Error During SVN Update!!
thru2trot
Postby thru2trot » Sat Jul 02, 2011 7:38 pm
Hello everyone,
I am trying to update blender via SVN by running this command:
Code: Select all
cd ~/blender-svn/build; svn up ../blender; make -j3; make install
Everything seems to run with no issues, however, at the very end of the update I get this error:
Code: Select all
Install the project...
-- Install configuration: "Debug"
-- Installing: /opt/blender/bin/blender
CMake Error at source/creator/cmake_install.cmake:40 (FILE):
  file INSTALL cannot copy file "/home/myusername/blender-svn/build/bin/blender"
  to "/opt/blender/bin/blender".
Call Stack (most recent call first):
  cmake_install.cmake:40 (INCLUDE)
make: *** [install] Error 1
I need to also add that the update does indeed go through, given the splash screen and the updated build version. Does anyone have any ideas as to what can be causing this? Any help would be greatly appreciated.
Regards,
thru2trot
thru2trot
Postby thru2trot » Sat Jul 02, 2011 7:46 pm
Hello all,
I know this definitely has something to do with not having permissions to opt, however I tried changing the permissions to the opt folder in root by typing:
Code: Select all
sudo chmod +x opt
, but this did not work. Again, I thank everyone for their help in helping me resolve this.
Best Regards,
thru2trot
stiv
Postby stiv » Sat Jul 02, 2011 9:46 pm
Likely it *is* a permissions problem in writing to a directoy you do not have access to. But...
+x is execute permission, not write.
doing 'sudo chmod +something' will add the +something to the root account, not joe_random_user.
The make install command is failing, not svn update. Those little semi-colons are statement separators.
The chmod manpage is your friend here if you are going to change permissions on a system dir. Did you try
sudo make install ?
thru2trot
Postby thru2trot » Sun Jul 03, 2011 4:48 am
Hello Stiv,
Thank you much for the response, the:
Code: Select all
sudo make install
seems to have done the trick, however, now I'm getting a different error:
Code: Select all
CMake Error at source/creator/cmake_install.cmake:96 (FILE):
  file INSTALL cannot find "//python3.2".
I will tell you if I run:
Code: Select all
python
in the terminal on Ubuntu 10.10 then python2.6 launches, however, if I do:
Code: Select all
python3
, then python 3.2 launches. I'm pretty sure this has to do with me not having python3.2 set as my system python, instead python 2.6 seems to be my system python instead. In the past I have tried to resolve this with no success.
Again, your help is greatly appreciated.
Best Regards,
thru2trot
stiv
Postby stiv » Sun Jul 03, 2011 2:11 pm
As long as you have python3 source (libs and headers installed), it does not matter whether py 2 or py 3 is your system python.
I confess I have not played with cmake and blender together, but the 'usual' location for system thingies is /usr.
We are looking for /usr/lib/python3.2. If your python3.2 stuff is installed in /usr/local or somewhere else, you will need to set the paths for cmake.
Doing this is left as an exercise for the reader. (yeah, that is a clever way of saying I do not know how, off the top of my head)
thru2trot
Postby thru2trot » Sun Jul 03, 2011 10:59 pm
Hello Stiv,
Again, i thank you for the clarity. And once again you're right, /usr/lib/python3.2 is where python should be installed and I can confirm this is where I have it installed. The question seems to be whether or not CMAKE knows that. I have tried to set up a symbolic link in the past only with the result of screwing up my system. So I'm in the same boat you are in not knowing how to do this properly. I'm sure there must be a way to do it through CMAKE as well.
And now, what puzzling me is the fact that I'm getting this error when trying to launch blender 2.5 from the Terminal:
Code: Select all
:~$ blender
Info: Config directory with "startup.blend" file not found.
found bundled python: /opt/blender/share/blender/2.58/python
Fatal Python error: Py_Initialize: Unable to get the locale encoding
LookupError: no codec search functions registered: can't find encoding
Aborted
Best Regards,
freesparks
hps
can't find encoding ..
Postby hps » Fri Oct 28, 2011 3:04 pm
On Fedora 16 I had to create a link within the blender make path to lib64:
cd /home/YOU/Downloads/cmake-make/bin/2.60/python/
ln -s lib lib64
SirDude
Postby SirDude » Fri Oct 28, 2011 3:27 pm
Does /opt/blender/bin exist?
and do you have write permission to it?
KIAaze
Postby KIAaze » Sun Nov 11, 2012 12:55 am
I'm having the same problem now with:
Code: Select all
And I also don't have python3 installed system-wide, since I still use Ubuntu 10.04.
i.e., I need to type python3 to run python3.
Have you managed to solve the problem?
I'm trying to compile blender 2.64a.
Here's my current CMakeCache.txt:
Code: Select all
# This is the CMakeCache file.
# For build in directory: /opt/blender-2.64a_built_from_source
# It was generated by CMake: /usr/bin/cmake
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Value Computed by CMake
Blender_BINARY_DIR:STATIC=/opt/blender-2.64a_built_from_source
Blender_SOURCE_DIR:STATIC=/home/USER/src/blender-2.64a
//The Boost FILESYSTEM library
Boost_FILESYSTEM_LIBRARY:FILEPATH=/usr/lib/libboost_filesystem-mt.so
//Path to a library.
Boost_FILESYSTEM_LIBRARY_DEBUG:FILEPATH=Boost_FILESYSTEM_LIBRARY_DEBUG-NOTFOUND
Boost_FILESYSTEM_LIBRARY_RELEASE:FILEPATH=/usr/lib/libboost_filesystem-mt.so
//Path to a file.
Boost_INCLUDE_DIR:PATH=/usr/include
//Boost library directory
Boost_LIBRARY_DIRS:FILEPATH=/usr/lib
//The Boost REGEX library
Boost_REGEX_LIBRARY:FILEPATH=/usr/lib/libboost_regex-mt.so
Boost_REGEX_LIBRARY_DEBUG:FILEPATH=Boost_REGEX_LIBRARY_DEBUG-NOTFOUND
Boost_REGEX_LIBRARY_RELEASE:FILEPATH=/usr/lib/libboost_regex-mt.so
//The Boost SYSTEM library
Boost_SYSTEM_LIBRARY:FILEPATH=/usr/lib/libboost_system-mt.so
Boost_SYSTEM_LIBRARY_DEBUG:FILEPATH=Boost_SYSTEM_LIBRARY_DEBUG-NOTFOUND
Boost_SYSTEM_LIBRARY_RELEASE:FILEPATH=/usr/lib/libboost_system-mt.so
//The Boost THREAD library
Boost_THREAD_LIBRARY:FILEPATH=/usr/lib/libboost_thread-mt.so
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=Boost_THREAD_LIBRARY_DEBUG-NOTFOUND
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=/usr/lib/libboost_thread-mt.so
//Path to a program.
