Previous Thread  Next Thread
chat icon Texture normal distance has changes between builds
ppeetteerr
Posted: Tue Mar 22, 2011 5:59 pm
I have the official blender beta release, and several other releases running on opensuse 11.4 If I use the official blender beta release and open my file with a cloud texture set at 1.00 I get a different roughness than if I open it in one of the trunk releases. Has this really changed?
Jandals
Posted: Thu May 26, 2011 3:03 am
I haven't opened a single project in different versions of Blender but I have encountered discrepancies in the intensity of texture values I use compared to other artists (who are using a slightly older release). For example, I am recreating a material based on someone else's description. The original artist uses a Cloud texture with Influence > Geometry > Normal set to 0.25. To get the same look I need to divide by about 12 and set my Normal Influence to about .02.
Blender 2.57b 64-bit
Mac OS 10.6.7
For anyone else who runs into this, the difference is caused by changing the Influence > Bump Mapping > Method property. Leaving it at "Default" generally gives me a more exaggerated result, meaning I have to reduce the effect of the bump map. Choosing "Compatible" makes my results conform to the examples I was following.
Jump to:
