configure error of Blender 2.27 in cygwin
jebas
Postby jebas » Mon Jun 02, 2003 6:51 am
Since blender has always been a little unstable with my video driver in XP, I have been trying to compile a version for my cygwin environment, and I have run into a problem. I have been using the autoconf build, and here is how far I have gotten.
The first problem was that “configure –with-x” does not generate a correct Makefile for ghost. This was easy enough to get around. I opened the Makefile, commented out the win32 entries, and uncommented the X11 entries at the beginning of the Makefile. I also had to add “-I$(X_CFLAGS)” to the include line so that it would see the X11 files.
The above got me through most of the compile, but I am now stuck at “makesdna/intern”. It generates the following compile line and then stops.
gcc -g -O2 -funsigned-char ../../../../../blender-2.27/source/blender/makesdna/intern/makesdna.c -o makesdna
If you look, you can see there are no -I includes. This is causing a failure because it needs files MEM_guardedalloc.h and DNA_sdna_types.h. I have not been able to figure out why, and the rest of this message is the Makefile from the makesdna/intern directory. Anyone have an idea on how to proceed from here?
# Makefile.in generated by automake 1.7.4 from Makefile.am.
# source/blender/makesdna/intern/Makefile. Generated from Makefile.in by configure.
# Copyright 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003
# Free Software Foundation, Inc.
# This Makefile.in is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
# PARTICULAR PURPOSE.
srcdir = ../../../../../blender-2.27/source/blender/makesdna/intern
top_srcdir = ../../../../../blender-2.27
VPATH = ../../../../../blender-2.27/source/blender/makesdna/intern
pkgdatadir = $(datadir)/blender-creator
pkglibdir = $(libdir)/blender-creator
pkgincludedir = $(includedir)/blender-creator
top_builddir = ../../../..
am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
INSTALL = /usr/bin/install -c
install_sh_DATA = $(install_sh) -c -m 644
install_sh_PROGRAM = $(install_sh) -c
install_sh_SCRIPT = $(install_sh) -c
INSTALL_HEADER = $(INSTALL_DATA)
transform = $(program_transform_name)
NORMAL_INSTALL = :
PRE_INSTALL = :
POST_INSTALL = :
NORMAL_UNINSTALL = :
PRE_UNINSTALL = :
POST_UNINSTALL = :
build_triplet = i686-pc-cygwin
host_triplet = i686-pc-cygwin
target_triplet = i686-pc-cygwin
ACLOCAL = ${SHELL} /usr/src/blender-2.27/missing --run aclocal-1.7
ALLOCA =
AMDEP_FALSE = #
AMDEP_TRUE =
AMTAR = ${SHELL} /usr/src/blender-2.27/missing --run tar
AUTOCONF = ${SHELL} /usr/src/blender-2.27/missing --run autoconf
AUTOHEADER = ${SHELL} /usr/src/blender-2.27/missing --run autoheader
AUTOMAKE = ${SHELL} /usr/src/blender-2.27/missing --run automake-1.7
AWK = gawk
BlenderFMOD_FALSE =
BlenderFMOD_TRUE = #
BlenderGAME_FALSE =
BlenderGAME_TRUE = #
BlenderOPENAL_FALSE =
BlenderOPENAL_TRUE = #
BlenderPLUGIN_FALSE =
BlenderPLUGIN_TRUE = #
BlenderQUICKTIME_FALSE =
BlenderQUICKTIME_TRUE = #
BlenderSTATIC_FALSE =
BlenderSTATIC_TRUE = #
CARBON_FALSE =
CARBON_TRUE = #
CC = gcc
CCDEPMODE = depmode=gcc3
CFLAGS = -g -O2 -funsigned-char
CPP = gcc -E
CPPFLAGS =
CXX = g++
CXXDEPMODE = depmode=gcc3
CXXFLAGS = -g -O2 -funsigned-char
CYGPATH_W = cygpath -w
DEFS = -DHAVE_CONFIG_H
DEPDIR = .deps
ECHO = echo
ECHO_C =
ECHO_N = -n
ECHO_T =
EGREP = grep -E
EXEEXT = .exe
EXPPYTHON_FALSE =
EXPPYTHON_TRUE = #
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_PROGRAM = ${INSTALL}
INSTALL_SCRIPT = ${INSTALL}
INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s
LDFLAGS =
LIBM =
LIBOBJS = error$U.o obstack$U.o
LIBS =
LIBTOOL = $(SHELL) $(top_builddir)/libtool
LN_S = ln -s
LTLIBOBJS = error$U.lo obstack$U.lo
MAKEINFO = ${SHELL} /usr/src/blender-2.27/missing --run makeinfo
OBJEXT = o
OGG_CFLAGS =
OGG_LIBS =
PACKAGE = blender-creator
PACKAGE_BUGREPORT =
PACKAGE_NAME = blender-creator
PACKAGE_STRING = blender-creator 2.26
PACKAGE_TARNAME = blender-creator
PACKAGE_VERSION = 2.26