CMAKE_AR:FILEPATH=/usr/bin/ar
//Choose the type of build, options are: None(CMAKE_CXX_FLAGS or
// CMAKE_C_FLAGS used) Debug Release RelWithDebInfo MinSizeRel.
CMAKE_BUILD_TYPE:STRING=Release
//Enable/Disable color output during build.
CMAKE_COLOR_MAKEFILE:BOOL=ON
//CXX compiler.
CMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++
//Flags used by the compiler during all build types.
CMAKE_CXX_FLAGS:STRING=-L/home/USER/opt/lib
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=-g
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
CMAKE_CXX_FLAGS_RELEASE:STRING=-O2 -DNDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
CMAKE_CXX_STANDARD_LIBRARIES:STRING=
//C compiler.
CMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc
CMAKE_C_FLAGS:STRING=
CMAKE_C_FLAGS_DEBUG:STRING=-g
CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
CMAKE_C_FLAGS_RELEASE:STRING=-O2 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
CMAKE_C_STANDARD_LIBRARIES:STRING=
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=/opt/
CMAKE_LINKER:FILEPATH=/usr/bin/ld
CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_NM:FILEPATH=/usr/bin/nm
CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy
CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump
CMAKE_PROJECT_NAME:STATIC=Blender
CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
CMAKE_STRIP:FILEPATH=/usr/bin/strip
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make.  This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//Enable to build TBZ2 source packages
CPACK_SOURCE_TBZ2:BOOL=ON
//Enable to build TGZ source packages
CPACK_SOURCE_TGZ:BOOL=ON
//Enable to build TZ source packages
CPACK_SOURCE_TZ:BOOL=ON
//Enable to build ZIP source packages
CPACK_SOURCE_ZIP:BOOL=OFF
//CUDA architectures to build binaries for
CYCLES_CUDA_BINARIES_ARCH:STRING=sm_13;sm_20;sm_21;sm_30
//Path to a file.
FREETYPE_INCLUDE_DIR_freetype2:PATH=/usr/include/freetype2
//Path to a file.
FREETYPE_INCLUDE_DIR_ft2build:PATH=/usr/include
FREETYPE_LIBRARY:FILEPATH=/usr/lib/libfreetype.so
//The directory where GL/glew.h resides
GLEW_INCLUDE_PATH:PATH=/usr/include
//The GLEW library
GLEW_LIBRARY:FILEPATH=/usr/lib/libGLEW.so
ICONV_LIBRARY:FILEPATH=ICONV_LIBRARY-NOTFOUND
INTL_LIBRARY:FILEPATH=INTL_LIBRARY-NOTFOUND
//Path to a file.
JPEG_INCLUDE_DIR:PATH=/usr/include
JPEG_LIBRARY:FILEPATH=/usr/lib/libjpeg.so
LD_LIBRARY_PATH:STRING=/home/USER/opt/lib
//Path to a file.
OPENAL_INCLUDE_DIR:PATH=/usr/include/AL
OPENAL_LIBRARY:FILEPATH=/usr/lib/libopenal.so
//Path to a file.
OPENCOLORIO_INCLUDE_DIR:PATH=OPENCOLORIO_INCLUDE_DIR-NOTFOUND
OPENCOLORIO_OPENCOLORIO_LIBRARY:FILEPATH=OPENCOLORIO_OPENCOLORIO_LIBRARY-NOTFOUND
OPENCOLORIO_TINYXML_LIBRARY:FILEPATH=OPENCOLORIO_TINYXML_LIBRARY-NOTFOUND
OPENCOLORIO_YAML-CPP_LIBRARY:FILEPATH=OPENCOLORIO_YAML-CPP_LIBRARY-NOTFOUND
OPENEXR_HALF_LIBRARY:FILEPATH=/usr/lib/libHalf.so
OPENEXR_IEX_LIBRARY:FILEPATH=/usr/lib/libIex.so
OPENEXR_ILMIMF_LIBRARY:FILEPATH=/usr/lib/libIlmImf.so
OPENEXR_ILMTHREAD_LIBRARY:FILEPATH=/usr/lib/libIlmThread.so
OPENEXR_IMATH_LIBRARY:FILEPATH=/usr/lib/libImath.so
//Path to a file.
OPENEXR_INCLUDE_DIR:PATH=/usr/include/OpenEXR
//Path to a file.
OPENGL_INCLUDE_DIR:PATH=/usr/include
OPENGL_gl_LIBRARY:FILEPATH=/usr/lib/libGL.so
OPENGL_glu_LIBRARY:FILEPATH=/usr/lib/libGLU.so
//Path to a file.
OPENGL_xmesa_INCLUDE_DIR:PATH=OPENGL_xmesa_INCLUDE_DIR-NOTFOUND
//Path to a file.
OPENIMAGEIO_INCLUDE_DIR:PATH=OPENIMAGEIO_INCLUDE_DIR-NOTFOUND
OPENIMAGEIO_LIBRARY:FILEPATH=OPENIMAGEIO_LIBRARY-NOTFOUND
//Path to a file.
OPENJPEG_INCLUDE_DIR:PATH=/usr/include
OPENJPEG_LIBRARY:FILEPATH=/usr/lib/libopenjpeg.so
//C++ compiler flags for OpenMP parallization
OpenMP_CXX_FLAGS:STRING=-fopenmp
//C compiler flags for OpenMP parallization
OpenMP_C_FLAGS:STRING=-fopenmp
PNG_LIBRARY:FILEPATH=/usr/lib/libpng.so
//Path to a file.
PNG_PNG_INCLUDE_DIR:PATH=/usr/include
PYTHON_INCLUDE_DIR:STRING=/home/USER/opt/include/python3.2m
PYTHON_LIBPATH:STRING=/home/USER/opt/lib
PYTHON_LIBRARY:STRING=-lpthread -ldl -lutil -lm -lpython3.2m
//Linker flags for python
PYTHON_LINKFLAGS:STRING=-Xlinker -export-dynamic
//Path to a file.
