DirectX8Exporter bug with Armatures
wyrmmage
Postby wyrmmage » Tue Dec 09, 2008 4:53 am
Hello :) This is my first post here, so please forgive me if I make any dumb mistakes XD
Anyway: I think I've discovered a bug in the DirectX8Exporter found in Blender V2.48a
I have an armature and a bone and then another bone extruded from that first bone (we'll call them boneOne and boneTwo). I then have two cubes; one cube is parented to boneOne and has all of its vertices assigned to boneOne, the other cube is likewise parented and assigned to boneTwo. Now, when I export my creation, the bones are only applied to boneOne, but not boneTwo :\
In my model I have quite a few more bones and meshes than in the above example, but the idea is the same. Here is the resulting .x file I get when I've exported my object (I've replaced stuff that's not really relevant with '...'):
xof 0303txt 0032
template VertexDuplicationIndices {
 <b8d65549-d7c9-4995-89cf-53a9a8b031e3>
 DWORD nIndices;
 DWORD nOriginalVertices;
 array DWORD indices[nIndices];
template XSkinMeshHeader {
 <3cf169ce-ff7c-44ab-93c0-f78f62d172e2>
 WORD nMaxSkinWeightsPerVertex;
 WORD nMaxSkinWeightsPerFace;
 WORD nBones;
template SkinWeights {
 <6f0d123b-bad2-4167-a0d0-80224f25fabb>
 STRING transformNodeName;
 DWORD nWeights;
 array DWORD vertexIndices[nWeights];
 array float weights[nWeights];
 Matrix4x4 matrixOffset;
Frame RootFrame {
  FrameTransformMatrix {...}
    Frame spineBone {
      Frame rightCollarBone {
        Frame rightShoulderBone {
          Frame rightArmBone {
            Frame rightGunBone {
      Frame leftCollarBone {
        Frame leftShoulderBone {
          Frame leftArmBone {
            Frame leftGunBone {
      Frame rightHipBone {
        Frame rightLegBone {
      Frame leftHipBone {
        Frame leftLegBone {
      Frame cameraFPSBone {
  }  // End of the Bone spineBone
      Frame cameraFPS {
Mesh {
  MeshMaterialList {...}  //End of MeshMaterialList
  MeshNormals {...}  //End of MeshNormals
  XSkinMeshHeader {
    1;
    3;
    14;
  SkinWeights {
    "cameraFPSBone";
     36;
    1,
    18,
    30,
    33,
    12,
    20,
    23,
    31,
    6,
    9,
    14,
    17,
    32,
    34,
    2,
    4,
    11,
    35,
    0,
    3,
    19,
    21,
    24,
    13,
    15,
    22,
    26,
    29,
    7,
    16,
    28,
    5,
    8,
    10,
    25,
    27;
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000,
    1.000000;
          1.000000,0.000000,-0.000000,0.000000,
          -0.000000,-0.999800,-0.022300,0.000000,
          -0.000000,0.022300,-0.999800,0.000000,
          0.000000,0.034300,0.769700,1.000000;;
  } // End of XSkinMeshHeader
  }  // End of the Object cameraFPS
      Frame rightGun {
Mesh {
  }  // End of the Mesh rightGun
      Frame leftGun {
        FrameTransformMatrix ...}
Mesh {...}  // End of the Mesh leftGun
      Frame leftArm {
Mesh {...}  // End of the Mesh leftArm
      Frame rightArm {
Mesh {...}  // End of the Mesh rightArm
      Frame leftShoulder {
Mesh {...}  // End of the Mesh leftShoulder
      Frame rightShoulder {
Mesh {...}  // End of the Mesh rightShoulder
      Frame leftLeg {
Mesh {...}  // End of the Mesh leftLeg
      Frame rightLeg {
Mesh {...}  // End of the Mesh rightLeg
      Frame spine {
Mesh {...}  // End of the Mesh spine
}  // End of the Root Frame
As you can see, both an XSkinMeshHeader and a SkinWeights structure are present under the definition of the Mesh of cameraFPS, but neither of these exist under the definition of the Mesh of rightGun :\
