Posted: Sat Apr 19, 2003 10:43 am
ok you guys know the "L" key
how when in edit mode it selects the linked vertex's
well it would be great if there was a combination between the "L" key and the "B" key so that you can select vertex's and then press the "L" key or somthing and have ALL linked vertex's selected
because currently i need to press the "L" key multiple times (e.g hundreds of times) to select multiple seperate groups of vertex's and being able to click and drag that selection would be great.
hope you understand what i mean by that
Alltaken
Posted: Sat Apr 19, 2003 11:03 am
AFAIK You can press L and move your mouse around. No need to press L repeatedly!
Posted: Sat Apr 19, 2003 3:01 pm
when i press the L key it selects ALL linked verts. Are you guys saying it works differently for you?
select adjacent verts is what i would want a 'linked' command to do.
BEAT
Posted: Sat Apr 19, 2003 3:30 pm
I think he means this:
you have an object with lots of separate meshes. You select one vertex on each mesh you want to select and then you hit L-key end you get the other vertices selected.. no?
Dani
Posted: Sat Apr 19, 2003 7:48 pm
| Dani wrote: |
Dani |
do you really i must go check!!!!!!!
Posted: Sat Apr 19, 2003 8:02 pm
na it doesn't work.
ok this is the deal i have a geodesic dome made up of individual tubes (for the edges)
each one is a seperate CLOSED MESH
but they are all joined together as a single OBJECT!!!!
now if i want to select HALF of them i can't just click and drag on half of them because i will not get some of the vertex's that are at one end of the tubes see included picture.
the thing i WANT to be able to do is select whatever verts i want to then afterwards press some kind of button ONCE to select all linked verts.
right now if i wanted to select the other end of all those meshs i would have to press the "L" key about 200 times
i know this becasue i did it earlier and it was why i chose to post here.
i hope you understand my request now.
p.s each of those sides is a seperate mesh.
Alltaken
is there already a way to do this??
coz if there is i apologise for wasting time!!!
Posted: Sun Apr 20, 2003 5:23 am
why can't you select less than half, then use the l key to select the other ends of the parts you want.
almost offtopic:
does anybody here consider using materials to store selections?
Posted: Sun Apr 20, 2003 8:59 am
i dunno why!!!!!!!!
thats what i am asking for!!
coz it doesn't work like that for me!
Posted: Thu Apr 24, 2003 10:07 am
I believe if you press ctrl-L it will select all verticies connected to those already selected. So you could select a bunch with B and then hit ctrl-L to get all the ones connected to them. I know this works in at least 2.26
Posted: Thu Apr 24, 2003 11:41 am
hey thanks man that is the exact thing i wanted.
i'm glad its already been done.
no need to impliment it now coz its already there.
Alltaken