PYTHON_NUMPY_PATH:PATH=/home/USER/opt/lib/python3.2/site-packages/
//Python Version (major and minor only)
PYTHON_VERSION:STRING=3.2
RPMBUILD:FILEPATH=/usr/bin/rpmbuild
SDLMAIN_LIBRARY:FILEPATH=/usr/lib/libSDLmain.a
//Path to a file.
SDL_INCLUDE_DIR:PATH=/usr/include/SDL
//Where the SDL Library can be found
SDL_LIBRARY:STRING=/usr/lib/libSDLmain.a;/usr/lib/libSDL.so;-lpthread
//Path to a file.
SPACENAV_INCLUDE_DIR:PATH=/usr/include
SPACENAV_LIBRARY:FILEPATH=/usr/lib/libspnav.a
//subversion command line client
Subversion_SVN_EXECUTABLE:FILEPATH=/usr/bin/svn
//Path to a file.
TIFF_INCLUDE_DIR:PATH=/usr/include
TIFF_LIBRARY:FILEPATH=/usr/lib/libtiff.so
//Call abort() when raising an assertion through BLI_assert()
WITH_ASSERT_ABORT:BOOL=OFF
//Build with blenders audio library (only disable if you know what
// you're doing!)
WITH_AUDASPACE:BOOL=ON
//Build blender (disable to build only the blender player)
WITH_BLENDER:BOOL=ON
//Include extra build details (only disable for development & faster
// builds)
WITH_BUILDINFO:BOOL=ON
//Enable Bullet (Physics Engine)
WITH_BULLET:BOOL=ON
//Enable Blenders own AVI file support (raw/jpeg)
WITH_CODEC_AVI:BOOL=ON
//Enable FFMPeg Support (http://ffmpeg.org)
WITH_CODEC_FFMPEG:BOOL=OFF
//Enable libsndfile Support (http://www.mega-nerd.com/libsndfile)
WITH_CODEC_SNDFILE:BOOL=OFF
//Enable the tile based nodal compositor
WITH_COMPOSITOR:BOOL=ON
//Enable legacy compositor
WITH_COMPOSITOR_LEGACY:BOOL=OFF
//Enable GuardedAlloc for C++ memory allocation tracking (only
// enable for development)
WITH_CXX_GUARDEDALLOC:BOOL=OFF
//Enable cycles Render Engine
WITH_CYCLES:BOOL=OFF
//Build cycles CUDA binaries
WITH_CYCLES_CUDA_BINARIES:BOOL=OFF
//Build Cycles with OSL support
WITH_CYCLES_OSL:BOOL=OFF
//Build cycles test application
WITH_CYCLES_TEST:BOOL=OFF
//Enable FFTW3 support (Used for smoke and audio effects)
WITH_FFTW3:BOOL=OFF
//Enable Game Engine
WITH_GAMEENGINE:BOOL=ON
//Enable debugging output for the GHOST library
WITH_GHOST_DEBUG:BOOL=OFF
//Enable building blender against SDL for windowing rather then
// the native APIs
WITH_GHOST_SDL:BOOL=OFF
//Enable drag'n'drop support on Linux using XDND protocol
WITH_GHOST_XDND:BOOL=ON
//Build without graphical support (renderfarm, server mode only)
WITH_HEADLESS:BOOL=OFF
//Enable ITASC IK solver (only disable for development & for incompatible
// C++ compilers)
WITH_IK_ITASC:BOOL=ON
//Enable Legacy IK solver (only disable for development)
WITH_IK_SOLVER:BOOL=ON
//Enable CINEON and DPX Image Support
WITH_IMAGE_CINEON:BOOL=ON
//Enable DDS Image Support
WITH_IMAGE_DDS:BOOL=ON
//Enable image FrameServer Support for rendering
WITH_IMAGE_FRAMESERVER:BOOL=ON
//Enable HDR Image Support
WITH_IMAGE_HDR:BOOL=ON
//Enable OpenEXR Support (http://www.openexr.com)
WITH_IMAGE_OPENEXR:BOOL=ON
//Enable OpenJpeg Support (http://www.openjpeg.org)
WITH_IMAGE_OPENJPEG:BOOL=ON
//Enable RedCode Image Support
WITH_IMAGE_REDCODE:BOOL=OFF
//Enable LibTIFF Support
WITH_IMAGE_TIFF:BOOL=ON
//Enable NDOF input devices (SpaceNavigator and friends)
WITH_INPUT_NDOF:BOOL=ON
//Install redistributeable runtime, otherwise install into CMAKE_INSTALL_PREFIX
WITH_INSTALL_PORTABLE:BOOL=ON
//Enable I18N (International fonts and text)
WITH_INTERNATIONAL:BOOL=ON
//Enable Jack Support (http://www.jackaudio.org)
WITH_JACK:BOOL=OFF
//Enable libmv structure from motion library
WITH_LIBMV:BOOL=ON
//Use LLVM
WITH_LLVM:BOOL=OFF
//Enable best LZMA compression, (used for pointcache)
WITH_LZMA:BOOL=ON
//Enable fast LZO compression (used for pointcache)
WITH_LZO:BOOL=ON
//Enable malloc replacement (http://www.canonware.com/jemalloc)
WITH_MEM_JEMALLOC:BOOL=OFF
//Enable Boolean Modifier
WITH_MOD_BOOLEAN:BOOL=ON
//Enable Experimental cloth solver
WITH_MOD_CLOTH_ELTOPO:BOOL=OFF
//Enable Decimate Modifier
WITH_MOD_DECIMATE:BOOL=ON
//Enable Elbeem Modifier (Fluid Simulation)
WITH_MOD_FLUID:BOOL=ON
//Enable Ocean Modifier
WITH_MOD_OCEANSIM:BOOL=OFF
//Enable Remesh Modifier
WITH_MOD_REMESH:BOOL=ON
//Enable Smoke Modifier (Smoke Simulation)
WITH_MOD_SMOKE:BOOL=ON
//Enable OpenAL Support (http://www.openal.org)
WITH_OPENAL:BOOL=ON
//Enable OpenCollada Support (http://www.opencollada.org)
WITH_OPENCOLLADA:BOOL=OFF
//Enable OpenColorIO color management
WITH_OPENCOLORIO:BOOL=ON
//Enable OpenMP (has to be supported by the compiler)
WITH_OPENMP:BOOL=ON
//Build Player
WITH_PLAYER:BOOL=OFF
//Enable Embedded Python API  (only disable for development)
WITH_PYTHON:BOOL=ON
//Copy system python into the blender install folder
WITH_PYTHON_INSTALL:BOOL=ON
//Copy system numpy into the blender install folder
WITH_PYTHON_INSTALL_NUMPY:BOOL=ON
//Enable building as a python module which runs without a user
// interface, like running regular blender in background mode (experimental,
// only enable for development)
WITH_PYTHON_MODULE:BOOL=OFF
//Enable internal API error checking to track invalid data to prevent
// crash on access (at the expense of some effeciency, only enable
// for development).
