| Code: |
| ./blender -d
Blender 2.51 (sub 0) Build Build: "2010-02-18" "16:05:19" "linux2" "dynamic" argv[0] = ./blender argv[1] = -d read file /home/dani/.B25.blend Version 250 sub 7 Segmentation fault |
| Code: |
| ./blender -d |
| Code: |
| cd ~/source/blender-2.5-alpha2-linux-glibc27-i686 |
| Code: |
| ./blender -d |
| Code: |
| Blender 2.52 (sub 0) Build
Build: "2010-03-09" "16:58:31" "linux2" "dynamic" argv[0] = ./blender argv[1] = -d read file Version 251 sub 0 ordered OBCube OBLamp OBCamera swin 1 added swin 2 added swin 3 added swin 4 added swin 5 added swin 6 added swin 7 added swin 8 added swin 9 added swin 10 added swin 11 added swin 12 added swin 13 added set screen found bundled python: /home/neduret/source/blender-2.5-alpha2-linux-glibc27-i686/.blender/python SRNA Subclassed: 'Panel' time properties_animviz 0.0004 SRNA Subclassed: 'Operator' time properties_data_armature 0.0009 SRNA Subclassed: 'Menu' SRNA Subclassed: 'Header' time properties_data_armature_rigify 0.0025 time properties_data_bone 0.0005 time properties_data_camera 0.0003 time properties_data_curve 0.0006 time properties_data_empty 0.0001 time properties_data_lamp 0.0005 time properties_data_lattice 0.0002 time properties_data_mesh 0.0005 time properties_data_metaball 0.0004 time properties_data_modifier 0.0005 time properties_game 0.0007 time properties_material 0.0018 time properties_object 0.0005 time properties_object_constraint 0.0005 time properties_particle 0.0022 time properties_physics_cloth 0.0004 time properties_physics_common 0.0000 time properties_physics_field 0.0003 time properties_physics_fluid 0.0005 time properties_physics_smoke 0.0005 time properties_physics_softbody 0.0009 time properties_render 0.0008 time properties_scene 0.0010 time properties_texture 0.0014 time properties_world 0.0009 time space_buttons 0.0002 time space_console 0.0006 time space_dopesheet 0.0003 time space_filebrowser 0.0003 time space_graph 0.0003 time space_image 0.0009 time space_info 0.0000 time space_logic 0.0001 time space_nla 0.0006 time space_node 0.0002 time space_outliner 0.0002 time space_sequencer 0.0010 time space_text 0.0006 time space_time 0.0003 time space_userpref 0.0028 time space_view3d 0.0040 time space_view3d_toolbar 0.0013 SRNA Subclassed: 'Operator' time add_armature_human 0.0007 time add_mesh_torus 0.0003 time console_python 0.0001 time console_shell 0.0001 time fcurve_euler_filter 0.0002 time image 0.0002 time mesh 0.0004 time object 0.0010 time object_align 0.0002 time object_randomize_transform 0.0002 time presets 0.0007 time screen_play_rendered_anim 0.0095 time sequencer 0.0002 time uv 0.0003 time uvcalc_follow_active 0.0002 time uvcalc_smart_project 0.0006 time vertexpaint_dirt 0.0002 time wm 0.0018 SRNA Subclassed: 'Panel' time engine_render_pov 0.0069 SRNA Subclassed: 'Operator' time export_3ds 0.0013 time export_fbx 0.0013 time export_mdd 0.0003 time export_obj 0.0005 time export_ply 0.0014 time export_x3d 0.0007 time import_anim_bvh 0.0004 time import_scene_3ds 0.0015 time import_scene_obj 0.0000 time import_shape_mdd 0.0002 SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Operator' time netrender 0.0430 Time 0.1278 SRNA Subclassed: 'Bone' SRNA Subclassed: 'Context' SRNA Subclassed: 'EditBone' SRNA Subclassed: 'Header' SRNA Subclassed: 'Macro' SRNA Subclassed: 'Menu' SRNA Subclassed: 'Mesh' SRNA Subclassed: 'MeshEdge' SRNA Subclassed: 'MeshFace' SRNA Subclassed: 'Object' SRNA Subclassed: 'Operator' SRNA Subclassed: 'Panel' SRNA Subclassed: 'PoseBone' read file Version 250 sub 0 handle evt 0 win 0 op WM_OT_splash swin 14 added bpy.ops.wm.splash() set drawable 1 ghost redraw recalcob Cube recalcdata Cube set screen |
| Code: |
| ./blender |
| Code: |
*bpy stats* - tot exec: 182, tot run: 0.0053sec, average run: 0.000029sec, tot usage 0.0256% |
| Code: |
| blender |
| Quote: |
blender-2.5-alpha2-linux-glibc27-i686.tar.bz2 |
| Code: |
cd ~/Downloads |
| Code: |
tar jxvf blender-2.5-alpha2-linux-glibc27-i686.tar.bz2 -C ~/source |
| Quote: |
| Linux, FreeBSD, Irix, Solaris: Unpack the distribution, copy the .blender directory from it to your home directory. Then run the Blender executable.
Install scripts by putting them in the .blender/scripts inside your home folder. |
| Code: |
| ./configure |
| Code: |
| make |
| Code: |
sudo make install |
| Code: |
| cd ~/source/blender-2.5-alpha2-linux-glibc27-i686$ ./blender |
| Code: |
export PATH="/my/path/to/blender2.5:${PATH}" |
