Posted: Mon Oct 11, 2010 6:52 pm
I'm new to blender and started learning the interface. I tried to rotate the camera around my object using the middle mouse button but it won't do it. Clicking on the symbol with the 3 dots and an arrow underneath hasn't done anything. I can't work out what I've pressed but it just will not rotate whatsoever. I'm wondering whether it's down to a bug as this version of blender is still in beta.
If it's not a bug then I hope someone knows how to fix this problem because I'm stumped.
Thanks a lot
xx
Posted: Tue Oct 12, 2010 11:57 am
are you using a mac mouse?
Posted: Thu Oct 14, 2010 5:34 pm
I'm using a trackpad on a macbook. Holding alt and pressing the button and moving along the trackpad with my otherfinger used to work fine, I don't know why it's suddenly stopped.
Posted: Thu Oct 14, 2010 7:12 pm
enable 'Emulate 3 button mouse' in user prefs. You can Ctrl U to save this a a default
If you've upgraded to a newer version of Blender you need to re-set our preferences.
Posted: Mon Oct 25, 2010 10:20 pm
I think you have to use a mouse because I've looked and that's the only thing that has worked for me
Posted: Tue Oct 26, 2010 9:26 pm
tcw, It works on my Macbook Pro, what version macbook are you using?
Posted: Wed Oct 27, 2010 2:35 pm
Posted: Wed Oct 27, 2010 2:37 pm
are we talking about 2.5 or 2.49?
Posted: Wed Oct 27, 2010 7:18 pm
Emulate 3 Button Mouse is a feature of both 2.49 & 2.5x and I remember it worked on my Powerbook G4
to access the User Prefs in 2.49 you need to drag down the top menu bar and select Edit Methods.
Posted: Wed Oct 27, 2010 7:25 pm
do you happen to know 2.5?
Posted: Thu Oct 28, 2010 1:08 pm
Blender 2.5
File -> User Preferences... choose Input, tick Emulate 3 Button Mouse. Close the User Preferences window and if you Ctrl U now you can save this as a default setting each time you open Blender. So it best do this with new scene.
Posted: Sun Feb 10, 2013 3:24 am
| psullie wrote: |
Blender 2.5
File -> User Preferences... choose Input, tick Emulate 3 Button Mouse. Close the User Preferences window and if you Ctrl U now you can save this as a default setting each time you open Blender. So it best do this with new scene. |
that help me but it zomed me out so far i cant see what im doing
