I guess anything would be better than using the screens panels
Or maybe it should be exposed ?
Return to “Python”
