Render Daemon "renderd.exe" failing to connect.
Postby BrianNickel » Wed Oct 23, 2002 5:08 am
I have a 1.8gHz machine I in the next room I would like to use for rendering. Blender causes an infinite loop in the graphics driver so I can't use it (but thats a story for another thread).
I've decided to use it for network rendering (hoping it won't crash), but when I start renderd.exe I get the following:
C:\Program Files\Blender>renderd
Using BLENDER = blender.exe
Could not create socket. Error PR_ADDRESS_IN_USE_ERROR (just wait TIME_WAIT)
This is on both the 1.8 XP machine, and the 450mHz machine thats running broker.exe
Anyone ever run across this problem?
Postby Sverre » Thu Oct 24, 2002 10:03 am
Yes, I have. I think it was caused bu the borke and/or daemon not releasing the port correctly. At the moment I can't quite remember how I produced the error, but as far as i can remember it happened when i had stopped the daemon and the restarted it immediately or something like that. Sitting tight for a minute or so until the port was reclaimed by the OS and then trying again worked for me.
Hopes this helps.
Re: Render Daemon "renderd.exe" failing to connect
Postby Caronte » Sat Oct 26, 2002 1:54 am
BrianNickel wrote:I have a 1.8gHz machine I in the next room I would like to use for rendering.
If do you use windows, you can try BlenderTools in Spanish Blender website
Return to “Rendering”
