Background Image and Video background do not work in 2.48
mrbabinga
Postby mrbabinga » Fri Oct 17, 2008 4:56 am
I am unable to use a background image or video background in version 2.48.
Works just fine in 2.44, so I know that I am doing it correctly.
Any help would be appreciated.
William
System info is:
= Blender 2.48 System Information =
Built on 2008-10-14 10:49:16, Rev-17080M Version linux2 dynamic
Platform: linux2
Python:
- Version: 2.5.1 (r251:54863, Jul 31 2008, 23:20:23)
[GCC 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)]
- Paths:
/home/william/blender2_48
/usr/lib/python25.zip
/usr/lib/python2.5
/usr/lib/python2.5/plat-linux2
/usr/lib/python2.5/lib-tk
/usr/lib/python2.5/lib-dynload
/usr/local/lib/python2.5/site-packages
/usr/lib/python2.5/site-packages
/usr/lib/python2.5/site-packages/Numeric
/usr/lib/python2.5/site-packages/gst-0.10
/var/lib/python-support/python2.5
/usr/lib/python2.5/site-packages/gtk-2.0
/var/lib/python-support/python2.5/gtk-2.0
/home/william/blender2_48/.blender/scripts
/home/william/blender2_48/.blender/scripts/bpymodules
- Directories:
Blender home dir:
Default dir for scripts:
Default "bpydata/" data dir for scripts:
/home/william/blender2_48/.blender/scripts/bpydata
User defined dir for scripts:
<NOTICE> -- not found
Data dir "bpydata/" inside user defined dir:
Default config data "bpydata/config/" dir:
/home/william/blender2_48/.blender/scripts/bpydata/config
- Modules: all basic ones were found.
OpenGL:
- Renderer: GeForce4 MX Integrated GPU/AGP/SSE/3DNOW!
- Vendor: NVIDIA Corporation
- Version: 1.5.8 NVIDIA 96.39
- Extensions:
GL_ARB_imaging GL_ARB_multitexture GL_ARB_pixel_buffer_object
GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects
GL_ARB_shading_language_100 GL_ARB_texture_compression
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle
GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object
GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos
GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra
GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract
GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_Cg_shader
GL_EXT_draw_range_elements GL_EXT_fog_coord
GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels GL_EXT_paletted_texture
GL_EXT_pixel_buffer_object GL_EXT_point_parameters
GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shared_texture_palette
GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod
GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array
GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region GL_NV_blend_square GL_NV_fence GL_NV_fog_distance
GL_NV_light_max_exponent GL_NV_packed_depth_stencil
GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners
GL_NV_texgen_reflection GL_NV_texture_env_combine4
GL_NV_texture_rectangle GL_NV_vertex_array_range
GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1
GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod
GL_SUN_slice_accum
- Simplistic almost useless benchmark:
Redrawing all areas 10 times took 0.2381 seconds.
(*) Found 2 notices, documented in the text above.
Return to “Coding Blender”