PATH_SEPARATOR = :
PYTHON = /usr/bin/python
PYTHONSYSPREFIX = /usr
PYTHON_EXEC_PREFIX = ${exec_prefix}
PYTHON_LDFLAGS =
PYTHON_PLATFORM = cygwin
PYTHON_PREFIX = ${prefix}
PYTHON_VERSION = 2.2
RANLIB = ranlib
SET_MAKE =
SHELL = /bin/bash
STRIP = strip
U_MAKE = make
VERSION = 2.26
VORBISENC_LIBS =
VORBISFILE_LIBS =
VORBIS_CFLAGS =
VORBIS_LIBS =
WIN32_FALSE = #
WIN32_TRUE =
X11_FALSE =
X11_TRUE = #
X_CFLAGS = -I/usr/X11R6/include -I/usr/X11R6/include
X_EXTRA_LIBS =
X_LIBS = -L/usr/X11R6/lib -L/usr/X11R6/lib
X_PRE_LIBS = -lSM -lICE -lSM -lICE
ac_ct_CC = gcc
ac_ct_CXX = g++
ac_ct_RANLIB = ranlib
ac_ct_STRIP = strip
am__fastdepCC_FALSE = #
am__fastdepCC_TRUE =
am__fastdepCXX_FALSE = #
am__fastdepCXX_TRUE =
am__include = include
am__leading_dot = .
am__quote =
bindir = ${exec_prefix}/bin
build = i686-pc-cygwin
build_alias =
build_cpu = i686
build_os = cygwin
build_vendor = pc
datadir = ${prefix}/share
exec_prefix = ${prefix}
host = i686-pc-cygwin
host_alias =
host_cpu = i686
host_os = cygwin
host_vendor = pc
includedir = ${prefix}/include
infodir = ${prefix}/info
install_sh = /usr/src/blender-2.27/install-sh
libdir = ${exec_prefix}/lib
libexecdir = ${exec_prefix}/libexec
localstatedir = ${prefix}/var
mandir = ${prefix}/man
oldincludedir = /usr/include
pkgpyexecdir = ${pyexecdir}/blender-creator
pkgpythondir = ${pythondir}/blender-creator
prefix = /usr/local
program_transform_name = s,x,x,
pyexecdir = ${exec_prefix}/lib/python2.2/site-packages
pythondir = ${prefix}/lib/python2.2/site-packages
sbindir = ${exec_prefix}/sbin
sharedstatedir = ${prefix}/com
sysconfdir = ${prefix}/etc
target = i686-pc-cygwin
target_alias =
target_cpu = i686
target_os = cygwin
target_vendor = pc
noinst_PROGRAMS = makesdna
makesdna_SOURCES = makesdna.c
makesdna_LDADD = $(top_builddir)/intern/guardedalloc/libblender_guardedalloc.la
makesdna_CPPFLAGS = -DBASE_HEADER="\"$(top_srcdir)/source/blender/makesdna/\""
makesdna_CFLAGS = $(makesdna_CPPFLAGS)
INCLUDES = \
-I$(top_srcdir)/intern/guardedalloc \
-I$(top_srcdir)/source/blender/makesdna
BUILT_SOURCES = dna.c
CLEANFILES = dna.c
EXTRA_DIST = \
Makefile
subdir = source/blender/makesdna/intern
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
mkinstalldirs = $(SHELL) $(top_srcdir)/mkinstalldirs
CONFIG_HEADER = $(top_builddir)/config.h
CONFIG_CLEAN_FILES =
noinst_PROGRAMS = makesdna$(EXEEXT)
PROGRAMS = $(noinst_PROGRAMS)
am_makesdna_OBJECTS = makesdna-makesdna.$(OBJEXT)
makesdna_OBJECTS = $(am_makesdna_OBJECTS)
makesdna_DEPENDENCIES = \
makesdna_LDFLAGS =
DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir)
depcomp = $(SHELL) $(top_srcdir)/depcomp
am__depfiles_maybe = depfiles
DEP_FILES = ./$(DEPDIR)/makesdna-makesdna.Po
COMPILE = $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) \
$(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS)
LTCOMPILE = $(LIBTOOL) --mode=compile $(CC) $(DEFS) $(DEFAULT_INCLUDES) \
$(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS)
CCLD = $(CC)
LINK = $(LIBTOOL) --mode=link $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
$(AM_LDFLAGS) $(LDFLAGS) -o $@
DIST_SOURCES = $(makesdna_SOURCES)
DIST_COMMON = Makefile.am Makefile.in
all: $(BUILT_SOURCES)
$(MAKE) $(AM_MAKEFLAGS) all-am
.SUFFIXES:
.SUFFIXES: .c .lo .o .obj
$(srcdir)/Makefile.in: Makefile.am $(top_srcdir)/configure.ac $(ACLOCAL_M4)
cd $(top_srcdir) && \
$(AUTOMAKE) --gnu source/blender/makesdna/intern/Makefile
Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)
clean-noinstPROGRAMS:
@list='$(noinst_PROGRAMS)'; for p in $$list; do \
f=`echo $$p|sed 's/$(EXEEXT)$$//'`; \
echo " rm -f $$p $$f"; \
rm -f $$p $$f ; \
done
makesdna$(EXEEXT): $(makesdna_OBJECTS) $(makesdna_DEPENDENCIES)
@rm -f makesdna$(EXEEXT)
$(LINK) $(makesdna_LDFLAGS) $(makesdna_OBJECTS) $(makesdna_LDADD) $(LIBS)
mostlyclean-compile:
-rm -f *.$(OBJEXT) core *.core
distclean-compile:
-rm -f *.tab.c
include ./$(DEPDIR)/makesdna-makesdna.Po
distclean-depend:
-rm -rf ./$(DEPDIR)
.c.o:
if $(COMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" \
-c -o $@ `test -f '$<' || echo '$(srcdir)/'`$<; \
then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; \
else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; \
fi
# source='$<' object='$@' libtool=no \
# depfile='$(DEPDIR)/$*.Po' tmpdepfile='$(DEPDIR)/$*.TPo' \
# $(CCDEPMODE) $(depcomp) \
# $(COMPILE) -c `test -f '$<' || echo '$(srcdir)/'`$<
.c.obj:
-c -o $@ `if test -f '$<'; then $(CYGPATH_W) '$<'; else $(CYGPATH_W) '$(srcdir)/$<'; fi`; \
fi
# $(COMPILE) -c `if test -f '$<'; then $(CYGPATH_W) '$<'; else $(CYGPATH_W) '$(srcdir)/$<'; fi`
.c.lo:
if $(LTCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" \
then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; \
fi
# source='$<' object='$@' libtool=yes \
# depfile='$(DEPDIR)/$*.Plo' tmpdepfile='$(DEPDIR)/$*.TPlo' \
# $(LTCOMPILE) -c -o $@ `test -f '$<' || echo '$(srcdir)/'`$<
makesdna-makesdna.o: makesdna.c
echo "This is it!"
if $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -MT makesdna-makesdna.o -MD -MP -MF "$(DEPDIR)/makesdna-makesdna.Tpo" \
-c -o makesdna-makesdna.o `test -f 'makesdna.c' || echo '$(srcdir)/'`makesdna.c; \
then mv -f "$(DEPDIR)/makesdna-makesdna.Tpo" "$(DEPDIR)/makesdna-makesdna.Po"; \
else rm -f "$(DEPDIR)/makesdna-makesdna.Tpo"; exit 1; \
fi
# source='makesdna.c' object='makesdna-makesdna.o' libtool=no \
# depfile='$(DEPDIR)/makesdna-makesdna.Po' tmpdepfile='$(DEPDIR)/makesdna-makesdna.TPo' \
# $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -c -o makesdna-makesdna.o `test -f 'makesdna.c' || echo '$(srcdir)/'`makesdna.c
makesdna-makesdna.obj: makesdna.c
if $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -MT makesdna-makesdna.obj -MD -MP -MF "$(DEPDIR)/makesdna-makesdna.Tpo" \
-c -o makesdna-makesdna.obj `if test -f 'makesdna.c'; then $(CYGPATH_W) 'makesdna.c'; else $(CYGPATH_W) '$(srcdir)/makesdna.c'; fi`; \
fi
# source='makesdna.c' object='makesdna-makesdna.obj' libtool=no \
# $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -c -o makesdna-makesdna.obj `if test -f 'makesdna.c'; then $(CYGPATH_W) 'makesdna.c'; else $(CYGPATH_W) '$(srcdir)/makesdna.c'; fi`
makesdna-makesdna.lo: makesdna.c
if $(LIBTOOL) --mode=compile $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -MT makesdna-makesdna.lo -MD -MP -MF "$(DEPDIR)/makesdna-makesdna.Tpo" \
-c -o makesdna-makesdna.lo `test -f 'makesdna.c' || echo '$(srcdir)/'`makesdna.c; \
then mv -f "$(DEPDIR)/makesdna-makesdna.Tpo" "$(DEPDIR)/makesdna-makesdna.Plo"; \
fi
# source='makesdna.c' object='makesdna-makesdna.lo' libtool=yes \
# depfile='$(DEPDIR)/makesdna-makesdna.Plo' tmpdepfile='$(DEPDIR)/makesdna-makesdna.TPlo' \
# $(LIBTOOL) --mode=compile $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(makesdna_CPPFLAGS) $(CPPFLAGS) $(makesdna_CFLAGS) $(CFLAGS) -c -o makesdna-makesdna.lo `test -f 'makesdna.c' || echo '$(srcdir)/'`makesdna.c
mostlyclean-libtool:
-rm -f *.lo
clean-libtool:
-rm -rf .libs _libs
distclean-libtool:
-rm -f libtool
uninstall-info-am:
ETAGS = etags
ETAGSFLAGS =
CTAGS = ctags
CTAGSFLAGS =
tags: TAGS
ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
unique=`for i in $$list; do \
if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
done | \
$(AWK) ' { files[$$0] = 1; } \
END { for (i in files) print i; }'`; \
mkid -fID $$unique
TAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \
$(TAGS_FILES) $(LISP)
tags=; \
here=`pwd`; \
done | \
test -z "$(ETAGS_ARGS)$$tags$$unique" \
|| $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
$$tags $$unique
ctags: CTAGS
CTAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \
tags=; \
here=`pwd`; \
done | \
test -z "$(CTAGS_ARGS)$$tags$$unique" \
|| $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
$$tags $$unique
GTAGS:
here=`$(am__cd) $(top_builddir) && pwd` \
&& cd $(top_srcdir) \
&& gtags -i $(GTAGS_ARGS) $$here
distclean-tags:
-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
top_distdir = ../../../..