WITH_PYTHON_SAFETY:BOOL=OFF
//Disables execution of scripts within blend files by default (recommend
// to leave off)
WITH_PYTHON_SECURITY:BOOL=OFF
//Enable use of SIMD (SSE) optimizations for the raytracer
WITH_RAYOPTIMIZATION:BOOL=ON
//Enable SDL for sound and joystick support
WITH_SDL:BOOL=ON
//Use GLEW OpenGL wrapper library provided by the operating system
WITH_SYSTEM_GLEW:BOOL=ON
//Use the operating systems OpenJPEG library
WITH_SYSTEM_OPENJPEG:BOOL=ON
//Enable X11 video mode switching
WITH_X11_XF86VMODE:BOOL=ON
//Enable X11 Xinput (tablet support and unicode input)
WITH_X11_XINPUT:BOOL=ON
//Path to a file.
X11_ICE_INCLUDE_PATH:PATH=/usr/include
X11_ICE_LIB:FILEPATH=/usr/lib/libICE.so
X11_SM_LIB:FILEPATH=/usr/lib/libSM.so
//Path to a file.
X11_X11_INCLUDE_PATH:PATH=/usr/include
X11_X11_LIB:FILEPATH=/usr/lib/libX11.so
//Path to a file.
X11_XF86keysym_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_XShm_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_XTest_INCLUDE_PATH:PATH=X11_XTest_INCLUDE_PATH-NOTFOUND
X11_XTest_LIB:FILEPATH=X11_XTest_LIB-NOTFOUND
//Path to a file.
X11_Xaccessrules_INCLUDE_PATH:PATH=X11_Xaccessrules_INCLUDE_PATH-NOTFOUND
//Path to a file.
X11_Xaccessstr_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xau_INCLUDE_PATH:PATH=/usr/include
X11_Xau_LIB:FILEPATH=/usr/lib/libXau.so
//Path to a file.
X11_Xcomposite_INCLUDE_PATH:PATH=/usr/include
X11_Xcomposite_LIB:FILEPATH=/usr/lib/libXcomposite.so
//Path to a file.
X11_Xcursor_INCLUDE_PATH:PATH=/usr/include
X11_Xcursor_LIB:FILEPATH=/usr/lib/libXcursor.so
//Path to a file.
X11_Xdamage_INCLUDE_PATH:PATH=/usr/include
X11_Xdamage_LIB:FILEPATH=/usr/lib/libXdamage.so
//Path to a file.
X11_Xdmcp_INCLUDE_PATH:PATH=/usr/include
X11_Xdmcp_LIB:FILEPATH=/usr/lib/libXdmcp.so
X11_Xext_LIB:FILEPATH=/usr/lib/libXext.so
//Path to a file.
X11_Xfixes_INCLUDE_PATH:PATH=/usr/include
X11_Xfixes_LIB:FILEPATH=/usr/lib/libXfixes.so
//Path to a file.
X11_Xft_INCLUDE_PATH:PATH=/usr/include
X11_Xft_LIB:FILEPATH=/usr/lib/libXft.so
//Path to a file.
X11_Xinerama_INCLUDE_PATH:PATH=/usr/include
X11_Xinerama_LIB:FILEPATH=/usr/lib/libXinerama.so
//Path to a file.
X11_Xinput_INCLUDE_PATH:PATH=/usr/include
X11_Xinput_LIB:FILEPATH=/usr/lib/libXi.so
//Path to a file.
X11_Xkb_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xkblib_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xlib_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xpm_INCLUDE_PATH:PATH=/usr/include
X11_Xpm_LIB:FILEPATH=/usr/lib/libXpm.so
//Path to a file.
X11_Xrandr_INCLUDE_PATH:PATH=/usr/include
X11_Xrandr_LIB:FILEPATH=/usr/lib/libXrandr.so
//Path to a file.
X11_Xrender_INCLUDE_PATH:PATH=/usr/include
X11_Xrender_LIB:FILEPATH=/usr/lib/libXrender.so
//Path to a file.
X11_Xscreensaver_INCLUDE_PATH:PATH=/usr/include
X11_Xscreensaver_LIB:FILEPATH=/usr/lib/libXss.so
//Path to a file.
X11_Xshape_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xt_INCLUDE_PATH:PATH=/usr/include
X11_Xt_LIB:FILEPATH=/usr/lib/libXt.so
//Path to a file.
X11_Xutil_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_Xv_INCLUDE_PATH:PATH=/usr/include
X11_Xv_LIB:FILEPATH=/usr/lib/libXv.so
X11_Xxf86misc_LIB:FILEPATH=X11_Xxf86misc_LIB-NOTFOUND
X11_Xxf86vmode_LIB:FILEPATH=/usr/lib/libXxf86vm.so
//Path to a file.
X11_dpms_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
X11_xf86misc_INCLUDE_PATH:PATH=X11_xf86misc_INCLUDE_PATH-NOTFOUND
//Path to a file.
X11_xf86vmode_INCLUDE_PATH:PATH=/usr/include
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=/usr/include
ZLIB_LIBRARY:FILEPATH=/usr/lib/libz.so
//Dependencies for target
bf_avi_LIB_DEPENDS:STATIC=
bf_blenfont_LIB_DEPENDS:STATIC=
bf_blenkernel_LIB_DEPENDS:STATIC=
bf_blenlib_LIB_DEPENDS:STATIC=
bf_blenloader_LIB_DEPENDS:STATIC=
bf_bmesh_LIB_DEPENDS:STATIC=
bf_compositor_LIB_DEPENDS:STATIC=
bf_dna_LIB_DEPENDS:STATIC=
bf_dna_blenlib_LIB_DEPENDS:STATIC=
bf_editor_animation_LIB_DEPENDS:STATIC=
bf_editor_armature_LIB_DEPENDS:STATIC=
bf_editor_curve_LIB_DEPENDS:STATIC=
bf_editor_datafiles_LIB_DEPENDS:STATIC=
bf_editor_gpencil_LIB_DEPENDS:STATIC=
bf_editor_interface_LIB_DEPENDS:STATIC=
bf_editor_io_LIB_DEPENDS:STATIC=
bf_editor_mask_LIB_DEPENDS:STATIC=
bf_editor_mesh_LIB_DEPENDS:STATIC=
bf_editor_metaball_LIB_DEPENDS:STATIC=
bf_editor_object_LIB_DEPENDS:STATIC=
bf_editor_physics_LIB_DEPENDS:STATIC=
bf_editor_render_LIB_DEPENDS:STATIC=
bf_editor_screen_LIB_DEPENDS:STATIC=
bf_editor_sculpt_paint_LIB_DEPENDS:STATIC=
bf_editor_sound_LIB_DEPENDS:STATIC=
bf_editor_space_action_LIB_DEPENDS:STATIC=
bf_editor_space_api_LIB_DEPENDS:STATIC=
bf_editor_space_buttons_LIB_DEPENDS:STATIC=
bf_editor_space_clip_LIB_DEPENDS:STATIC=
bf_editor_space_console_LIB_DEPENDS:STATIC=
bf_editor_space_file_LIB_DEPENDS:STATIC=
bf_editor_space_graph_LIB_DEPENDS:STATIC=
bf_editor_space_image_LIB_DEPENDS:STATIC=
bf_editor_space_info_LIB_DEPENDS:STATIC=
bf_editor_space_logic_LIB_DEPENDS:STATIC=
bf_editor_space_nla_LIB_DEPENDS:STATIC=
bf_editor_space_node_LIB_DEPENDS:STATIC=
bf_editor_space_outliner_LIB_DEPENDS:STATIC=
bf_editor_space_script_LIB_DEPENDS:STATIC=
bf_editor_space_sequencer_LIB_DEPENDS:STATIC=
bf_editor_space_time_LIB_DEPENDS:STATIC=
bf_editor_space_userpref_LIB_DEPENDS:STATIC=
bf_editor_space_view3d_LIB_DEPENDS:STATIC=
bf_editor_text_LIB_DEPENDS:STATIC=
bf_editor_transform_LIB_DEPENDS:STATIC=
bf_editor_util_LIB_DEPENDS:STATIC=
bf_editor_uvedit_LIB_DEPENDS:STATIC=
bf_gpu_LIB_DEPENDS:STATIC=
bf_ikplugin_LIB_DEPENDS:STATIC=
bf_imbuf_LIB_DEPENDS:STATIC=
bf_imbuf_cineon_LIB_DEPENDS:STATIC=
bf_imbuf_dds_LIB_DEPENDS:STATIC=
bf_imbuf_openexr_LIB_DEPENDS:STATIC=
bf_intern_audaspace_LIB_DEPENDS:STATIC=
bf_intern_bsp_LIB_DEPENDS:STATIC=
bf_intern_ctr_LIB_DEPENDS:STATIC=
bf_intern_decimate_LIB_DEPENDS:STATIC=
bf_intern_dualcon_LIB_DEPENDS:STATIC=
bf_intern_elbeem_LIB_DEPENDS:STATIC=
bf_intern_ghost_LIB_DEPENDS:STATIC=
bf_intern_guardedalloc_LIB_DEPENDS:STATIC=
bf_intern_iksolver_LIB_DEPENDS:STATIC=
bf_intern_itasc_LIB_DEPENDS:STATIC=
bf_intern_memutil_LIB_DEPENDS:STATIC=
bf_intern_mikktspace_LIB_DEPENDS:STATIC=
bf_intern_moto_LIB_DEPENDS:STATIC=
bf_intern_opencolorio_LIB_DEPENDS:STATIC=
bf_intern_opennl_LIB_DEPENDS:STATIC=
bf_intern_raskter_LIB_DEPENDS:STATIC=
bf_intern_smoke_LIB_DEPENDS:STATIC=
bf_intern_string_LIB_DEPENDS:STATIC=
bf_modifiers_LIB_DEPENDS:STATIC=
bf_nodes_LIB_DEPENDS:STATIC=
bf_opencl_LIB_DEPENDS:STATIC=
bf_python_LIB_DEPENDS:STATIC=
bf_python_bmesh_LIB_DEPENDS:STATIC=
bf_python_ext_LIB_DEPENDS:STATIC=
bf_python_mathutils_LIB_DEPENDS:STATIC=
bf_render_LIB_DEPENDS:STATIC=
bf_rna_LIB_DEPENDS:STATIC=
bf_windowmanager_LIB_DEPENDS:STATIC=
extern_binreloc_LIB_DEPENDS:STATIC=
extern_bullet_LIB_DEPENDS:STATIC=
extern_carve_LIB_DEPENDS:STATIC=
extern_ceres_LIB_DEPENDS:STATIC=
extern_colamd_LIB_DEPENDS:STATIC=
extern_libmv_LIB_DEPENDS:STATIC=
extern_lzma_LIB_DEPENDS:STATIC=
extern_minilzo_LIB_DEPENDS:STATIC=
extern_recastnavigation_LIB_DEPENDS:STATIC=
extern_xdnd_LIB_DEPENDS:STATIC=
ge_blen_routines_LIB_DEPENDS:STATIC=
ge_converter_LIB_DEPENDS:STATIC=
ge_logic_LIB_DEPENDS:STATIC=
ge_logic_expressions_LIB_DEPENDS:STATIC=
ge_logic_ketsji_LIB_DEPENDS:STATIC=
ge_logic_loopbacknetwork_LIB_DEPENDS:STATIC=
ge_logic_network_LIB_DEPENDS:STATIC=
ge_logic_ngnetwork_LIB_DEPENDS:STATIC=
ge_oglrasterizer_LIB_DEPENDS:STATIC=
ge_phys_bullet_LIB_DEPENDS:STATIC=
ge_phys_common_LIB_DEPENDS:STATIC=
ge_phys_dummy_LIB_DEPENDS:STATIC=
ge_rasterizer_LIB_DEPENDS:STATIC=
ge_scenegraph_LIB_DEPENDS:STATIC=
ge_videotex_LIB_DEPENDS:STATIC=
# INTERNAL cache entries
//Whether the Boost FILESYSTEM library found
Boost_FILESYSTEM_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_FILESYSTEM_LIBRARY
Boost_FILESYSTEM_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_FILESYSTEM_LIBRARY_DEBUG
Boost_FILESYSTEM_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_FILESYSTEM_LIBRARY_RELEASE
Boost_FILESYSTEM_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_LIBRARY_DIRS
Boost_LIBRARY_DIRS-ADVANCED:INTERNAL=1
//The library version string for boost libraries
Boost_LIB_VERSION:INTERNAL=1_40
//Whether the Boost REGEX library found
Boost_REGEX_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_REGEX_LIBRARY
Boost_REGEX_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_REGEX_LIBRARY_DEBUG
Boost_REGEX_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_REGEX_LIBRARY_RELEASE
Boost_REGEX_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Whether the Boost SYSTEM library found
Boost_SYSTEM_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_SYSTEM_LIBRARY
Boost_SYSTEM_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_SYSTEM_LIBRARY_DEBUG
Boost_SYSTEM_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_SYSTEM_LIBRARY_RELEASE
Boost_SYSTEM_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Whether the Boost THREAD library found
Boost_THREAD_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_THREAD_LIBRARY
Boost_THREAD_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//The version number for boost libraries
Boost_VERSION:INTERNAL=104000
//ADVANCED property for variable: CMAKE_AR
CMAKE_AR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=/opt/blender-2.64a_built_from_source
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=8
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=1
//ADVANCED property for variable: CMAKE_COLOR_MAKEFILE
CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=/usr/bin/cmake
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=/usr/bin/cpack
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=/usr/bin/ctest
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Result of TRY_COMPILE
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=/usr/bin/cmake-gui
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Unix Makefiles
//Have function connect
CMAKE_HAVE_CONNECT:INTERNAL=1
//Have function gethostbyname
CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1
//Have library pthreads
CMAKE_HAVE_PTHREADS_CREATE:INTERNAL=
CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1
//Have include CMAKE_HAVE_PTHREAD_H
CMAKE_HAVE_PTHREAD_H:INTERNAL=1
//Have function remove
CMAKE_HAVE_REMOVE:INTERNAL=1
//Have function shmat
CMAKE_HAVE_SHMAT:INTERNAL=1
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=/home/USER/src/blender-2.64a
//Install .so files without execute permission.
CMAKE_INSTALL_SO_NO_EXE:INTERNAL=1
//Have library ICE
CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_NM
CMAKE_NM-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=119
//ADVANCED property for variable: CMAKE_OBJCOPY
CMAKE_OBJCOPY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_OBJDUMP
CMAKE_OBJDUMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_RANLIB
CMAKE_RANLIB-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=/usr/share/cmake-2.8
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//CHECK_TYPE_SIZE: sizeof(unsigned short)
CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=2
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STRIP
CMAKE_STRIP-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
//uname command
CMAKE_UNAME:INTERNAL=/bin/uname
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_SOURCE_TBZ2
CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_SOURCE_TGZ
CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_SOURCE_TZ
CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_SOURCE_ZIP
CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1
//Test CXX_WARN_ALL
CXX_WARN_ALL:INTERNAL=1
//Test CXX_WARN_INIT_SELF
CXX_WARN_INIT_SELF:INTERNAL=1
//Test CXX_WARN_LOGICAL_OP
CXX_WARN_LOGICAL_OP:INTERNAL=1
//Test CXX_WARN_MISSING_DECLARATIONS
CXX_WARN_MISSING_DECLARATIONS:INTERNAL=1
//Test CXX_WARN_MISSING_INCLUDE_DIRS
CXX_WARN_MISSING_INCLUDE_DIRS:INTERNAL=1
//Test CXX_WARN_NO_DIV_BY_ZERO
CXX_WARN_NO_DIV_BY_ZERO:INTERNAL=1
//Test CXX_WARN_NO_INVALID_OFFSETOF
CXX_WARN_NO_INVALID_OFFSETOF:INTERNAL=1
//Test CXX_WARN_NO_SIGN_COMPARE
CXX_WARN_NO_SIGN_COMPARE:INTERNAL=1
//Test CXX_WARN_UNDEF
CXX_WARN_UNDEF:INTERNAL=1
//Test CXX_WARN_UNINITIALIZED
CXX_WARN_UNINITIALIZED:INTERNAL=1
//ADVANCED property for variable: CYCLES_CUDA_BINARIES_ARCH
CYCLES_CUDA_BINARIES_ARCH-ADVANCED:INTERNAL=1
//Test C_WARN_ALL
C_WARN_ALL:INTERNAL=1
//Test C_WARN_CAST_ALIGN
C_WARN_CAST_ALIGN:INTERNAL=1
//Test C_WARN_ERROR_DECLARATION_AFTER_STATEMENT
C_WARN_ERROR_DECLARATION_AFTER_STATEMENT:INTERNAL=1
//Test C_WARN_ERROR_IMPLICIT_FUNCTION_DECLARATION
C_WARN_ERROR_IMPLICIT_FUNCTION_DECLARATION:INTERNAL=1
//Test C_WARN_ERROR_RETURN_TYPE
C_WARN_ERROR_RETURN_TYPE:INTERNAL=1
//Test C_WARN_INIT_SELF
C_WARN_INIT_SELF:INTERNAL=1
//Test C_WARN_LOGICAL_OP
C_WARN_LOGICAL_OP:INTERNAL=1
//Test C_WARN_MISSING_INCLUDE_DIRS
C_WARN_MISSING_INCLUDE_DIRS:INTERNAL=1
//Test C_WARN_MISSING_PROTOTYPES
C_WARN_MISSING_PROTOTYPES:INTERNAL=1
//Test C_WARN_NO_CHAR_SUBSCRIPTS
C_WARN_NO_CHAR_SUBSCRIPTS:INTERNAL=1
//Test C_WARN_NO_DEPRECATED_DECLARATIONS
C_WARN_NO_DEPRECATED_DECLARATIONS:INTERNAL=1
//Test C_WARN_NO_DIV_BY_ZERO
C_WARN_NO_DIV_BY_ZERO:INTERNAL=1
//Test C_WARN_NO_ERROR_UNUSED_BUT_SET_VARIABLE
C_WARN_NO_ERROR_UNUSED_BUT_SET_VARIABLE:INTERNAL=
//Test C_WARN_NO_NULL
C_WARN_NO_NULL:INTERNAL=1
//Test C_WARN_NO_UNKNOWN_PRAGMAS
C_WARN_NO_UNKNOWN_PRAGMAS:INTERNAL=1
//Test C_WARN_NO_UNUSED_PARAMETER
C_WARN_NO_UNUSED_PARAMETER:INTERNAL=1
//Test C_WARN_POINTER_ARITH
C_WARN_POINTER_ARITH:INTERNAL=1
//Test C_WARN_STRICT_PROTOTYPES
C_WARN_STRICT_PROTOTYPES:INTERNAL=1
//Test C_WARN_UNDEF
C_WARN_UNDEF:INTERNAL=1
//Test C_WARN_UNINITIALIZED
C_WARN_UNINITIALIZED:INTERNAL=1
//Test C_WARN_UNUSED_PARAMETER
C_WARN_UNUSED_PARAMETER:INTERNAL=1
//Test C_WARN_WRITE_STRINGS
C_WARN_WRITE_STRINGS:INTERNAL=1
EXECUTABLE_OUTPUT_PATH:INTERNAL=/opt/blender-2.64a_built_from_source/bin
//Details about finding Freetype
FIND_PACKAGE_MESSAGE_DETAILS_Freetype:INTERNAL=[/usr/lib/libfreetype.so][/usr/include;/usr/include/freetype2]
//Details about finding JPEG
FIND_PACKAGE_MESSAGE_DETAILS_JPEG:INTERNAL=[/usr/lib/libjpeg.so][/usr/include]
//Details about finding OpenEXR
FIND_PACKAGE_MESSAGE_DETAILS_OpenEXR:INTERNAL=[/usr/lib/libHalf.so;/usr/lib/libIex.so;/usr/lib/libIlmImf.so;/usr/lib/libIlmThread.so;/usr/lib/libImath.so][/usr/include/OpenEXR]
//Details about finding OpenJPEG
FIND_PACKAGE_MESSAGE_DETAILS_OpenJPEG:INTERNAL=[/usr/lib/libopenjpeg.so][/usr/include]
//Details about finding OpenMP
FIND_PACKAGE_MESSAGE_DETAILS_OpenMP:INTERNAL=[-fopenmp][-fopenmp]
//Details about finding PNG
FIND_PACKAGE_MESSAGE_DETAILS_PNG:INTERNAL=[/usr/lib/libpng.so][/usr/include]
//Details about finding PythonLibsUnix
FIND_PACKAGE_MESSAGE_DETAILS_PythonLibsUnix:INTERNAL=[-lpthread -ldl -lutil -lm -lpython3.2m][/home/USER/opt/include/python3.2m]
//Details about finding Spacenav
FIND_PACKAGE_MESSAGE_DETAILS_Spacenav:INTERNAL=[/usr/lib/libspnav.a][/usr/include]
//Details about finding TIFF
FIND_PACKAGE_MESSAGE_DETAILS_TIFF:INTERNAL=[/usr/lib/libtiff.so][/usr/include]
//Details about finding Threads
FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE]
//Details about finding X11
FIND_PACKAGE_MESSAGE_DETAILS_X11:INTERNAL=[/usr/lib/libX11.so][/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include]
//Details about finding ZLIB
FIND_PACKAGE_MESSAGE_DETAILS_ZLIB:INTERNAL=[/usr/lib/libz.so][/usr/include]
//ADVANCED property for variable: FREETYPE_INCLUDE_DIR_freetype2
FREETYPE_INCLUDE_DIR_freetype2-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FREETYPE_INCLUDE_DIR_ft2build
FREETYPE_INCLUDE_DIR_ft2build-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FREETYPE_LIBRARY
FREETYPE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: GLEW_INCLUDE_PATH
GLEW_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: GLEW_LIBRARY
GLEW_LIBRARY-ADVANCED:INTERNAL=1
HAVE_CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=TRUE
//Have include stddef.h
HAVE_STDDEF_H:INTERNAL=1
//Have include stdint.h
HAVE_STDINT_H:INTERNAL=1
//Have include sys/types.h
HAVE_SYS_TYPES_H:INTERNAL=1
HAVE__SYSTEM_BIG_ENDIAN:INTERNAL=TRUE
//ADVANCED property for variable: ICONV_LIBRARY
ICONV_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: INTL_LIBRARY
INTL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: JPEG_INCLUDE_DIR
JPEG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: JPEG_LIBRARY
JPEG_LIBRARY-ADVANCED:INTERNAL=1
LIBRARY_OUTPUT_PATH:INTERNAL=/opt/blender-2.64a_built_from_source/lib
//ADVANCED property for variable: OPENCOLORIO_INCLUDE_DIR
OPENCOLORIO_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_HALF_LIBRARY
OPENEXR_HALF_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_IEX_LIBRARY
OPENEXR_IEX_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_ILMIMF_LIBRARY
OPENEXR_ILMIMF_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_ILMTHREAD_LIBRARY
OPENEXR_ILMTHREAD_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_IMATH_LIBRARY
OPENEXR_IMATH_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENEXR_INCLUDE_DIR
OPENEXR_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_INCLUDE_DIR
OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_xmesa_INCLUDE_DIR
OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENIMAGEIO_INCLUDE_DIR
OPENIMAGEIO_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENIMAGEIO_LIBRARY
OPENIMAGEIO_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENJPEG_INCLUDE_DIR
OPENJPEG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENJPEG_LIBRARY
OPENJPEG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OpenMP_CXX_FLAGS
OpenMP_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OpenMP_C_FLAGS
OpenMP_C_FLAGS-ADVANCED:INTERNAL=1
//Test OpenMP_FLAG_DETECTED
OpenMP_FLAG_DETECTED:INTERNAL=1
//ADVANCED property for variable: PNG_LIBRARY
PNG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PNG_PNG_INCLUDE_DIR
PNG_PNG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PYTHON_INCLUDE_DIR
PYTHON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PYTHON_LIBRARY
PYTHON_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PYTHON_LINKFLAGS
PYTHON_LINKFLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PYTHON_NUMPY_PATH
PYTHON_NUMPY_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: PYTHON_VERSION
PYTHON_VERSION-ADVANCED:INTERNAL=1
//ADVANCED property for variable: RPMBUILD
RPMBUILD-ADVANCED:INTERNAL=1
//ADVANCED property for variable: SDLMAIN_LIBRARY
SDLMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: SDL_INCLUDE_DIR
SDL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: SDL_LIBRARY
SDL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: SDL_LIBRARY_TEMP
SDL_LIBRARY_TEMP-ADVANCED:INTERNAL=1
SDL_LIBRARY_TEMP:INTERNAL=/usr/lib/libSDLmain.a;/usr/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDLmain.a;/usr/local/lib/libSDL.so;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread;-lpthread
//ADVANCED property for variable: SPACENAV_INCLUDE_DIR
SPACENAV_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: SPACENAV_LIBRARY
SPACENAV_LIBRARY-ADVANCED:INTERNAL=1
//Test SUPPORT_SSE2_BUILD
SUPPORT_SSE2_BUILD:INTERNAL=1
SUPPORT_SSE2_BUILD_COMPILED:INTERNAL=TRUE
//Result of TRY_RUN
SUPPORT_SSE2_BUILD_EXITCODE:INTERNAL=0
//Test SUPPORT_SSE_BUILD
SUPPORT_SSE_BUILD:INTERNAL=1
SUPPORT_SSE_BUILD_COMPILED:INTERNAL=TRUE
//Result of TRY_RUN
SUPPORT_SSE_BUILD_EXITCODE:INTERNAL=0
//ADVANCED property for variable: Subversion_SVN_EXECUTABLE
Subversion_SVN_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TIFF_INCLUDE_DIR
TIFF_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TIFF_LIBRARY
TIFF_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_ASSERT_ABORT
WITH_ASSERT_ABORT-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_AUDASPACE
WITH_AUDASPACE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_BLENDER
WITH_BLENDER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_CXX_GUARDEDALLOC
WITH_CXX_GUARDEDALLOC-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_GHOST_DEBUG
WITH_GHOST_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_GHOST_SDL
WITH_GHOST_SDL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_HEADLESS
WITH_HEADLESS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_MEM_JEMALLOC
WITH_MEM_JEMALLOC-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_MOD_CLOTH_ELTOPO
WITH_MOD_CLOTH_ELTOPO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_PYTHON
WITH_PYTHON-ADVANCED:INTERNAL=1
//ADVANCED property for variable: WITH_PYTHON_SECURITY
WITH_PYTHON_SECURITY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_ICE_INCLUDE_PATH
X11_ICE_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_ICE_LIB
