Interactive Python
markluffel
Interactive Python
Postby markluffel » Sun Oct 20, 2002 1:44 am
An interactive python mode for blender would be great.
I often start the python interpreter while testing a script to check a code stub without executing the entire thing. There is no direct way to do this in blender. Adding a 'terminal' window mode to blender seems like the obvious solution, but perhaps there is something more elegant.
Besides allowing testing of scripts this creates a command-line-interface for blender that would handle repetitive but single use actions like...
Code: Select all
for bone in skeleton:
  if bone.x > 0:
    bone.name = 'r'+bone.name
  else:
    bone.name = 'l'+bone.name
theeth
Postby theeth » Sun Oct 20, 2002 5:52 am
I usually use a dummy script to do that kind of things, but yes, a command line window could be very useful.
Martin
- John Lennon
joonas
Postby joonas » Tue Oct 22, 2002 12:17 pm
This code snippet creates a simple Python shell to the Blender console. It handles neither multi-line statements nor exceptions, but creating a fully compatible shell is not a problem. Anyway, I don't know if this solves your problem.
Code: Select all
while 1:
    try:
        try:
            s = raw_input('>>> ')
        except EOFError:
            print
            break
        if s and s[0] != '#':
            s = s + '\n'
            c = compile(s, '<stdin>', 'single')
            exec c
    except:
        raise
- Joonas
markluffel
Console vs Terminal
Postby markluffel » Thu Oct 24, 2002 6:06 am
To get a console window in MacOS X you must call Blender from the command line. Something like:
/Applications/BlenderPublisher.app/Contents/MacOS/blenderpublisher
You could also create a link to the executable and name it "blender" for easy access. Say:
ln /Application/...publisher ~/blender.
I also edited the script:
Code: Select all
import traceback
while 1:
  try:
    try:
    except EOFError:
      print traceback.print_exc()
      break
    if s == 'exit':
      break
      s = s + '\n'
      exec compile(s, '<stdin>', 'single')
  except:
It would be elegant if there was a toggle button on the script window that executed a script after it was selected in the drop-down menu. This would make selecting GUI scripts (or this console hack) like selecting a window mode. I think it would be consistent with the rest of the interface.[/code]
Return to “Python”