distdir = $(top_distdir)/$(PACKAGE)-$(VERSION)
distdir: $(DISTFILES)
@srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \
topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \
list='$(DISTFILES)'; for file in $$list; do \
case $$file in \
$(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \
$(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \
esac; \
if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
if test "$$dir" != "$$file" && test "$$dir" != "."; then \
dir="/$$dir"; \
$(mkinstalldirs) "$(distdir)$$dir"; \
else \
dir=''; \
fi; \
if test -d $$d/$$file; then \
if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
fi; \
cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
else \
test -f $(distdir)/$$file \
|| cp -p $$d/$$file $(distdir)/$$file \
|| exit 1; \
fi; \
done
check-am: all-am
check: $(BUILT_SOURCES)
$(MAKE) $(AM_MAKEFLAGS) check-am
all-am: Makefile $(PROGRAMS)
installdirs:
$(MAKE) $(AM_MAKEFLAGS) install-recursive
install: $(BUILT_SOURCES)
$(MAKE) $(AM_MAKEFLAGS) install-am
install-exec: install-exec-am
install-data: install-data-am
uninstall: uninstall-am
install-am: all-am
@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
installcheck: installcheck-am
install-strip:
$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
INSTALL_STRIP_FLAG=-s \
`test -z '$(STRIP)' || \
echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
mostlyclean-generic:
clean-generic:
-test -z "$(CLEANFILES)" || rm -f $(CLEANFILES)
distclean-generic:
-rm -f Makefile $(CONFIG_CLEAN_FILES)
maintainer-clean-generic:
@echo "This command is intended for maintainers to use"
@echo "it deletes files that may require special tools to rebuild."
-test -z "$(BUILT_SOURCES)" || rm -f $(BUILT_SOURCES)
clean: clean-am
clean-am: clean-generic clean-libtool clean-noinstPROGRAMS \
mostlyclean-am
distclean: distclean-am
distclean-am: clean-am distclean-compile distclean-depend \
distclean-generic distclean-libtool distclean-tags
dvi: dvi-am
dvi-am:
info: info-am
info-am:
install-data-am:
install-exec-am:
install-info: install-info-am
install-man:
installcheck-am:
maintainer-clean: maintainer-clean-am
maintainer-clean-am: distclean-am maintainer-clean-generic
mostlyclean: mostlyclean-am
mostlyclean-am: mostlyclean-compile mostlyclean-generic \
mostlyclean-libtool
pdf: pdf-am
pdf-am:
ps: ps-am
ps-am:
uninstall-am: uninstall-info-am
.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \
clean-libtool clean-noinstPROGRAMS ctags distclean \
distclean-compile distclean-depend distclean-generic \
distclean-libtool distclean-tags distdir dvi dvi-am info \
info-am install install-am install-data install-data-am \
install-exec install-exec-am install-info install-info-am \
install-man install-strip installcheck installcheck-am \
installdirs maintainer-clean maintainer-clean-generic \
mostlyclean mostlyclean-compile mostlyclean-generic \
mostlyclean-libtool pdf pdf-am ps ps-am tags uninstall \
uninstall-am uninstall-info-am
# maybe there's a better way...
dna.c: makesdna
# cp -f $(top_srcdir)/source/blender/makesdna/*.h $(top_builddir)/source/blender/makesdna
./makesdna$(EXEEXT) dna.c
# Tell versions [3.59,3.63) of GNU make to not export all variables.
# Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
Return to “Coding Blender”
