Posted: Sun Feb 20, 2011 5:44 pm
Hi! I'm new to the forums. After great experiences with GIMP and Inkscape I hope to learn at least basics of Blender
Here we go...
Due to UI problems I had with 2.49 I've decided to install the latest dev version. I've downloaded the tar.bz2 archive from blender.org, extracted it...
The readme.html inside the archive says
| Quote: |
Linux, FreeBSD, Irix, Solaris: Unpack the distribution, copy the .blender directory from it to your home directory. Then run the Blender executable.
Install scripts by putting them in the .blender/scripts inside your home folder. |
1. There is no .blender dir in the archive (even though I have "show hidden files" option checked)
2. 2-Clicking on the blender executable included in this archive does nothing.
Can anyone help me out.
Posted: Tue Feb 22, 2011 5:11 pm
if you are building blender form source i don't know anything about that, but if you want the file provided by blender.org it's here
http://www.blender.org/download/get-blender/ .The blender executable is in that file, just click on it.
ebb
Posted: Tue Feb 22, 2011 9:41 pm
I already did - as stated above.
Posted: Wed Feb 23, 2011 9:03 pm
Run blender from the command line as ./blender . Likely there is something missing that is keeping it from running.
A more sophisticated approach would be to run ldd on the blender executable and look at the missing shared libraries.
Posted: Wed Feb 23, 2011 9:21 pm
| stiv wrote: |
A more sophisticated approach would be to run ldd on the blender executable and look at the missing shared libraries. |
Already tried that. It returns "blender not installed". It obviously tries to launch an "installed blender" and doesn't even care about that executable from the package. When I had 2.49 installed a command to launch 2.56 was launching... the installed 2.49.
Posted: Thu Feb 24, 2011 5:35 am
This suggests you are trying to run blender from the command line as
blender
not as
./blender
(that is dot-slash-blender).
Just typing blender will look for an executable in your PATH. dot-slash-blender will execute that specific file. If this does not work, show the results of running
file ./blender
Posted: Fri Feb 25, 2011 9:00 pm
I've been given a 32 bit Ubuntu CD instead of 64 bit so I was trying to run blender x64 on 32 bit system without even a clue that this was the reason of all the troubles. On top of that I ran 2.49 instead of 2.56 by mistake. Bad, embarassing day all around
Sorry for bothering you.
So:
- run the right executable for your system architecture e.g. run 32 bit executable on 32 bit system
- running blender 2.5x from tar.bz2 archives from blender.org is the easiest way to run blender 2.5x and works flawlessly
Posted: Fri Feb 25, 2011 10:23 pm
Posted: Fri Feb 25, 2011 11:35 pm
