Cycles Render Issue
Termin8
Cycles Render Issue
Postby Termin8 » Fri Sep 14, 2012 12:19 am
Hi all,
Sometimes i try to render a part of my model with Cycles in the viewport and get something like this:
The topology is simple:
I have to reload Blender to fix it.
Is it ok?
Thank you!
muCkk
Postby muCkk » Fri Sep 14, 2012 2:34 am
Hey,
I think I have a similar issue. If I am using Cycles to render my image it gets worse and worse if I use more samples. It doesn't matter if I use the CPU or the GPU. The only lightsource is ambient occlusion.
1 sample:
50 samples:
Termin8
Postby Termin8 » Sat Sep 15, 2012 8:51 pm
That's weird, but i get another issue.
The same scene. The watches base has twomaterials assigned to it. The model is UV Unwrapped, the texture applied to the front digits panel.
The checker texture renders just fine:
If i replace the checker texture with the image everything seems fine in the Textured/Material vewport mode:
However, if i choose Rendered viewport mode it renders something like this:
Please help!
Termin8
Postby Termin8 » Sat Sep 15, 2012 8:53 pm
Ooops! Sorry for the image size, can't find how to fix it
Termin8
Postby Termin8 » Sun Sep 16, 2012 6:17 pm
The issue has been resolved by upgrading to the 2.64 latest test build.
Thanks!
Return to “Rendering”
