chat icon Help with F-Curve Actuator - Urgent! Please Help!
Jackson 1
Posted: Mon May 30, 2011 9:02 pm
When I add an IPO actuator/F-Curve Actuator (I'm working in 2.57...), I can't see an option to select or define which animation you want it to play, so, by default, it only plays my first animation.
Can you add multiple animations to a single Empty by selecting a different animation for each F-Curve actuator, or do you have to insert another Empty? If so, how would I go about this, because my Meshes are parented to the Empty I have now, and parenting them to a second Empty results in the "Loop in Parents" error or just generally screwing up the Meshes Sad
This is really my only problem now. But until I know how to do it, I can't continue with the project!
Thanks.
OTO
Posted: Fri Jun 03, 2011 5:29 pm
Hello
Try like this, example:
Animation1 : Frame 1 to 100
Animation2 :Frame 101 to 150
Animation3 : Frame 201 to 400
and so on
Then in Logic Bricks you should use the Start: and End: of F-Curve Actuator to specify each animation will play at a given moment!
Bye
