Videotexture Video4Linux2
darkshine
Postby darkshine » Wed Sep 28, 2011 12:11 pm
Hi People,
im working right now the first time with VideoTextures in Blender.
I have right now a little problem, I know that my webcam is a Video4Linux2 Device - is it possible that it can work with the actual Blender Version?
I saw this post -> http://www.blender.org/forum/viewtopic. ... hlight=v4l and I thought - maybe there is already a solution for this? (Because the post is from 2008).
This is the Code that i use - is there something wrong?
Code: Select all
import GameLogic as G
import VideoTexture as VT
def init_world():
   cont = G.getCurrentController()
   obj = cont.owner
   matID = VT.materialID(obj, 'MAvideo')
   G.video = VT.Texture(obj, matID)
   S1 = G.expandPath("/dev/video0")
   video_source = VT.VideoFFmpeg(S1, 1, 25.0, 320, 240)
   video_source.repeat = -1
   video_source.scale = True
   #video_source.flip = False
   #video_source.deinterlace = True
   G.video.source = video_source
   G.video.source.play()
   #sound = cont.actuators["a_sound"]
   #cont.activate(sound)
   #G.sound = sound
def update():
   G.video.refresh(True)
Thank you for your help :)
darkshine
Re: Videotexture Video4Linux2
Postby darkshine » Wed Sep 28, 2011 5:07 pm
darkshine wrote:Hi People,
Code: Select all
def init_world():
   obj = cont.owner
   #G.sound = sound
def update():
Ok I found a solution :D
I changed in /source/gameengine/VideoTexture.cpp Line: 623
Code: Select all
inputFormat = av_find_input_format("video4linux");
to
Code: Select all
inputFormat = av_find_input_format("video4linux2");
I hope it helps someone :)
Thillbucci
Postby Thillbucci » Mon Jan 02, 2012 1:18 am
Thanks for this hint Darkshine!
In Blender Version 2.6 this change has to be made in file /source/gameengine/VideoTexture/VideoFFmpeg.cpp Line: 625
Unfortunately it's not working for me on a Mac to access the stream of the iSight camera, but this may have other reasons...
stiv
Postby stiv » Mon Jan 02, 2012 2:47 am
Pardon my ignorance on the subject, but is that the name of the video device under OSX?
Thillbucci
Postby Thillbucci » Mon Jan 02, 2012 1:23 pm
stiv wrote:Pardon my ignorance on the subject, but is that the name of the video device under OSX?
Unfortunately not and it seems none too easy to grab a camera stream on OSX this way (http://stackoverflow.com/questions/6557655/mac-webcam-get-the-device)
I'm trying to use OpenCV now... Or is there anybody who knows another solution?
Maybe I should open a new thread for further questions regarding to video-streams on OSX :?
sphaero
Postby sphaero » Tue Feb 28, 2012 3:22 pm
Thillbucci wrote:
stiv wrote:I'm trying to use OpenCV now... Or is there anybody who knows another solution?
Just to confirm: FFmpeg does not support video capturing on OSX currently.
Rg,
Arnaud
sphaero
Postby sphaero » Mon Apr 02, 2012 2:06 pm
Just to note I've suggested a patch for BGE to incorporate an extra parameter to set the format. This fixes the hardcoded video4linux problem.
http://projects.blender.org/tracker/ind ... 9&atid=127
My suggestion to get OSX capture support is to add a VideoGstreamer module like the VideoFFMpeg. Just not my cup of tea yet as I'm just staryting to get into the source :S
Rg,
Arnaud
ldo
Postby ldo » Tue Apr 03, 2012 12:26 am
Things like this used to be done on the Mac through QuickTime APIs—you had the low-level video-capture “components” that knew about specific hardware, and the higher-level sequence-grabber on top of that, that kind of thing.
Does that not work any more?
offtools
Re: patch
Postby offtools » Thu May 10, 2012 5:22 am
sphaero wrote:Just to note I've suggested a patch for BGE to incorporate an extra parameter to set the format. This fixes the hardcoded video4linux problem.
Rg,
Arnaud
The patch opens some new possibilities. x11grab works with it, which is a cool thing. Unfortunately my easycap dc60 usb capture device still doesnt work in the bge. av_open_input_file fails. The problem is the deprecated api code, which is still used. Who maintains the VideoFFmpeg Code. I've started to add some changes too, but I can test only on Linux.
offtools
gstreamer
Postby offtools » Thu May 10, 2012 5:24 am
Yes and Gstreamer would be awesome :)
Return to “Interactive 3d”
Users browsing this forum: Google [Bot] and 1 guest