If you'd like to download the blend file I'm using, you can find it here. I'll try and look into this and see if I can fix it, but I've already been trying for a couple of days without much success, so if someone else could come up with a patch, that would be great too ^_^
-wyrmmage
wyrmmage
Postby wyrmmage » Wed Dec 10, 2008 3:57 am
Well, that was more simple than I would have thought :)
Below is the svn patch for DirectX8Exporter.py:
Index: DirectX8Exporter.py
--- DirectX8Exporter.py   (revision 17767)
+++ DirectX8Exporter.py   (working copy)
@@ -319,10 +319,12 @@
       obs = Blender.Scene.GetCurrent().objects
       return [ ob for ob in obs if ob.parent == obj ]
-   def getArmChildren(self,obj):
+   def getArmChildren(self,obj):
+      resultingObjects = []
       for ob in Blender.Scene.GetCurrent().objects: #Object.Get():
-         if ob.parent == obj :
-            return ob
+         if ob.parent == obj:
+            resultingObjects.append(ob)
+      return resultingObjects
    def getLocMat(self, obj):
       pare = obj.parent
@@ -348,7 +350,7 @@
       if type(mesh) == Types.ArmatureType :
          Child_obj = self.getArmChildren(obj)
          chld_obj = obj
-         ch_list.append(Child_obj)
+         ch_list += Child_obj
          self.writeRootBone(obj, Child_obj)
       if obj.type == 'Mesh' and obj not in ch_list:
          self.exportMesh(obj)
@@ -399,7 +401,7 @@
             if ch and ch.type == "Armature":
                ch_list.append(ch)
                self.writeObjFrames(ch)
-            else :
+            else :
                self.writeChildObj(ch_l)
          if obj.type != "Armature":
             self.file.write("  }  // SI End of the Object %s \n" % (obj.name))
@@ -483,16 +485,17 @@
    #Export Mesh with Armature
    def exportMeshArm(self,arm,arm_ob,ch_obj):
-      tex = []
-      mesh = ch_obj.getData()
-      self.writeTextures(ch_obj, tex)
-      self.writeMeshcoordArm(ch_obj ,arm_ob)
-      self.writeMeshMaterialList(ch_obj, mesh, tex)
-      self.writeMeshNormals(ch_obj, mesh)
-      self.writeMeshTextureCoords(ch_obj, mesh)
-      self.writeSkinWeights(arm,mesh)
-      #self.file.write("  }  // End of the Frame %s \n" % (ch_obj.name))
-      self.file.write("  }  // End of the Object %s \n" % (ch_obj.name))
+      for co in ch_obj:
+         tex = []
+         mesh = co.getData()
+         self.writeTextures(co, tex)
+         self.writeMeshcoordArm(co, arm_ob)
+         self.writeMeshMaterialList(co, mesh, tex)
+         self.writeMeshNormals(co, mesh)
+         self.writeMeshTextureCoords(co, mesh)
+         self.writeSkinWeights(arm,mesh)
+         #self.file.write("  }  // End of the Frame %s \n" % (ch_obj.name))
+         self.file.write("  }  // End of the Object %s \n" % (co.name))
    #Export Root Bone
Any chance of this making it into the next Blender release? Do I need to submit the patch anywhere?
-wyrmmage
Postby stiv » Wed Dec 10, 2008 5:02 am
Best thing to do is submit the patch to the patch tracker at
https://projects.blender.org/tracker/?a ... unc=browse
You will need to create an account.
Here is an general info page on patches.
http://www.blender.org/development/submit-a-patch/
wyrmmage
Postby wyrmmage » Wed Dec 10, 2008 5:37 am
stiv wrote:Best thing to do is submit the patch to the patch tracker at
I've posted the patch to the tracker.
Thanks for the help :)
Return to “Coding Blender”
