object with color "invisible"
tmohr
Postby tmohr » Mon Sep 24, 2012 11:45 pm
i want to place an object A of color / material "invisible" in front of other objects and in the final render i'd like to see alpha=0 at the pixels that show object A.
So object A is in front of other objects that have normal color. A is marked as invisible but you can't see through but if you render a PNG you see a hole in the PNG where A was visible.
I hope it is clear what i want to achieve.
I saw some hints to check the "Sky" checkbox but that did not help.
Thanks for any hints,
Torsten.
CoDEmanX
Postby CoDEmanX » Tue Sep 25, 2012 1:19 pm
Use Transparency, Mask Alpha 0.0 for the invisible material:
http://www.pasteall.org/pic/show.php?id=38131
tmohr
Thanks
Postby tmohr » Tue Sep 25, 2012 10:54 pm
CoDEmanX wrote:Use Transparency, Mask Alpha 0.0 for the invisible material:
Great, exactly what i wanted.
Best regards,
Torsten.
Return to “Rendering”
