| Quote: |
| ImportError: No module named bpy |
| Quote: |
| apparently ive been running on directx 11 |
| Quote: |
| bpy is a built-in module. Are you running this script inside Blender? |
| Quote: |
| Blender uses OpenGL. It does not use DirectX. |
| Quote: |
| no i ran the code through the "Python program" and even said that in my earlier post about it. |
| Quote: |
| Bottom line: Blender scripts MUST be run inside of Blender. You CANNOT run them with the regular Python interpreter. |
| Quote: |
| Code: import bpy
narrowui = 180 from properties_physics_common import point_cache_ui from properties_physics_common import effector_weights_ui class PhysicButtonsPanel(bpy.types.Panel): bl_space_type = 'PROPERTIES' bl_region_type = 'WINDOW' bl_context = "physics" def poll(self, context): ob = context.object rd = context.scene.render return (ob and ob.type == 'MESH') and (not rd.use_game_engine) class PHYSICS_PT_smoke(PhysicButtonsPanel): bl_label = "Smoke" def draw(self, context): layout = self.layout md = context.smoke ob = context.object wide_ui = context.region.width > narrowui split = layout.split() split.operator_context = 'EXEC_DEFAULT' if md: # remove modifier + settings split.set_context_pointer("modifier", md) split.operator("object.modifier_remove", text="Remove") row = split.row(align=True) row.prop(md, "render", text="") row.prop(md, "realtime", text="") else: # add modifier split.operator("object.modifier_add", text="Add").type = 'SMOKE' if wide_ui: split.label() if md: if wide_ui: layout.prop(md, "smoke_type", expand=True) else: layout.prop(md, "smoke_type", text="") if md.smoke_type == 'TYPE_DOMAIN': domain = md.domain_settings split = layout.split() col = split.column() col.label(text="Resolution:") col.prop(domain, "maxres", text="Divisions") col.label(text="Particle:") col.prop(domain, "initial_velocity", text="Initial Velocity") if wide_ui: col = split.column() col.label(text="Behavior:") col.prop(domain, "alpha") col.prop(domain, "beta") col.prop(domain, "dissolve_smoke", text="Dissolve") sub = col.column() sub.active = domain.dissolve_smoke sub.prop(domain, "dissolve_speed", text="Time") sub.prop(domain, "dissolve_smoke_log", text="Slow") elif md.smoke_type == 'TYPE_FLOW': flow = md.flow_settings split = layout.split() col = split.column() col.prop(flow, "outflow") col.label(text="Particle System:") col.prop_object(flow, "psys", ob, "particle_systems", text="") if md.flow_settings.outflow: if wide_ui: col = split.column() else: if wide_ui: col = split.column() col.label(text="Behavior:") col.prop(flow, "temperature") col.prop(flow, "density") #elif md.smoke_type == 'TYPE_COLL': # layout.separator() class PHYSICS_PT_smoke_groups(PhysicButtonsPanel): bl_label = "Smoke Groups" bl_default_closed = True def poll(self, context): md = context.smoke return md and (md.smoke_type == 'TYPE_DOMAIN') def draw(self, context): layout = self.layout group = context.smoke.domain_settings wide_ui = context.region.width > narrowui split = layout.split() col = split.column() col.label(text="Flow Group:") col.prop(group, "fluid_group", text="") #col.label(text="Effector Group:") #col.prop(group, "eff_group", text="") if wide_ui: col = split.column() col.label(text="Collision Group:") col.prop(group, "coll_group", text="") class PHYSICS_PT_smoke_cache(PhysicButtonsPanel): bl_label = "Smoke Cache" bl_default_closed = True def poll(self, context): md = context.smoke return md and (md.smoke_type == 'TYPE_DOMAIN') def draw(self, context): layout = self.layout domain = context.smoke.domain_settings layout.label(text="Compression:") layout.prop(domain, "smoke_cache_comp", expand=True) md = context.smoke.domain_settings cache = md.point_cache_low point_cache_ui(self, context, cache, (cache.baked is False), 0, 1) class PHYSICS_PT_smoke_highres(PhysicButtonsPanel): bl_label = "Smoke High Resolution" bl_default_closed = True def poll(self, context): md = context.smoke return md and (md.smoke_type == 'TYPE_DOMAIN') def draw_header(self, context): high = context.smoke.domain_settings self.layout.prop(high, "highres", text="") def draw(self, context): layout = self.layout md = context.smoke.domain_settings wide_ui = context.region.width > narrowui split = layout.split() col = split.column() col.label(text="Resolution:") col.prop(md, "amplify", text="Divisions") col.prop(md, "viewhighres") if wide_ui: col = split.column() col.label(text="Noise Method:") col.row().prop(md, "noise_type", text="") col.prop(md, "strength") class PHYSICS_PT_smoke_cache_highres(PhysicButtonsPanel): bl_label = "Smoke High Resolution Cache" bl_default_closed = True def poll(self, context): md = context.smoke return md and (md.smoke_type == 'TYPE_DOMAIN') and md.domain_settings.highres def draw(self, context): layout = self.layout domain = context.smoke.domain_settings layout.label(text="Compression:") layout.prop(domain, "smoke_cache_high_comp", expand=True) md = context.smoke.domain_settings cache = md.point_cache_high point_cache_ui(self, context, cache, (cache.baked is False), 0, 1) class PHYSICS_PT_smoke_field_weights(PhysicButtonsPanel): bl_label = "Smoke Field Weights" bl_default_closed = True def poll(self, context): smoke = context.smoke return (smoke and smoke.smoke_type == 'TYPE_DOMAIN') def draw(self, context): domain = context.smoke.domain_settings effector_weights_ui(self, context, domain.effector_weights) classes = [ PHYSICS_PT_smoke, PHYSICS_PT_smoke_field_weights, PHYSICS_PT_smoke_cache, PHYSICS_PT_smoke_highres, PHYSICS_PT_smoke_groups, PHYSICS_PT_smoke_cache_highres] def register(): register = bpy.types.register for cls in classes: register(cls) def unregister(): unregister = bpy.types.unregister for cls in classes: unregister(cls) if __name__ == "__main__": register() |
| Quote: |
| Errors: >>> col = split.column()
File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> col.label(text="Noise Method:") File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> col.row().prop(md, "noise_type", text="") File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> col.prop(md, "strength") File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> >>> >>> class PHYSICS_PT_smoke_cache_highres(PhysicButtonsPanel): ... bl_label = "Smoke High Resolution Cache" ... bl_default_closed = True ... >>> def poll(self, context): File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> md = context.smoke File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> return md and (md.smoke_type == 'TYPE_DOMAIN') and md.domain_settings.highres File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> >>> def draw(self, context): File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> layout = self.layout File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> >>> domain = context.smoke.domain_settings File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> >>> layout.label(text="Compression:") File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> layout.prop(domain, "smoke_cache_high_comp", expand=True) File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) >>> >>> >>> md = context.smoke.domain_settings File "<string>", line None SyntaxError: unexpected indent (<console>, line 1) |
| Quote: |
| BTW the directX thing was mentioned for a game,but I figured it'd be useful for Blender as well somehow...but OpenGL is not needed anyways...it's not integrated into that many video cards yet.. |
