Posted: Wed Dec 19, 2012 1:40 am
Hello, guys
I am pretty new to the blender development. So after downloading the source code via svn and setting up everything as said in the
wiki, I try to build the source but I am getting this error each time at about 13%:
| Code: |
/bin/sh: 1: ../../../../bin/datatoc: Permission denied
make[2]: *** [release/datafiles/startup.blend.c] Error 126
make[1]: *** [source/blender/editors/datafiles/CMakeFiles/bf_editor_datafiles.dir/all] Error 2
make: *** [all] Error 2
01:16:48: The process "/usr/bin/make" exited with code 2.
Error while building/deploying project blender (target: Desktop)
When executing step 'Make'
Same happens with sudo make. I am using Qt creator as my IDE.
I am working on an Ubuntu VM and my code is in an external hd, if it matters.
Any help or hints are welcome.
Posted: Thu Jan 10, 2013 1:08 pm
| jithujose wrote: |
Hello, guys
I am pretty new to the blender development. So after downloading the source code via svn and setting up everything as said in the wiki, I try to build the source but I am getting this error each time at about 13%:
| Code: |
Any help or hints are welcome. |
Did you try to move the code to the local disk?
I had this kind of permission problem once. Even running sudo make, maybe the make executable does not have permission to write on an external disk.
I'm not sure if this can really happen, but I think it worths a try.
_________________
Anyday, anytime, anywhere
Posted: Thu Jan 10, 2013 3:14 pm
I got it working today after copying the source to my hd.
Thank you for your suggestion.
I tried the same thing some days ago and the build was not going beyond the permission issue.
Posted: Thu Jan 10, 2013 5:32 pm
/me guesses: you have the source on a disk partition where you do not have privs to run programs from. Look for the noexec option in the mount command.
