I didnt exactly know where to post this, but here goes...
It was pointed out by someone at Elysiun that Zblur doesnt work in 2.28 (as I am to understand that all if not most scripts/plugins should work there because of the new api?)
I thought...no, it might just be their setup....you I tried it, and I get error messages in the console window and a bright red render in the render window.
Anyone know whats the go here?
When a real depth of field...
strange, the zblur plugin works perfectly here.
the red window can be a result of wrong zmin values, too. what's the console output?
.andy
Ok heres what Im getting:
Error: input has no z-buffer
---------edit--------------
It seems i have the old compile....not the june 2003 one..
It works now
where to get the new version?
finally i've downloaded it here again and now it works:
http://www-users.cs.umn.edu/~mein/blender/plugins/sequence/zblur/index.html
maybe this helps you!
benjamin
