Previous Thread  Next Thread
chat icon Render issue
maxmajki
Posted: Sat Oct 08, 2011 10:36 am
Does somebody know what the problem is with the "T" in producTion in this video http://www.youtube.com/watch?v=KIXtBTOkgjg
Tehrasha
Posted: Sat Oct 08, 2011 7:01 pm
Looks like Z-fighting
You have duplicate faces in there somewhere, and they are 'fighting' to be the on top. In fact, it looks like you might have two 't's right on top of each other.
maxmajki
Posted: Sat Oct 08, 2011 8:05 pm
Thanks for responding
And how can I solve this??
Tehrasha
Posted: Sat Oct 08, 2011 9:03 pm
You need to delete the duplicates.
There are many ways to do this, depending on how your model is setup.
Try selecting the entire 't' in Edit Mode and then 'remove doubles'.
If there is an entire duplicate 't' which is also a different object, that will not work. In that case you will need to delete one of the two objects.
maxmajki
Posted: Sat Oct 08, 2011 9:08 pm
But there is only 1 object and 1 letter T
Tehrasha
Posted: Sat Oct 08, 2011 9:57 pm
If there is not a hidden duplicate causing it, I do not know what to tell you.
You could upload the .blend file somewhere, and I could take a look at it if you want.
maxmajki
Posted: Sun Oct 09, 2011 12:47 am
Here is the link http://dl.dropbox.com/u/19932671/maxmajkicenturyfox.blend
Tehrasha
Posted: Sun Oct 09, 2011 3:56 am
Sorry for the delay.
Yes, it is definitely z-fighting.
I didnt think to ask if you had left the text as a text entity instead of converting it into a raw mesh. If you convert all of your text to mesh ( Alt-C ) you can them remove doubles and the flicker goes away.
Might also save you some render time. Smile
maxmajki
Posted: Sun Oct 09, 2011 10:15 am
Thanks so much Tehrasha, it works!! Very Happy
Jump to:
