Getting rid of unwanted default plugin
malcolmst
Postby malcolmst » Fri Oct 18, 2002 6:58 am
A while ago, I installed a 3D head creator plug-in for blender (I put it on when I had 2.23). It divided the entire window in two (not just the main part) with the python window which seems to be impossible to get rid of. This loads every time blender starts, and even though I have deleted the file and re-installed blender as well as putting on the new version, it will not go away.
I had to create a default blend file to load with the link to (temporarily) make the screen normal again. Does anyone know how I can get rid of this plug-in? Thanks in advance.
--Malcolm
Caronte
Postby Caronte » Fri Oct 18, 2002 2:58 pm
Chosse the .blend you like the interface and press Ctrl U, next time you load Blender you will see this interface.
P.S: Is better if you use www.elisyun.com to post messages like this one.
malcolmst
Postby malcolmst » Fri Oct 18, 2002 10:51 pm
:D Thank you very much! It works fine now. I never knew what Ctrl+U had done before...
Return to “Interface & Tools”
