WinOSI ?
rosss
WinOSI ?
Postby rosss » Sun Oct 20, 2002 9:01 pm
Just wanted to say that their is a great freeware SMALL renderer ..
http://www.winosi.onlinehome.de/
Debaser
Re: WinOSI ?
Postby Debaser » Mon Oct 21, 2002 2:09 pm
Looks good indeed, and it's opensource :!: could be very useful.
But there's not a lot of documentation yet.
kaktuswasser
Postby kaktuswasser » Mon Oct 21, 2002 11:42 pm
looks good,but seems to be very slow :?
MrMunkily
Postby MrMunkily » Tue Oct 22, 2002 3:49 am
visual quality aint that great neither. lots of grain from what i saw. not an artists render, rather a true simulation of what light would do. not exactly what an artists program needs to be... but interesting nonetheless
protoplazm
Postby protoplazm » Tue Oct 22, 2002 9:07 am
it may have been my computer, but the speed of WinOSI is TERRIBLE...
but i checked the gallery online, and the results look pretty good. i don't know if the speed is acceptable though
MrMunkily
Postby MrMunkily » Wed Oct 23, 2002 12:59 am
it has no optimizations and no appoximations. that's why it looks so bad unless you leave it on for 100 days. those images took like 5 days to render.
protoplazm
Postby protoplazm » Wed Oct 23, 2002 9:36 am
that explains a lot :p
Noiprox
Postby Noiprox » Thu Oct 24, 2002 2:22 am
Do not judge WinOSI before you even know what it is!
It is an experiment in physically-based modelling of light. It is not intended for artistic use. It does represent what will probably be standard for CG eventually. By modelling the actual photons as rays, it is possible to simulate all light phenomena with perfect accuracy. Unfortunately, with current computing power, that requires days of calculation. There was a time but a decade ago when a typical frame of a typical game would be all but impossible to achieve, even pre-rendered. Now it's realtime...
WinOSI is very impressive in that it models light with amazing physical accuracy. For Blender, it would be better to look to Renderman, raytracing and the like instead.
MrMunkily
Postby MrMunkily » Wed Nov 27, 2002 8:02 am
sure. it's not really a renderer.
It's not realistic at this point.
I have yet to see a GI solution that was actually completed. everything looks half caluclated with a lot of grain.
green
Postby green » Wed Nov 27, 2002 4:18 pm
Noiprox wrote:Do not judge WinOSI before you even know what it is!
I dont see alot of checkered floors and glass spheres in proffesional photo's...
Noiprox
Postby Noiprox » Fri Nov 29, 2002 2:55 am
Green, you managed to mispunctuate and misspell in a single chunk of destructive sarcasm.
If you had read what I wrote more carefully, you would notice that I never called it photorealistic. It is more physically accurate than other algorithms. Those checkered floors and glass spheres you refer to are clearly due to the limitations of the scene description language supported by WinOSI, not the rendering algorithm itself. It is theoretically possible to render a scene photorealistically with an approach like WinOSI's, but not with raytracing, and definately not with REYES or scanline algorithms.
MrMunkily, if you think WinOSI is not a renderer, you should look up the definition of the word. WinOSI is most definately a renderer, just not one designed for the purposes that you people all seem to assume it was intended for. WinOSI is more of a scientific experiment than anything else.
As for Global Illumination, do you mean WinOSI's examples are not complete GI solutions, or do you mean GI in general? If you knew anything about the physics of light, you would know that light levels on surfaces are actually defined as the limits of infinite photonic reflections. There is no such things as calculating a GI scene to "completion". By modelling the actual photons, it is possible to generate pixel-perfect images, though, and those will be "complete" in your sense of the word, but that requires a fair bit of supercomputer time for even a simple scene.
There are actually scenes that have been calculated to extremely high degrees of accuracy, the classical one being the Cornell Box, of course.
I am not defending WinOSI for the sake of WinOSI.
I stand for truth.
neil
Postby neil » Fri Nov 29, 2002 5:10 pm
This is why Blender needs besides any integrated renderer(s) the ability to easily interface with external renderers. No-one can agree what the ideal renderer is because everyone has different requirements/interests/patience (in terms of rendering times). Personally I think once he has made the upgrade to handle complex geometry better this will be a very good option to have along with other renderers.
Neil
green
Postby green » Sat Nov 30, 2002 5:59 pm
I think what you meant to say that it is impossible for YOU to do it.
The artists doesnt blame the tool when he fails.. he learns new ways to get to the goal.
People like you just want a MakeNiceLookingImage button, *sheesh*
alltaken
Postby alltaken » Mon Dec 02, 2002 12:42 am
the renderer doesn't look to bad.
the images are grainy because the camera is picking up only photons that reach it (because "the renderer is so advanced" )(LOL)
na i think it looks nice and the images are rather real looking. (even if they look a bit washed out)
Hmmmmm
please don't start a fight :cry: :cry: :cry: :cry:
it would make me sad.
wait for a new version i say, it still has a few bugs.
kniffo
The Problem...
Postby kniffo » Mon Dec 02, 2002 8:08 am
Well, beside that there's a problem. Not all of the renderers, WinOSI for instance or Light++, can take renderman rib-files as their input. Light++ takes C++ text. vmd-files are of another format than the others. So, I don't want to talk long about this - what do you think of desinging an interface definition language, so that we would have a bison for blender. The designer of an interface to any renderer would provide an interface definition to his format and the blender would then use this definition to produce the right format.
Would'nt that be nice? Well, if this is a good idea, I would start such a thing but I need your concerns! :)
/Kniffo
Return to “Rendering”
Users browsing this forum: Google [Bot] and 0 guests
