How does one export blender to be used in other apps.
dj
Postby dj » Wed Jul 09, 2003 9:34 am
Newby here. Just wondering how one exports/renders an image to be used in another application as a pic or animated .swf etc?
Cheers
Damien.
ideasman
Postby ideasman » Wed Jul 09, 2003 10:47 am
Give us more details of what you want to do with the images
Press F12 to render
and then F3 to save
If you can't use taga's then change the format in the render panel - F10
If you want to make an SWF there is no SIMPLE way to to this.
You could import the image sequence into flash and convert them to vectors.
Then export the swf.
dj
Postby dj » Wed Jul 09, 2003 12:07 pm
Prob a basic question, but I am very new to the environment. I would like to know how blender work can be exported as image or a vid file (if with vid file, can one use windows media player to view?)
I am mainly wanting to know how exported blender work can be exported as a jpeg etc.
Thanks!
Damien.
ideasman
Postby ideasman » Thu Jul 10, 2003 1:11 am
When you press F10 there is an export format dropdown.
From this you can select AVI or QUICKTIME,
To preview your animation it wireframe mode- Move your mouse over the camera viewpord and press CTRL+A
Make sure you have a sane start and end frame
Select the render dir using the little square on the top left of the render panel.
Then press the big ANIM button in the render panel (F10)
This will save the AVI, QT or image sequence
When finished press play.
Return to “Rendering”
