Previous Thread  Next Thread
chat icon property problem
mbibim
Posted: Tue May 20, 2003 5:42 pm
Hello
I've posted this problem a month ago but no solution was found. So i ask this question again :
i'm working under blender 2.25 and i use python, but i can't access the value of my object's property (define in Real time button).
I've tried many python script but no solution. I think it should start like this:
import GameLogic
ow = GameLogic.getCurrentController().getOwner()
print ow.pousse ("pousse" is the name of the property)
but it doesn't work.
Please help me 'cause i really need to solve my problem.
thanks a lot.
biČ
verence
Posted: Wed May 21, 2003 11:38 am
hi,
do you get an attribute error? maybe the property name does not match (but i do not think so). first, use a
Code:
print dir(ow)
to find out if your object really has this property. second use
Code:
if hasattr(ow, "pousse"):
    print ow.pousse
because it could be that the object is not 'prepared'.
you should also keep in mind that property names are case sensitive.
hope that helps
[/code]
mbibim
Posted: Fri May 23, 2003 9:26 am
hy
thanx for your help. I've tried you suggestion with my camera which has a property (created in the real times button) called "perso". I wrota that :
from Blender import *
ow = Object.Get("Camera")
if hasattr(ow, "perso"):
print ow.perso
but the property wasn"t found . So that is not the solution to get a property. Probably i have to change the second line of my code. But how can I get my object in python in order to access his properties ???
thanx
biČ
verence
Posted: Fri May 23, 2003 12:05 pm
mbibim wrote:
hy
print ow.perso
biČ
Object.Get won't work to access properties. you need to fetch your object via
ow = controller.getOwner()
i do this a lot to display text via ow.Text = "hallo".
but i will have a look at it when i'm home.
greets
Jump to:
