Guides for compiling Blender
kestion
Re: video guide build blender 2.5x
Postby kestion » Tue Aug 30, 2011 9:17 pm
The Vimeo actually had the best resolution for me. Thanks.
candre
win7 x64 build - trunk
Postby candre » Fri Nov 18, 2011 1:51 am
Hi all
im following this guide:
Building x64 targets with Visual C++ 2008 Express:
It's possible to build 64 bit versions of Blender using Visual C++ express from microsoft, and windows 7 x64 editions
http://wiki.blender.org/index.php/Dev:2 ... 08_Express
And then this step:
http://wiki.blender.org/index.php/Dev:2 ... msvc/Scons
This is how to build Blender from its SVN source using Microsoft compiler with Scons. Except if specifically noted you can use the free Microsoft Visual C++ Express instead of the full Microsoft Visual Studio.
I trying to compile using cycles with CUDA so i learn
Building Cycles:
http://wiki.blender.org/index.php/Dev:2 ... s/Building
And about CUDA:
Download the CUDA Toolkit and install, and make sure you have recent enough nvidia drivers (e.g. 270.X or newer)
Everything works fine... no errors... but
when i select cycles > render > display
only can see CPU option
no GPU option... no CUDA
What im doing wrong ?
any help is welcome
user-config.py
WITH_BF_FFMPEG = True
WITH_BF_GAMEENGINE = True
WITH_BF_BULLET = True
WITH_BF_PLAYER = True
WITH_BF_ODE = False
WITH_BF_OPENEXR = True
WITH_BF_FTGL = True
WITH_BF_FMOD = False
WITH_BF_FREETYPE = True
WITH_BF_COLLADA = True
WITH_BF_BOOST = True
WITH_BF_CYCLES = True
WITH_CYCLES_CUDA_BINARIES = True
WITH_BF_DDS = True
WITH_BF_OPENAL = True
WITH_BF_SDL = True
WITH_BF_ICONV = True
WITH_BF_FFTW3 = False
WITH_BUILDINFO = True
WITH_BF_RAYOPTIMIZATION = True
BF_DEBUG = False
BF_NUMJOBS = 5
WITH_BF_OPENMP = False
mcleary
Re: win7 x64 build - trunk
Postby mcleary » Mon Jan 07, 2013 1:56 am
candre wrote:Hi all
And then this step:
Building Cycles:
And about CUDA:
any help is welcome
user-config.py
WITH_BF_ODE = False
WITH_BF_FTGL = True
WITH_BF_DDS = True
WITH_BF_SDL = True
BF_DEBUG = False
BF_NUMJOBS = 5
Open the User Preferences (Ctrl Alt U), go to System and then choose a Device in the Compute Device section. Be sure to select your graphics card.
After this, GPU Compute option will be available in the Render Panel.
Anyday, anytime, anywhere
theugly
Postby theugly » Sun Jul 14, 2013 9:52 am
what does it mean if my graphic card is not listed?
mcleary
Postby mcleary » Sun Jul 14, 2013 4:22 pm
theugly wrote:what does it mean if my graphic card is not listed?
It probably means your GPU doesn't support CUDA.
Which graphics card do you have?
Return to “Coding Blender”
Users browsing this forum: No registered users and 3 guests