X11_ICE_LIB-ADVANCED:INTERNAL=1
//Have library /usr/lib/libX11.so;/usr/lib/libXext.so
X11_LIB_X11_SOLO:INTERNAL=1
//ADVANCED property for variable: X11_SM_LIB
X11_SM_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_X11_INCLUDE_PATH
X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_X11_LIB
X11_X11_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_XF86keysym_INCLUDE_PATH
X11_XF86keysym_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_XShm_INCLUDE_PATH
X11_XShm_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_XTest_INCLUDE_PATH
X11_XTest_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_XTest_LIB
X11_XTest_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xaccessrules_INCLUDE_PATH
X11_Xaccessrules_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xaccessstr_INCLUDE_PATH
X11_Xaccessstr_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xau_INCLUDE_PATH
X11_Xau_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xau_LIB
X11_Xau_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xcomposite_INCLUDE_PATH
X11_Xcomposite_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xcomposite_LIB
X11_Xcomposite_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xcursor_INCLUDE_PATH
X11_Xcursor_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xcursor_LIB
X11_Xcursor_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xdamage_INCLUDE_PATH
X11_Xdamage_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xdamage_LIB
X11_Xdamage_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xdmcp_INCLUDE_PATH
X11_Xdmcp_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xdmcp_LIB
X11_Xdmcp_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xext_LIB
X11_Xext_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xfixes_INCLUDE_PATH
X11_Xfixes_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xfixes_LIB
X11_Xfixes_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xft_INCLUDE_PATH
X11_Xft_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xft_LIB
X11_Xft_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xinerama_INCLUDE_PATH
X11_Xinerama_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xinerama_LIB
X11_Xinerama_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xinput_INCLUDE_PATH
X11_Xinput_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xinput_LIB
X11_Xinput_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xkb_INCLUDE_PATH
X11_Xkb_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xkblib_INCLUDE_PATH
X11_Xkblib_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xlib_INCLUDE_PATH
X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xpm_INCLUDE_PATH
X11_Xpm_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xpm_LIB
X11_Xpm_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xrandr_INCLUDE_PATH
X11_Xrandr_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xrandr_LIB
X11_Xrandr_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xrender_INCLUDE_PATH
X11_Xrender_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xrender_LIB
X11_Xrender_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xscreensaver_INCLUDE_PATH
X11_Xscreensaver_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xscreensaver_LIB
X11_Xscreensaver_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xshape_INCLUDE_PATH
X11_Xshape_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xt_INCLUDE_PATH
X11_Xt_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xt_LIB
X11_Xt_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xutil_INCLUDE_PATH
X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xv_INCLUDE_PATH
X11_Xv_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xv_LIB
X11_Xv_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xxf86misc_LIB
X11_Xxf86misc_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_Xxf86vmode_LIB
X11_Xxf86vmode_LIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_dpms_INCLUDE_PATH
X11_dpms_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_xf86misc_INCLUDE_PATH
X11_xf86misc_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: X11_xf86vmode_INCLUDE_PATH
X11_xf86vmode_INCLUDE_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
//Result of TEST_BIG_ENDIAN
_SYSTEM_BIG_ENDIAN:INTERNAL=0
Tehrasha
Postby Tehrasha » Sun Nov 11, 2012 9:32 am
I agree, I think something might be garffed with the latest SVN.
I have been successfully building Blender for months, and now suddenly after updating to the current SVN, my build sequence fails.
Code: Select all
CMake Error at /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:70 (MESSAGE):
  Could NOT find PythonLibsUnix (missing: PYTHON_LIBRARY PYTHON_LIBPATH
  PYTHON_INCLUDE_DIR PYTHON_INCLUDE_CONFIG_DIR)
This seems to imply that I do not have python, or at least the path to it is broken. But I have not changed anything since my last build, which obviously needed and found python to succeed..
Spacemice Wiki -- Input devices for a 3D world.
Spacemice / Blender Compatibility
stiv
Postby stiv » Sun Nov 11, 2012 4:30 pm
We are using Python 3.3 in svn trunk now.
mikevan
Postby mikevan » Fri Nov 16, 2012 6:11 pm
Tehrasha wrote:I agree, I think something might be garffed with the latest SVN.
Code: Select all
I followed the Blender wiki instructions on building Python3.3 which is now required to build Blender and installed it to /opt/py33 and amended my paths to point to that and it all compiles fine in that regard. The install_deps.sh script installs the Python3.3 to /opt/lib/python-3.3 so if you use that you'll want to reflect that dir in your user-config.py file if using scons or point to it in your cmake setup.
Return to “Coding Blender”
Users browsing this forum: Bing [Bot] and 0 guests
