problem with normals
superted
Postby superted » Fri Apr 11, 2003 12:54 pm
Hello,
I use a python scipt to export 3d datas. Then I import thoses exported datas in my OpenGL/C++ program.
All works great, expect for normals : vertices normals seem to be ALWAYS interpolated between the adjacent faces.
If this is good for a sphere, it isn't for a cube (which is not 'smooth').
Would you know how have the normals such as defined in blender ?
Here is the way I access to the normals :
(for a cube it should print {0,1,-1}, but here it prints {-0.577349185944, 0.577349185944})
Code: Select all
import Blender
import sys
from Blender import Object, NMesh, Mesh, BGL, Draw
select=Object.get()
for ob in select :
   nomMesh=ob.data.name
   mesh=Mesh.get(nomMesh)
   if (mesh!=None) :
      nmesh=NMesh.GetRaw(nomMesh)
      numFace=0
      faces=nmesh.faces
      for face in faces :
         for ver in face.v :
            print ver.no[0]
            print ver.no[1]
            print ver.no[2]
eeshlo
Postby eeshlo » Mon Apr 14, 2003 10:11 pm
You want face normals, not vertex normals, which you have to calculate yourself.
z3r0_d
Postby z3r0_d » Tue Apr 15, 2003 7:21 pm
... calculating them yourself
Code: Select all
def vec_dot(u, v):
   return u[0]*v[0] + u[1]*v[1] + u[2]*v[2]
def vec_cross(u, v):
   #   |   i   j   k   |
   #   |   u0   u1   u2   |
   #   |   v0   v1   v2   |
   # (u1*v2-u2*v1)i - (u0*v2-u2*v0)j + (u0*v1-u1*v0)k
   # (u1*v2-u2*v1)i + (u2*v0-u0*v2)j + (u0*v1-u1*v0)k
   return [u[1]*v[2]-u[2]*v[1], u[2]*v[0]-u[0]*v[2], u[0]*v[1]-u[1]*v[0]]
def vec_mag(u):
   return sqrt(u[0]*u[0] + u[1]*u[1] + u[2]*u[2])
def vec_norm(u):
   n = vec_mag(u)
   return [u[0]/n, u[1]/n, u[2]/n]
def vec_between_points(u, v):
   # returns the vector from point u to point v
   return [v[0]-u[0], v[1]-u[1], v[2]-u[2]]
# thisMesh is a NMesh object
i = 0
while i<len(thisMesh.faces):
   aFace = thisMesh.faces[i]
   norm = vec_norm(vec_cross(vec_between_points(aFace.v[0], aFace.v[1]), vec_between_points(aFace.v[1], aFace.v[2])))
(you may use this code, even though it is from two of my scripts (only one of which has ben released)
oh, I forgot to mention that this works best on triangles as they are planar. On quads one vertex is completely ignored. It may be prefered that you average your normals on a quad
Return to “Python”
