Previous Thread  Next Thread
chat icon Error "Python script error: check console"
Peixe
Posted: Fri Jun 08, 2007 3:54 pm
Hello,
i am new and have for a few minutes downloaded
Blender 2.44 (installer) on a
Computer with Windows XP 32.
When I went to the menu "help" > websites > i.e. blender website > then
comes a message: Error "Python script error: check console".
What is wrong and what do I need???
Is it wrong to think that all what I need is in the Blender package???
What is Phython???
Greetings
Peixe
_________________
Love one another
stiv
Posted: Fri Jun 08, 2007 4:46 pm
Python is Blender's scripting language.
The Blender 2.44 package for Windows is slightly broken and does not install what little Python we normally install for that platform.
Easist fix: go to www.python.org/download
and install Python 2.5.
Peixe
Posted: Fri Jun 08, 2007 5:01 pm
thank you, I have dowloaded it and will try it out.
Greetings
Peixe
_________________
Love one another
pmacd
Posted: Sat Jul 07, 2007 6:18 am
Peixe wrote:
Greetings
Peixe
I had the same problem and solved it. I put up my solution in this forum post. I hope this helps...
http://www.blender.org/forum/viewtopic.php?t=11938
killakanz
Posted: Wed Aug 01, 2007 4:27 pm
Hello.
Can someone who has the power put a note on the Blender download page that you need Python installed for most of Blender to work, and put a link in please?
It will save many newbies a good hour of trying to spot what's wrong and it'll save you guys a lot of these help threads Smile
Cheers.
mranteater
Posted: Thu Aug 23, 2007 11:05 pm
I'm new to Python, but not Blender. I've been trying to use the new "unfolder" script included in 2.44, and I'm getting the same check console error. The console says:
Code:
Compiled with Python version 2.3.5.
Checking for installed Python... got it!
One of the Python modules required can't be found.
No module named decimal
  File "<string>", line 21, in ?
ImportError: No module named decimal
  File "<string>", line 1229, in ?
NameError: name 'xml' is not defined
I'm guessing I need to somehow point blender at these python modules... possilby using the User Preferences... any ideas? Thank you!
stiv
Posted: Fri Aug 24, 2007 6:25 am
Import errors are typically caused by missing Python modules. Bad paths are another reason we will ignore for the moment.
The problem here is the mesh_unfolder script requires the decimal module. The module was introduced in Python 2.4. You are running Python 2.3 which means the script will not work for you.
You have not mentioned which platform you are on. However, installing an updated version of Python from the convenient python.org packages is fairly simple. If you do update Python, you also need a version of Blender that uses that version of Python.
We try to maintain compatibility with Python 2.3 since one of our supported platforms, OSX, is still stuck on 2.3 even though the rest of the world has moved on. ( Current production Python is 2.5. ) In spite of our efforts, compatibility problems do sneak in. One more thing to fix for the Blender 2.45 release!
mranteater
Posted: Fri Aug 24, 2007 6:36 am
thanks! dang, i meant to be thorough on my post... of course forgot to mention, yes, i'm on OS X (10.4.10). Also, I have downloaded Python 2.5 but am not sure how to get Blender to recognize it... It's obviously still linked to 2.3.
I think my answer may lie in this mess http://blenderartists.org/forum/showthread?t=7412
P.S. I was using Blender 2.37 until today and then got 2.44 and then python 2.5[/url]
stiv
Posted: Fri Aug 24, 2007 7:02 am
Blender has an embedded Python interpreter that is built with a specific version of Python. You can tell which one by the "Compiled with Python version x.x" that Blender prints on startup.
This means that to use Python 2.5 you need a version of Blender built with Python 2.5.
You can try and cheat by setting environment variables like PYTHONHOME, but neither you nor Blender will be happy with the result.
mranteater
Posted: Fri Aug 24, 2007 7:13 am
OK. thanks for the tips. much appreciated.
I'm new to environment variables so I'm trying to learn them now (not sure if these are within OS X or Blender right now), but in general on OS X it sounds like I'm out of luck for using python 2.5 (or 2.4 for that matter)... Since blender 2.44 on other platforms is using more recent versions of python I assume the same would be done for OS X if possible.
mranteater
Posted: Fri Aug 24, 2007 7:19 am
... and this is the part where I feel like an idiot for "wasting" about 3 hours today. Just download the version marked
Quote:
Custom Python 2.5 installations:
Blender 2.43, PowerPC, Python 2.5 (9MB): USA | Germany | Australia | NL
below the main version which comes with Python 2.3
Whadayaknow... the unfold script worked like a charm. Thanks for your help.
kontrare
Posted: Thu Oct 18, 2007 1:26 am
Hello all - ive got Python woes too (again Sad )
Slackware 12 -> blender-2.44 -> Python-2.5
Trying to export a model in MD2 format and get:
File "<string>", line 50, in ?
File "/usr/lib/python/struct.py", line 30, in ?
from _struct import Struct, error
ImportError: No module named _struct
Any ideas please?
Have you guys ever thought of forking Python to BlenderPy - lol
Just a quickie too: can i use this account to go onto blenderartists forum?
TIA
kontrare
_________________
have you hugged your wolf today?
jesterKing
Posted: Thu Oct 18, 2007 6:13 am
No, they are seperate.
/Nathan
_________________
Planet Blender | BlenderStorm | #blender.fi | Letwory Interactive
jesterKing
Posted: Thu Oct 18, 2007 6:15 am
Without further investigation, the error message and stack trace leads me to believe your python install is borked. At least struct.py looks like it is from your Python install...
/Nathan
_________________
kontrare
Posted: Thu Oct 18, 2007 11:29 am
/Nathan
Hey JesterKing me an a mate were chattin to you back in the year on the Blender irc about building Blender Wink - thanks for these replies.
Would it do any good if i install a fresh python under my dotBlend say and set the PYTHONHOME & PYTHONPATH to this?
I noticed up the thread after i posted that stiv had said this tho:
Normally i wouldnt be too bothered but i really could do with getting the export stuff working as im trying to help someone out with a few meshes for a game remake. Also i'de like to get the MD2 thing going for me as im playing with some OpenGL code and thats the format its using.
cheers again - kontrare
_________________
Goto page 1, 2, 3  Next
Jump to:
