Previous Thread  Next Thread
chat icon Can someone help with OBJ export script?
ghoulish
Posted: Wed Apr 30, 2003 9:08 pm
Hello - I have come across this OBJ export script from sourceforge:
http://sourceforge.net/projects/blenderobjex/
It does not work with Blender 2.26 for Windows. Can somebody get this to work with Blender 2.26 on Windows? I dont understand Python or scripting. What im after is to be able to export mesh, texture, and material data, and this script is supposed to do that. - Thank you.
Here is the contents of the script:
# $Id: blenderobjex.py,v 1.3 2002/02/02 11:41:55 rid Exp $
# blenderobjex - Blender Alias/Wavefront OBJ-File exporter
# Copyright (C) 2001-2002 Christoph Frick <rid@zefix.tv>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
import Blender210 as Blender
import GUI
import sys, os
def export( filename ):
scene = Blender.getCurrentScene();
objfile = open( filename+".obj", "w" );
mtlfile = open( filename+".mtl", "w" );
bfilename = os.path.basename(filename)
mapfile = open( filename+".map", "w" );
objfile.write( "# \n" );
objfile.write( "mtllib "+bfilename+".mtl\n");
objfile.write( "maplib "+bfilename+".map\n");
mtllib = {};
vs = {};
vns = {};
vts = {};
mats = {};
maps = {};
s_count = 1;
t_count = 1;
n_count = 1;
for name in scene.objects:
if Blender.isMesh( name ):
meshobj = Blender.getObject( name );
mesh = Blender.getMesh( meshobj.data );
for vertex in mesh.vertices:
v = "v %f %f %f" % (vertex[0],vertex[1],vertex[2]);
if not vs.has_key(v):
vs[v] = s_count;
s_count = s_count + 1;
objfile.write( v + "\n" );
for normal in mesh.normals:
vn = "vn %f %f %f" % (normal[0],normal[1],normal[2]);
if not vns.has_key(vn):
vns[vn] = n_count;
n_count = n_count +1;
objfile.write( vn + "\n" );
for texcoord in mesh.texcoords:
for tc in texcoord:
vt = "vt %f %f" % (tc[0],tc[1]);
if not vts.has_key(vt):
vts[vt] = t_count;
t_count = t_count +1;
objfile.write( vt + "\n" );
for material_name in meshobj.materials:
if not mats.has_key( material_name ):
material = Blender.getMaterial( material_name );
mtlfile.write( "newmtl %s\n" % (material_name) );
mtlfile.write( "Ka %f %f %f\n" % (material.Amb,material.Amb,material.Amb) );
mtlfile.write( "Kd %f %f %f\n" % (material.R,material.G,material.B) );
mtlfile.write( "Ks %f %f %f\n" % (material.SpecR,material.SpecG,material.SpecB) );
mtlfile.write( "Ns %f\n" % (material.Spec) );
mtlfile.write( "\n" );
mats[ material_name ] = 1;
if mesh.texture:
bmapname = os.path.basename(mesh.texture);
maps[ mesh.texture ] = bmapname;
mapfile.write( "newmap %s\nKa %s\n\n" % (bmapname,bmapname) );
lastmat = "";
lastsmooth = -1;
facecount = 0;
if ( mesh.texture ):
objfile.write("usemap %s\n" % (maps[mesh.texture]) );
for face in mesh.faces:
if face[4] != lastsmooth:
objfile.write( "s %i\n" % face[4] );
lastsmooth = face[4];
if len(meshobj.materials) > 0 and lastmat != meshobj.materials[face[5]]:
lastmat = meshobj.materials[face[5]]
objfile.write( "usemtl %s\n"%(lastmat) );
objfile.write( "f " );
for i in range(4):
if i!=3 or face[3]:
x = "";
v = "v %f %f %f" % (mesh.vertices[face[i]][0],mesh.vertices[face[i]][1], mesh.vertices[face[i]][2]);
x = x + "%i/" % (vs[v]);
if len(mesh.texcoords):
tc = mesh.texcoords[facecount][i];
x = x + "%d"%(vts[vt]);
x = x + "/";
vn = "vn %f %f %f" % (mesh.normals[face[i]][0],mesh.normals[face[i]][1], mesh.normals[face[i]][2]);
x = x + "%i"%(vns[vn]);
x = x + " ";
objfile.write( x );
objfile.write( "\n" );
facecount = facecount+1;
def callback(fs):
export(fs.filename)
fs = GUI.FileSelector()
fs.activate(callback, fs)
Michel
Posted: Thu May 01, 2003 7:57 am
import GUI
the Blender210 and GUI modules are not included in Blender 2.26. You'll have to use prior versions of Blender for that.
both modules will probably never return Twisted Evil . The fileselector from the GUI module will probably return in some other form.
With regards,
Michel
ghoulish
Posted: Thu May 01, 2003 4:08 pm
What are "GUI modules", and how can this script be modified to be used wint Blender 2.26? What is "fileselector from the GUI module"? Is it possible to put back into Blender 2.26 "GUI modules"?
z3r0_d
Posted: Fri May 02, 2003 5:07 am
Graphical User Interface
they do things like buttons, and textinputs.
I would look for what values the necescary ui items return, and set them to hard coded values, as a hack.
but I know python
(I could suggest how to change the script if you put it into code block when you posted so that the indentation would be saved[code]...[removme/code])
it is a lot like the open and save windows
----------------------edit----------------------
I now see a link to the sourceforge page
am too lazy to extact a tar.gz to try to update it
why not use an older version of blender? 2.23 should work.
is on pablosbrain
http://www.pablosbrain.com/blender3d/files/
ghoulish
Posted: Fri May 02, 2003 3:43 pm
Thanks for you reply z3r0_d, but your talking way over my head. I dont konw the first thing about programming, scripting, file extensions, GUI modules or anything related. All i know to do is make pictures, and shapes. What im after here is to be able to take a shape i made in Blender (with UV textures added) and export it to be used elsewhere.
z3r0_d
Posted: Sat May 03, 2003 7:40 pm
I am (again) too lazy to fix it, but I would suggest you try it in Blender 2.23, not 2.25 or 2.26.
Jump to:
