Error message when using modifier
GLakie
Postby GLakie » Sat Nov 12, 2011 12:41 am
While trying to use the solidify modifier, I keep getting an error message that says "Modifier cannot be applied to mesh with shape keys". I've tried using the remove shapekeys function with no help and also on the same object, boots, the smooth function in the toolbar distorts the boot in a really ugly way. Maybe they're both suffering from the same problem, and I just can't find it. Please help if you can.
abre360
Re: Error message when using modifier
Postby abre360 » Sun Nov 13, 2011 3:11 am
GLakie wrote:While trying to use the solidify modifier, I keep getting an error message that says "Modifier cannot be applied to mesh with shape keys". I've tried using the remove shapekeys function with no help and also on the same object, boots, the smooth function in the toolbar distorts the boot in a really ugly way. Maybe they're both suffering from the same problem, and I just can't find it. Please help if you can.
Maybe you should upload .blend file to analyze it.
Return to “Interface & Tools”
