[Official 2.64 r51026] Cycles crashes every time
MatejMo
Postby MatejMo » Thu Oct 04, 2012 11:25 am
Hi!
I downloaded the official Blender 2.64 yesterday, but unfortunately rendering with Cycles doesn't work. It crashes every time with:
CUDA error: Invalid value in cuLaunchGrid(cuDisplace, xblocks, 1)
Official 2.64 RC2 works ok though.
My specs:
* Linux Mint 64 bit
* GTX 570 2.5GB
* Nvidia 295.75 drivers
* CUDA toolkit 4.0.17 (with 4.2 is the same problem)
Any suggestions what could be wrong?
Gilgamos
Re: [Official 2.64 r51026] Cycles crashes every time
Postby Gilgamos » Fri Oct 05, 2012 8:00 pm
Unfortunately, I got the same problem today.
- system: Win7 64Bit
- graphics card: Quadro FX4000
Thanks for help.
MatejMo
Postby MatejMo » Mon Oct 08, 2012 9:56 am
Hi.
The solution in my case was to disable Sample as Lamp in the World tab -> Settings panel.
Gilgamos
Postby Gilgamos » Mon Oct 08, 2012 10:45 am
Thanks for your workaround MatejMo - worked for me, too. Hopefully this bug will be fixed quickly, so that "sample as lamp" can still be used in connection with cycles. (I think, it helps a lot to improve Renderquality especially with HDRI-Lighting)
MatejMo
Postby MatejMo » Mon Oct 15, 2012 6:01 pm
This problem was solved in 2.64a, "sample as lamp" does not produce a crash anymore.
But, and this is kinda weird, if I have that option enabled, I hear a "screeching" noise (supposedly coming from my graphic card) every time the render re-starts (ie. I tweak something that causes render re-start).
And it gets even more weird: the noise is louder, the bigger the map resolution is.
Should I be worried? Is Cycles somehow violating my graphic card? :lol:
Has anyone else noticed such behavior?
Postby stiv » Mon Oct 15, 2012 11:27 pm
Noisy fan bearing?
MatejMo
Postby MatejMo » Tue Oct 16, 2012 12:45 pm
stiv wrote:Noisy fan bearing?
No, no way. This noise happens only under the conditions mentioned (2.64a if "sample as lamp" is enabled), I can render in Cycles and Octane for hours, without any fan or other noises. The card is also only two weeks old.
It's a subtle "screeching" "beep" noise, that happens once when render re-start is triggered in Cycles.
I said its was weird :)
Return to “Testing Builds”
