Menu display trouble with Blender 2.5
les Acides Animés
Postby les Acides Animés » Fri Mar 05, 2010 6:56 pm
Hi guys !
I have a display problem using Blender 2.5 alpha 2 (and every test bluids I've downloaded so far) : I can't see the menus !
It looks like this : screenshot.
My drivers are up to date and it doesn't solve this problem.
Any idea or anybody wih the same thing ?
thanks!
Last edited by les Acides Animés on Mon Apr 19, 2010 12:29 pm, edited 3 times in total.
IAlex
Re: Menu display trouble with Blender 2.5
Postby IAlex » Thu Mar 25, 2010 7:08 am
les Acides Animés wrote:Hi guys !
thanks!
I have this problem too (Blender Alpha 1 and 2 (win_32)).
When the appication boots, the debuger writes in the consol window:
search for unknown operator WM_OT_context_toggle, WM_OT_context_toggle
RNA_string_set: OperatorProperties.path not found.
search for unknown operator WM_OT_context_cycle_enum, WM_OT_context_cycle_enum
search for unknown operator WM_OT_context_toggle_enum, WM_OT_context_toggle_enum
RNA_string_set: OperatorProperties.value_1 not found.
RNA_string_set: OperatorProperties.value_2 not found.
search for unknown operator OBJECT_OT_subdivision_set, OBJECT_OT_subdivision_set
RNA_int_set: OperatorProperties.level not found.
RNA_boolean_set: OperatorProperties.relative not found.
search for unknown operator WM_OT_context_set_int, WM_OT_context_set_int
RNA_int_set: OperatorProperties.value not found.
search for unknown operator WM_OT_context_set_enum, WM_OT_context_set_enum
RNA_string_set: OperatorProperties.value not found.
search for unknown operator WM_OT_context_cycle_int, WM_OT_context_cycle_int
RNA_boolean_set: OperatorProperties.reverse not found.
search for unknown operator CONSOLE_OT_execute, CONSOLE_OT_execute
search for unknown operator CONSOLE_OT_autocomplete, CONSOLE_OT_autocomplete
search for unknown operator HELP_OT_release_logs, HELP_OT_release_logs
search for unknown operator HELP_OT_manual, HELP_OT_manual
search for unknown operator HELP_OT_blender_website, HELP_OT_blender_website
search for unknown operator HELP_OT_user_community, HELP_OT_user_community
search for unknown operator HELP_OT_python_api, HELP_OT_python_api
Installed software: Windows XP Professional SP2, Python 2.6.5.
Installed hardware: 2 GB RAM, 2 Ghz CPU, ATI Radion 9600XT 256Mb.
torihito
Postby torihito » Fri Mar 26, 2010 6:29 pm
・Coincidence only "2 lines" in blender.exe. see below(image html link).
entry URL:
http://blenderhack.ganriki.net/Solution ... tPage.html
・Debug Tool's screen shots and explain to focus error handler, Hear!!
(I use microsoft Visual C++ 2008 Express Edition SPx and blender 2.50 alpha xx.)
See 「Solution Hints」 (date 2010.03/26)
URL:
http://blenderhack.ganriki.net/Solution ... 03_26.html :shock:
les Acides Animés
Postby les Acides Animés » Fri Apr 02, 2010 1:16 pm
Hi!
I'm very happy because I've solved my problem in a very easy way!
And the solution is so stupid (it really works for me) : when I download a new build of Blender, I don't put it on my primary partition disk (C:), but on an other partition (which is D:). So I guess Blender has some problems with this!
When I move the folder to the C: partition, it works perfectly!
I hope it'll work for you too!
Nagle
Same bug is in 2.57 RELEASED versions.
Postby Nagle » Sat Apr 16, 2011 9:09 am
I'm getting the same problem in the RELEASED version, Blender 2.57.
I'm installing on Windows 7, 64-bit.
I've tried installing both the 32-bit and 64-bit versions of Blender, using the Windows installers. Both are broken.
I've tried removing all old versions of Blender, both the Program Files part and the AppData part. I still don't get a menu bar.
It's really hard to view the error messages, now that Blender hides the text console window. But if I exit Blender and hit PrtScr to get a screen capture fast enough, I can sort of see some of them. The text console is fading out and has gone translucent at that point, so it's barely readable. But I can make out this:
python line lookup failed, interpreter inactive
Unknown operator WM_OT_url_open.
OperatorProperties.url not found
Someone else reported this in an Italian forum: http://www.kino3d.com/forum/viewtopic.php?t=8640&p=94157.
djeten
Postby djeten » Tue Apr 19, 2011 9:34 pm
I have the same problem, but when I run blender as admin, then it works...
Nagle
Postby Nagle » Sun May 01, 2011 10:01 pm
There have been many reports of this problem in different forums over the last several years:
http://www.blender.org/forum/viewtopic. ... 9a0c27f74e
http://www.blender.org/forum/viewtopic. ... f6ab46ac83
http://www.linuxquestions.org/questions ... le-786260/
http://projects.blender.org/tracker/?gr ... &aid=23063
(Status: Developer in denial:
" Date: 2010-08-27 02:35
Sender: Campbell Barton
assuming this is just a broken installation, we get a few of these reports.
closing.")
http://projects.blender.org/tracker/?gr ... &aid=23560
("Closed due to inactivity")
Typical suggestions from developers include reinstalling, installing in a different place, running as admin, switching to a different OS, switching to a different graphics card, and sacrificing a chicken.
adriana252
Postby adriana252 » Thu Sep 29, 2011 2:37 pm
Unfortunately, there's no real pipeline from Blender 2.5, only 2.49. A project was started recently aiming to create such an Egg exporter (it won't be a Chicken port as that's not possible) and Collada support is underway for Panda 1.8, but at the moment -- Blender 2.5 is out of limits, sorry.
holmedean
Postby holmedean » Sat Nov 19, 2011 6:00 pm
adriana252 wrote:Unfortunately, there's no real pipeline from Blender 2.5, only 2.49. A project was started recently aiming to create such an Egg exporter (it won't be a Chicken port as that's not possible) and Collada support is underway for Panda 1.8, but at the moment -- Blender 2.5 is out of limits, sorry.
So has this exporter been created?
yaxinhoo
Postby yaxinhoo » Sat Dec 17, 2011 2:50 pm
i have the same problem on blender 2.6.1 . and still don't know how to do. anyone can help me ?
Return to “Testing Builds”
