APT-able debian packages
jochym
Postby jochym » Fri Oct 18, 2002 3:23 pm
Based on the excelent work of phaethon I've created
apt-able debian packages for woody and sid distributions.
Just add:
deb http://rozeta.com.pl/blender/debian/ woody/
or
deb http://rozeta.com.pl/blender/debian/ sid/
to your /etc/apt/sources.list
then:
apt-get update ; apt-get install blender-creator-ph
and you have blender installed.
The binary name is blendercreator-ph
Have fun! :)
AlanGordie
Re: APT-able debian packages
Postby AlanGordie » Fri Oct 18, 2002 5:18 pm
jochym wrote:Hi,
Incredible! The binary works great! Thanks a lot guys! :D
Do you guys happen to know if/when Phaethon's autoconf contribs will will make it into CVS?
Hos
Postby Hos » Sat Oct 19, 2002 11:07 pm
jochym wrote:Based on the excelent work of phaethon I've created
I haven't tried your packages yet, but I think this is a great idea!
Have you checked out the mplayer CVS source? One thing that
is very cool about it is that it has a debian directory so after you
check out the sources you can "fakeroot debian/rules binary"
and it will configure and build a debian package for you directly
from the fresh CVS sources.
I would very much like to see something like that for the blender
CVS tree.
Regards,
Chris
jochym
Postby jochym » Sun Oct 20, 2002 12:52 am
CVS tree.
I'll try to submit appropriate patches of this type as soon as regular
development starts.
P.
Unreality
Postby Unreality » Sun Oct 20, 2002 4:44 pm
I just get error message: E: Malformed line 5 in source list /etc/apt/sources.list (dist) :cry:
Hos
Postby Hos » Sun Oct 20, 2002 5:03 pm
Unreality wrote:I just get error message: E: Malformed line 5 in source list /etc/apt/sources.list (dist) :cry:
... and what does line 5 of your /etc/apt/sources.list look like?
Chris
Unreality
Postby Unreality » Sun Oct 20, 2002 6:39 pm
Hos wrote:... and what does line 5 of your /etc/apt/sources.list look like?
jochym
Postby jochym » Sun Oct 20, 2002 7:19 pm
Check it carefully. It should work like this
It works on both my woody and sid systems.
P.
xitnalta
Postby xitnalta » Sun Oct 20, 2002 7:56 pm
Unreality: Two possible reasons come to my mind:
1. Do you really have Debian "woody" (3.0, aka "stable")? The testing dist is called "sarge" (I think), so you have to look which one of "woody" or "sid" works better, and the unstable dist is "sid". If you still have potato (Debian 2.2), you probably shouldn't use Blender yet. ;)
2. If this is the last line in the file - does it end with a newline ('\n') or just with the end of file? Certain tools are (still) a bit picky about the last line not ending with a newline.
Felix
Hos
Postby Hos » Mon Oct 21, 2002 3:16 am
I just copy and pasted your line into my sources.list and
it work just fine. Maybe try posting the rest of the file?
Chris
Unreality
Postby Unreality » Mon Oct 21, 2002 2:37 pm
I tried sid and it worked! :D
heffel
Postby heffel » Tue Oct 22, 2002 4:15 pm
I got the Sid version as well, it installed without any problems.
I was pleasantly surprised when I ran the executable and saw that I could resize the blender main window (I was never able to resize the window of the "standard" blender in Sid, it was always maximized).
I noticed the 7, 1 and 3 keys on the number pad were not working.
Kind of bummed I went back to the "standard", always maximized Blender, since I cannot do much if I can't change the view.
Heffel
Hos
Postby Hos » Tue Oct 22, 2002 8:07 pm
heffel wrote:I was pleasantly surprised when I ran the executable and saw that I could resize the blender main window (I was never able to resize the window of the "standard" blender in Sid, it was always maximized).
This is actually really bad, because the NaN developers forgot to register WM_CLASS
for the application so you are stuck with a non-maximized window for all UNIX versions.
If you want to override this you need a window manager like sawfish that'll allow you
to set attributes for windows with no WM_CLASS. (windowmaker, which is what
I use, doesn't do that.)
You can resize old standard blender too -- for example, launch it with:
blender -w -p 5 5 800 600
Type "blender -h" for more tricks.
Chris
heffel
Postby heffel » Wed Oct 23, 2002 12:53 am
Chris[/quote]
Cool!
Thanks for the tip.
Heffel
zola
Postby zola » Wed Oct 23, 2002 12:56 am
I use Enlightenment and run Blender full-screen on one desktop which I can switch to and from with a hot-key. Enlightenment remembers window settings for applications if you want it to so you don't even need any special command-line options.
Return to “News & Chat”
