Posted: Thu Aug 14, 2003 5:16 pm
Hello,
I am having problems with particle streams not following their parents. The mesh moves fine but the actual particles won't budge.
If I hit the recalculate all button they snap to where they should be but are then stuck there.
I am pretty sure there is a fix for this but have run out of ideas.
Can anyone help?
Thanks
Posted: Thu Aug 14, 2003 5:45 pm
The Ob button controls how much the speed of the object affects the particles.
Posted: Thu Aug 14, 2003 5:48 pm
Where is the Ob button, and what is its function?
Thanks
Posted: Thu Aug 14, 2003 6:27 pm
Sorry. It is on the same window as the other particle controls. It's in the purplish row between Norm and Rand.
Ob controls how much of the emitting object's speed is used as a starting speed for the particles. This is similar to how the Norm button affects how much of the particles speed comes from the vertex normal. ( strictly speaking, we should say 'velocity' instead of 'speed' since we are talking about speed in a particular direction )
For an example, run your particle animation with Ob:0.000 and then run it again with Ob cranked up all the way to Ob:1.000 and you'll see how this works.
Feel free to ask further if I have explained this badly.
Posted: Thu Aug 14, 2003 8:27 pm
Well, I cranked up the Ob button to 1 and it still didn't budge. Any other ideas?
Thanks
Posted: Fri Aug 15, 2003 2:47 am
Perhaps I don't understand what you are trying to do. Do you have a .blend file showing this?
