Mac OS X 10.4.11 won't open Blender 2.49
pancreasboy
Postby pancreasboy » Fri Jun 05, 2009 4:25 am
Is anyone else not able to open the new Blender on a mac with a similar configuration to me? How on a mac can I see if it's crashing at some point in it's start up?
Thanks in advance.
stiv
Postby stiv » Fri Jun 05, 2009 7:10 am
Run blender from the command line.
I suspect problems with Python versions.
pancreasboy
Postby pancreasboy » Fri Jun 05, 2009 7:38 am
Sorry I'm more a designer than a programmer guy.
How do I run it from the command line? And sorry where is the command line?
Sorry for my lack of coding skills.
SirDude
Postby SirDude » Fri Jun 05, 2009 4:28 pm
Open up a terminal
/Applications/Utilities/Terminal.app
Then if you have blender installed as say
/users/mein/blender2.49/blender.app
type
/users/mein/blender2.49/blender.app/Contents/MacOS/blender
pancreasboy
Postby pancreasboy » Thu Jun 11, 2009 1:51 am
ok i tried that and got this
Last login: Thu Jun 11 08:50:05 on console
Welcome to Darwin!
mein-computer:~ mein$ /users/mein/blender2.49/blender.app/Contents/MacOS/blender
dyld: Library not loaded: /Library/Frameworks/Python.framework/Versions/2.5/Python
Referenced from: /users/mein/blender2.49/blender.app/Contents/MacOS/blender
Reason: image not found
Trace/BPT trap
(where "mein" is obviously substituted for my real name)
kittrick
I was having the same problem
Postby kittrick » Thu Jun 11, 2009 4:44 am
You need to install Python for blender to work.
http://www.python.org/download/releases/2.5.4/
I tried installing a newer version, but blender is specifically requesting 2.5
After I installed python blender worked beautifully.
pancreasboy
Postby pancreasboy » Thu Jun 11, 2009 7:43 am
sweet thanks kittrick,
that was the ticket
hhassey
Re: I was having the same problem
Postby hhassey » Fri Aug 07, 2009 5:27 am
kittrick wrote:You need to install Python for blender to work.
I installed Python 2.5.4 but still noting.
Also I tried to start blender form the terminal and got with cd all the way before blender
but never worked.
Can anyone help me?
My blender 2.48 works fine.
mcgheel
Postby mcgheel » Wed Jan 27, 2010 9:04 am
I am also having issues opening blender on my Mac 10.4.11.
I get the blender.app file and double click....the icon looks as though it opened but nothing appears.
I downloaded both Python 3.1.1 and 2.5.4 but still nothing is working.
Above it says that Blender 2.48 works fine. Is this version still available.
Does anyone have any other suggestions???
Thanks
jms
Postby jms » Wed Jan 27, 2010 11:23 am
pancreasboy wrote:ok i tried that and got this
Welcome to Darwin!
Trace/BPT trap
Is there a reason why you did not download the intel mac version for OSX 10.4 and python 2.3 available on blender.org ?
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
mcgheel
Postby mcgheel » Wed Jan 27, 2010 6:23 pm
The USA version was blocked out so......I downloaded the German version though and it worked... Thanks!
SirDude
Postby SirDude » Wed Jan 27, 2010 8:52 pm
I fixed the link.
Thanks
jms
Postby jms » Fri Feb 12, 2010 3:25 pm
onthis site the last stable revision, 23612, a sort of blender 2.49c, is available.
Da2mangame
Mac Blender 2.49 Flashy Glitchy problem
Postby Da2mangame » Tue Feb 23, 2010 7:50 pm
Hi everyone. I have a Macbook 2 GHz intel core duo processor with 2 GB 667 MHz DDr2 SDRAM. i have downloaded blender-2.49b-OSX-10.5-py2.5-intel and Python 2.6.4 . when i open Blender it will open like i believe i should. when i try to do something as simple as delete the first object (the cube), then move the cursor around and or add a new object the original cube that had been deleted will flashily reappear. and it will do this for i believe EVERYTHING. can someone tell me what to do. it's very annoying.
i found another problem. when i save as, enter name, then click save as it says
2/23/10 2:24:05 PM [0x0-0x21d21d].org.blenderfoundation.blender[4001] <memory2>/: No such file or directory
jms
Re: Mac Blender 2.49 Flashy Glitchy problem
Postby jms » Thu Feb 25, 2010 3:03 pm
Da2mangame wrote: ...can someone tell me what to do. it's very annoying. i found another problem. when i save as, enter name, then click save as it says 2/23/10 2:24:05 PM [0x0-0x21d21d].org.blenderfoundation.blender[4001] <memory2>/: No such file or directory
As the python 2.3 is the version released with the macbook operating system, you should use blender-2.49b-OSX-10.4-py2.3-intel version.
Return to “Testing Builds”
